Hey everyone, I need some help with my 2011 Cruze. The valve cover had the typical failure where you can hear it sucking air, so she bought a new valve cover and I threw it on. There was also an issue with the corrugated hose that goes from the intake to the turbo. It was cracked so I replaced it. Just about 3 weeks after replacing the VC the vent in the disk for the valve cover has started leaking oil out. If I pull the dipstick or the oil cover off there is excessive blow by. I was considering a kit from one of the Admins on here. I am not sure that is a symptom that I have read so far about the PCV problem. I have to do a compression test and hopefully will have a chance this weekend. Now another issue has crept up. I am getting a code P0472 (Exhaust Pressure Sensor Low Input). I did some searching and couldnt find anything for this on the Chevy Cruze. Does anyone have some suggestions.
