1 - 2 of 2 Posts
I have a 2012 LS 1.8L, I just recently noticed a coolant leak. After checking I found that the lower radiator hose has a small leak. I also found that on the top of the thermostat/water outlet housing there is a connection with an elbow connector that connects a hose that goes up and over the engine to a connection on the left side of the engine. The elbow connection from the hose to the water outlet has cracked and is also leaking. I have been researching online and have found that there seems to be several different names for this hose and connector. I am posting here in the hopes that someone can give me the correct name of this connection and hose so I can order the correct replacement part. Any help would be greatly appreciated. I have attached pics of the leaking part. Thanks. Auto part Fuel line Engine Vehicle Suspension
Auto part Engine Vehicle Car Automotive engine part
1 - 2 of 2 Posts
