1 - 14 of 14 Posts
Hi to all other cruze owner i am just starting my SQ build this is a list of my equipment
Head Deck : Alpine INE-W997D
Processor : Alpine PXA-H800
Controller : Alpine RUX-C800
Amps : Alpine PDX-F6 X 2
Amp : Alpine PDX-M12 X1
Speakers : Morel Elates 603
Sub : Morel Ultimo 122
I hope you realize it is both a waste of material and a substantial increase in weight to apply a 100% coverage of peel n stick deadener.
There are far more effective ways to accomplish what you were doing. Since it's obviously too late, I'm stating this for anyone who reads this thread in the future.
Sent from my STV100-1 using Tapatalk
Sent from my STV100
I feel the need to disagree with that statement. While any deadener product will add weight, I am a firm believer of add as much as possible and/or afford. And/if you are at this point, you are already in deep. So go all in....IF you can afford the deadener, you can buy fuel, do not cheap out over gas costs cuz you put an extra 75/100 pounds in your car! I deadened my entire trunk and the trunk lid. Then I added layer of ensolite foam to it. MY doors also got the same treatment.
Sent from my STV100
Then you don't understand acoustics or the purpose of the products you're using. A vibration deadener requires 25% coverage to effectively deaden vibrations. Anything over that just adds weight with no benefit. You need a mass loaded medium to actually block out sound, and in that application, you can use a 100% coverage.
The mistake most people make is assuming vibration deadeners are anywhere near as effective as mass loaded layers in blocking out sound, which is why you see total coverage jobs with vibration deadeners and people call it good. It's the wrong tool for the job.
A mass loaded vinyl will be more effective than a vibration deadener. Sure, you can get a screw into drywall with a hammer, but it's the wrong tool for the job. If you have the money, do it right. 100% coverage of vibration deadeners is not doing it right. It's copying what the last guy did because it looked good.
Ensolite foam is good for absorbing certain frequencies, depending on the thickness you're using, and for thermal insulation, but it's a very poor sound blocking medium.
I'd recommend reviewing some of these purpose built products for yourself:
www.sounddeadenershowdown.com
A methodical approach to sound treatment will yield far better results for the same or less money and for the same or less weight. There is no universal sound treatment product that performs all of the tasks you need it to in an automotive environment well, which is what people think these peel n stick products are. Treat each area you are trying to address with products specifically designed for that purpose.
1 - 14 of 14 Posts
