Maybe it works better, but the ones on the Volts are notorious for **** reception. 90% of the time it's fine, but it can get noticeably crappy in certain spots...like where I back into next to my garage.I dont seem to have any issues.
Yeah, Satellite radio is a whole different thing.I've had issues with xm connecting but that's typically when the car is blocked in by a building or the car wash. And that was with the stock unit.
It's just the stock one. Everyone gets bad reception with it, but I so infrequently listen to the radio with mine, it's not a big deal. And if you're moving, it's not really an issue either.What sharkfin do you have on your volt??? Stock unit or aftermarket?
I had crappy reception before I installed mine. Still the same. About three stations in a station rich area since I bought it in 2014.Looks good! Love the look of the shark fin on my Volt, but Christ the reception sucks with one.
Well, thank you PatFinally got the Maf sensor holder done .. Still have to get it onto the pipe and finish the holder for the drop down.. Hopingto have enough time friday to drop that on and switch the brakes over.. and since neither @JLL or @Blasirl have instaled them yet I'm going to put the set of bushings I made in place of the whitelines.. and yeah im just giving you guys a hard time. '
I have been more interested in getting her to run right first. I am still waiting on the front sway bar, and I still need to order tires. all of that will happen at the same time. At least I have the bushing ready to go!!Finally got the Maf sensor holder done .. Still have to get it onto the pipe and finish the holder for the drop down.. Hopingto have enough time friday to drop that on and switch the brakes over.. and since neither @JLL or @Blasirl have instaled them yet I'm going to put the set of bushings I made in place of the whitelines.. and yeah im just giving you guys a hard time. '
Good to see you Pat.Well it's been a bit since i did any updates.. waiting on a few clamps for the CAI and going to try and get this brake setup in this weekend
For the 2 bolts deep in the oil pan, use a deep 8mm 1/4 drive socket with an extention.So Finally getting something done on this pooer car, looking forward to having it back.. Stated the teardown yesterday and ran into an issue trying to get the oil pan off.... and the weather is not letting me go out to work on it today . Turbo, intake and valve cover off. all but 2 bolts out of the oil pan.... 2 vertically through the pan into the engine block i cant seem to get my socket onto. Ordered a new oil cooler since i have it torn down this far already have new components for everything else.
standard 8 mm or the E8 ?? LMAO it took a while for me to figure out that I had missed 2 bolts there.... But on the lighter Side I had a half hour of sunlight to work with yet tonight so I hurried up and got the timing cover and chain off and pulled the headFor the 2 bolts deep in the oil pan, use a deep 8mm 1/4 drive socket with an extention.
