Welcome, sorry to hear about your problem.
This may or may not be the cause but it’s usually recommended as a good place to start if you haven’t already done so.
http://www.cruzetalk.com/forum/25-g...al-coverage-14311-negative-battery-cable.html
Also make sure the battery is in good shape. If it’s over 3-4 years old, might be suspect as well. The electronics on this car are very sensitive to electrical variances.
Good Luck!!
Good Luck!!
