And I finally got to the timing belt. I broke the cover, the brass insert spun so it was a sol moment. There's no oil seepage on the timing side, but the idler bearing did poop its contents everywhere so a bit of grim with all the belt dust. Given that I washed the timing cover, hermonic balancer and gave a soapy scrub to the inside... The p0011 code looks strong with this one... New soliniod, new cam gear "Ina china" complements of the previous purchaser. Although original belts/ rollers. The water pump seems to have a couple seeping spots better veiwed without the timing cover on.
Stressing that you need the "special" lock tool to change your belt? Naw easy peasy the exhaust cam is a easy one hander to twist. I do recommend the carry over method with this. Marking spots with sharpy as pictured below, makes for a fool proof way as you verify the belt Length carrying over the marks, and everything is marked on the gears.
And back to better. The car runs a little more responsive. And quieter
Weird notes I thought I torqued the crank bolt, and on start up the bolts threaded out. After reinstalling I turned on the car and the headlights were blinking along with the parking brake on warning beeper, even though I didn't have the parking brake drawn. Second start up the lights still blinked and the next start it was back to normal.
