1 - 4 of 4 Posts
Figured I would just share my last tank of ⛽. Running 93
This was at the gas station filling up
The morning drive into work
And the drive home
Its about a 35 40 min drive to work. Some what alot of stop and go.
Also I let my car run for about 3 to 5 min. Before I pull off 9 times outta 9. Haha
Sent from my VK810 4G using Tapatalk
Very nice! But please keep in mind modern fuel pumps require fuel to stay properly lubricated. If you run your tank completely empty every time you run the risk of causing damage the pump and may have to replace it early.
I don't know that this is completely correct. The Cruze fuel pump sits in a plastic bucket that is filled with fuel within the tank I believe the pump has a weep hole to keep the bucket full.
1 - 4 of 4 Posts
