Some coolant will be lost so plan on adding.
There is a 'O'ring around the nipple that you will see once the clip is pulled and hose removed....I guess 200k plus miles is starting to show.
'O' ring is probably turned to rock by now.
Be very gentle.....the plastic ends become very brittle in their old age.....if a replacement hose (will have nipples included) is available, I'd probably change the whole thing.
I'm basing my thoughts on thermal cycling.....you have far more than the average 30k driver on the forum and this may make 'O'ring replacement a bit dicey.
