Hello everyone,
New member from Pittsburgh, PA with a 2012 Cruze LTZ. Autumn Metallic with black brick interior.
Joined the forum because I been having some issues with my Cruze. Recently got a CEL for P0171. Relating to the PCV valve in the cam cover. I did not have the symptoms of a bad idle (yet). Cleared the code and changed the plugs (car was at 90k miles). Noticed there was oil on several of the plugs. Drove it for a week now I have the horrible idle. So I scheduled the dealer to look at the car. Told them they needed to order the cam cover and said they said they couldn't until they looked at the car. I also asked if they could do a compression test cause I know these cars can crack pistons. They looked at me like I am crazy and said they don't have a reason to do a compression test. So I drop the car off they confirm it is the cam cover. They said the part is on back order. So fast forward a week goes by and they wont give me a donor car cause I work out of state. So I ask for a rental and they said the part will be here tomorrow. Several days go by and no part is here. I am getting frustrated at this point. I decide to pick my car up and it can sit at my house versus the dealer. I pick the car up and my girlfriend drives it home and it pours smoke out the whole way home. (note..when I dropped it off with a bad PCV valve it did NOT smoke) I call them freaking out and they said they cant do anything until the cam cover is replaced. So another week goes by the part is finally in. I bring the car is for the cam cover replacement. I once again ask for a compression test and they said they will see once the cam cover is replaced if it still smokes. Call me couple hours later and tell me its done. I pick it up and before leaving I let it idle. I still smell oil burning. I drive it home and my buddy follows me and says he can see it still smoking. I let it idle in front of my garage for 10 minutes and it fills my garage with smoke. So I immediately take it back to the dealer and tell them. They say they will look at it. So I go back out to my car and notice a puddle under it. Pop the hood and see they cracked the water outlet pipe. So today they replace the pipe and tell me they drove it 20 miles and it did not smoke. I will be picking it up after work today. I am extremely frustrated with the whole situation.
My warranty is up in December. I have the feeling they are trying to push the work off until my warranty is up. I literally had zero other problems in the first 90k miles. I replaced tires twice and did the brakes once. I consistently got 32mpg over these 90k miles. I am at the point where I am ready to trade the car.
