System not pressurized? Try pressure test to see if it holds pressure
Thanks BossGreetings, most every 1.4t owner has had coolant system issues. It is THE most important system regarding this engine to keep in good condition. That means air/water tight and 100% sealed up to 20 psi.
imho and as briefly as I can say pertaining to the cruze gen1 and from my own experience:
1. replace your coolant reservoir and cap. The photo clearly shows it has been leaking. Less than $30 us. Dorman or Acdelco.
2. Follow the upper smaller hose from the reservoir down to the coolant outlet. That connector is very fragile, replace hose if leaking.(acdelco) The hottest coolant liquid flows through the outlet from the engine and is directed to the radiator(big hose on front), oil cooler(smaller hose on front), the heater core hose(on back), and the return to reservoir(hose on top), and...another?. It has 1 of 2 coolant temperature sensors integrated. It is made of plastic and breaks apart under extreme heat. Replace it if leaking. $20 us. Acdelco
3. Follow the large hose down to the radiator inlet. the radiator on the cruze seems to be robust and is rarely the problem unless structural damage has happened.
4. Go to the radiator outlet on the other side and follow the large hose to the thermostat. Replace the thermostat if older than 50k Mi. $45 us. Acdelco. Also, the 2nd coolant temperature sensor is on the outlet side, edge of the radiator with an electrical connector.(can leak, but prob not). Also, the bleed screw is on back of radiator toward top, white color.
5. The thermostat is bolted to the water pump inlet. check for water pump leaks under that side of the engine. Water pump warrenty up to 10years/130k mi.
6. Check oil cooler(behind turbo) and turbo coolant hose connections for leaks. ( stick your fingers everywhere on cold engine for coolant drips)
You will get to know your car easily and most handy people can perform these repairs themselves with the correct inexpensive tools. Good Luck! Hope this helps, long post...I was in a sharing mood...
I am open to corrections if I missed or mis-stated anything.
Please check the "how to" section on the forum.
@Blasirl
The gauge is not working properly, see the same issue I had years ago and what I've done to make it work. No issues since.Temperature Half but Coolant keep boiling
There are now aftermarket METAL Coolant outlets that can be purchased....I highly suggest going that route for anyone that has theirs stock part fail. I replaced the stock Delco one 3...yes...3 times before they finally came up with a metal aftermarket option. This part should NEVER have been made out of plastic to begin with...but I digress.2. Follow the upper smaller hose from the reservoir down to the coolant outlet. That connector is very fragile, replace hose if leaking.(acdelco) The hottest coolant liquid flows through the outlet from the engine and is directed to the radiator(big hose on front), oil cooler(smaller hose on front), the heater core hose(on back), and the return to reservoir(hose on top), and...another?. It has 1 of 2 coolant temperature sensors integrated. It is made of plastic and breaks apart under extreme heat. Replace it if leaking. $20 us. Acdelco
@Blasirl
Could be. The cap needs to make a seal with the top of the tank and hold pressure up to 20psi. I made a pressure tester that pumps into the 5/16ths hose that goes into the top of the tank.. This proves that my cap/tank interface is good and it vents right at 20psi.I am having the same issue with my 2014 Cruze. I have already replaced the water pump and a leaking hose. Now after getting to normal operating temperature the coolant in the reservoir is boiling and coming out of hole beneath the cap. I have contemplated changing the thermostat but could it just be the reservoir?
