About a month or so ago my check engine light came on. I had it scanned at O’Reiley’s and it posted with six codes. After reading the codes and description I loosened the clamp and took off what I would assume is possibly an intake hose for the Turbo. (I’ll post a picture with it circled). I’m no car expert by any means so I’m incorrect please correct me. After slightly removing the hose and pushing it back into place after a few hours or so of driving it clears. But periodically it will come back and I will repeat to get the light to come off. I have no idea what the issue is possibly a bad sensor. Any advice is greatly appreciated. The codes are:
P0098- Intake Air Temperature sensor 2 circuit high ( confirmed)
P0236- Turbocharger/supercharger boost sensor A circuit range/ performance( confirmed)
P0237- Turbocharger/ supercharger boost sensor A circuit low( confirmed)
P1101- Intake air flow system performance(confirmed)
P2227- Barometric pressure circuit range/ performance
P1101 Intake air flow system performance( permanent)
The two circuit codes suggests to me you've got a wiring or connection issue. Removing and replacing the hose is doing just enough to temporarily solve the problem.
Get some electrical parts cleaner (sometimes called "MAF sensor cleaner"), and blast the air pressure sensors. There should be one near the air filter housing and a boost sensor for the turbo (somewhere along the turbo hose).
Discussion Starter #4
I was thinking of replacing any sensors that could be causing the issue but I’ll also try to clean the sensors see if that works. Thanks!
