If you'd improve on that reaction time, you'd be in the high 13's! :OFINALLY got it to the dragstrip! Ran 14.147 @ 97.8 mph at 13PSI. I was going to poke a hole in the wastegate vac hose but the track was closing and not enough time for another runView attachment 295933
R/T doesn't effect the E/T in this case but I hit high 13s today anywaysIf you'd improve on that reaction time, you'd be in the high 13's! :O
Got it posted just then
Depending on what ecu it’s running you need to get the airflow sensor config right. I needed to add a barometric pressure sensor and a tiap sensor to get my throttle working rightI'm currently in the really slow process of supercharging my 1.8L, do you have anything you'd recommend me knowing regarding boosting the 1.8L?
In a previous post I explain how to add the additional sensor for an e78 ecu. I basically wired the tiap sensor into the existing maf wiring and removed the extras, then pinned in a baro sensor. The tiap needs to be before the throttle pretty close if possible, and I have the baro sensor under the intake manifold in free air.I'm currently running in BARO in HP Tuners, but I don't physically have a sensor other than the one integrated into the current MAF, which would become useless when it seems pressure, right?
Where exactly do you relay these sensor to?
So you don't use your MAF anymore at all then?In a previous post I explain how to add the additional sensor for an e78 ecu. I basically wired the tiap sensor into the existing maf wiring and removed the extras, then pinned in a baro sensor. The tiap needs to be before the throttle pretty close if possible, and I have the baro sensor under the intake manifold in free air.
Nope, probably could with my new air intake having a larger diameter but I’m running in SD modeSo you don't use your MAF anymore at all then?
Why did you switch to exclusively using speed density?Nope, probably could with my new air intake having a larger diameter but I’m running in SD mode
MAF was exceeding hard airflow limit with the original setup. I may buy a new wiring harness and include the MAF as my intake is now largerWhy did you switch to exclusively using speed density?
