Unbelievable. Makes me want to rethink my tweeter install before I even begin. That's some awesome work. You are obviously talented. Maybe I should send you my pillars. How much does a pillar job like that cost, minus the speakers & the install?
R-
I didn't build them a friend of mine did. My total cost just for the pillars was $750. The entire audio system is probably close to $7500 including all my speakers/subs, the sub box, headunit w/interface, 3 amplifiers, sound deadening, power and ground cables (0,4,8,gauge), speaker wires, and rca cables....and I did all the work myself except for the A-pillars.
So those actually fit on top of the existing mirror cover? Looking at it closer, that's what it appears to be. Did they fit without modifications? They look good. I did not notice that it wasn't OEM. That's a nice find. Thanks.
I May try to fabricate/somewhat duplicate your pillars but my plan is to use my viffa tweeters & keep with xtreme revolution's SQ build as I have most everything to do it now. Just waiting on his door baffles and then I can start the install. I really want your pillars. I will order some new pillars from GM to hack up, just in case I'm not successfull. They're actually fairly inexpensive. The Modified pillars will change the off axis response a bit & may require a tune adjustment. I just hope when all is said & done that the factory head unit lives up to my expectations.
Rich.
· Administrator
