241 - 260 of 290 Posts
COTM Winner
Discussion Starter · #241 ·
I'll be honest it would be easier to buy an injen. But
3 inch carbon fiber pipe was about 75 to 80 dollars. 3 inch 90 degree connector 50. I bought 2 different carbon fiber panels as originally I was going to build an enclosure over the port where a CAI drops in but opted for a different route. I'm using one of then panels as the holder over that port for the lower portion with a larger zzp filter. I'll try and lay everything out once I'm done with it for sure. And after I file my patent. :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO:
2013 Cruze LT
Sorry, I meant the brakes.
COTM Winner
Discussion Starter · #244 ·
OHHHHHHHHHH lol um yeah pretty sure im under 400..
$70 for a pair of calipers and brackets <debated getting the powder coated ones but that would have been well over the 400>,
$50 For pads
$50 for Dust shields
$85 For Rotors
$15 for the drill bit I didnt have <one of few>
$?? Caliper Bolts I seem to forget about this part.. Hopefully I'll find what I need before Friday.
Current total $270. Though this is only the fronts. I havent decided if Im pad slapping the rear or replaceing pads and rotors
Reactions: Thebigzeus
2013 Cruze LT
$50 For pads
$85 For Rotors
Nice, mine seem to fade under hard braking, thinking of pricing this out and doing it.
COTM Winner
Discussion Starter · #246 ·
Thats why im doing it lol.. ive noticed it a lot since the day I got the car.. I end up in traffic a lot and seem to have to apply more pressure than necessary to slow down and then it finally starts to have effect by which point its more of a sudden stop ...
COTM Winner
Discussion Starter · #247 ·
now wishing I would have seen this before I bought my parts....
Encore set
COTM Winner
Discussion Starter · #249 ·
Except I dont want the redrilled rotors that I have to get remade whenever I need a set. And although the dual piston set up sounds good I'm familiar with the issues on those calipers.
2013 Cruze LT
You'll likely never need new rotors for the rest of the life of the car though.
Re-drilled from 5x110 to 5x105 or as in drilled and slotted -
I'm confused
COTM Winner
Discussion Starter · #257 ·
I'm confused
The zzp.ones are redrilled for the cruze lug pattern. Drilled and slotted references the rotor faces themselves.... and yeah I was able to stay under 400 with an encore setup. No one said anything about an upgraded version of the setup with powder coated calipers and drilled rotor faces.. the link I put up.. and still at 401.. lol grief over a buck :p
COTM Winner
Discussion Starter · #258 ·
Updated the antennae. Apparently visual garage isn't that busy because I got mine in about a week.
293609
Reactions: Blasirl
COTM Winner
Looks good! Love the look of the shark fin on my Volt, but Christ the reception sucks with one.
COTM Winner
Discussion Starter · #260 ·
I dont seem to have any issues.
