Hi, 2012 Lt 1.4L, 135670 miles, USA.
Recently, (yesterday) changed out water pump and thermostat. Water pump was leaking and thermostat busted. Also in 2013 water pump and thermostat was changed due to overheating recall.
Now after test drive, coolant reservoir is boiling and sounds like boiling in engine. Also, digital reading is going from 221 to 235. Fan comes on only on high at 230ish. Temps go down to 225 then back up 230s and fan on and the process continues over and over. Fan does come on with AC on also.
Digital reading before changing thermostat and water pump was 210 to 216 at normal driving temp. Do not want the engine to overheat.
What do you recommend to be changed to fix the problems or resolutions?Maybe change a sensor or coolant reservoir and cap?
