I have a 2014 ltz rs and i have a couple of questions about upgrades in the audio department. I'm not new to car audio but my last install was 12 or so years ago and things look a little different.
First, for the battery connections, what are you using? My battery has a large cover on the (+) side. I normally would use a car audio connector but I'm not sure that would work in this case. Im going to run 4 gauge power line to my amps.
Second, what is the best way to hook up an Audiocontrol lc6i? It will be in the trunk with the amps. Should I get a line converter like the pac aa gm 44 and run rca's to the lc6i or is there a better way?
I apologize if this info is already on this site. I have looked though the tutorials and alot of the audio posts. Thanks for any help
