I called KY and ordered the Stage 2 clutch with slave cylinder for 375$ shipped. I'll be putting it in next week, hopefully. I'll also do a write up. It shouldn't be too bad of a job to do on jack stands. Has anyone done this job? If so, any tips?
I plan on taking plenty for remembering where bolts go and that sort of thing, I'm also replacing the driver's side fender, so, I'll be documenting that as well.
I'll do my best. I've never changed a clutch in a fwd car before. I've put a clutch in a '96 Mustang GT and an '84 BMW 735i, both rwd cars. So, it'll probably be a really lengthy job compared to those vehicles.
I remember reading a write up a while back about a member here who ordered a stage 1 clutch from BNR and installed it himself. can you try searching and see if it comes up?
I got the clutch in from KY. It didn't fit in the flywheel. It was the stage 2. I don't really have time to send my flywheel in and wait on it as I have to work and stuff, so, I got another stocker for now.
2011-2016 Cruze 1.4L PCV Valve Cover/Intake Manifold Issues
Video:
I made a video to help better explain how this whole PCV system works to supplement this article.
Overview
I find myself having to explain this issue to someone almost daily, so in the interest of brevity, I'm creating a...
Hi all,
Recently, I've started noticing a few unusual feelings while driving my car, including: skipping 2nd gear (revs only to about 1200rpm after 1st, quickly shifting, dropping to around 900rpm when shifting, and then jumping up to 1700rpm after "skipping" all with my foot hardly on the...
I have a 2014 lt. It had the typical pcv issue rough idle same as always so I changed the valve cover. Then it started spewing oil out of the valve cover. I tried another one I thought it was warped but the same thing happened. So I just changed the intake and I broke the flimsy corrugated pcv...
Hello I am brand new here and need some advice. I have a 2014 Cruze Ltz and the transmission fluid has never been changed. The manual states it should be done every 45000 miles. Since it is so far past the maintenance time should I change the fluid or should I just leave it alone? I am scared I...
Hello! I read through some threads ahead but didn't really find what I am looking for as far as "power loss explanation. I have a trifecta tune and normally would get to 23-24 pounds boost under full uphill acceleration in performance mode. I reflashed my car and suddenly I cannot get over 10...
