You still have air in your cooling system. It needs to be vented. GM has a piece of dealer equipment called a vac-u-fill or something like that. Call around and try to find a dealer that has that equipment.
The cooling system air bleed in the Cruze needs to be done level, not with the front end lifted. Lifting the front end leaves a lot of air trapped in the radiator. What's the coolant level in the tank? It should be at the top of the arrow pointing up to the top rib of the tank. If it's lower, fill it. If it's down to the large hose this is the source of the air in the system.Thank you Ill call around the dealer told me they raised the cars front end up on a lift and bled the system nothing else they can do, air will work its way out.
