Hi, I recently purchased a used chevy cruze 2012 LT model. I must say I'm quiet impressed with it. However i do have few things I'm struggling to understand and a couple of problems I'm facing at the moment.
1-What does the letters that show up on the right side on the dic panel next to the mileage reader means. I see it moves between N, E, SW and others when the car is moving in D (Automatic mode). Have read the manual thoroughly and i still couldn't find it explained.
2. I had to change the left headlight since it was broken. Recently when i switch to high the left headlight doesn't come on but the right is ok. But when i switch to low both lights come on.
3. I also hear little noise (When on rough roads) and whining noise when i turn the steer. (mostly beyond 60 degrees either left or right). The manual says i have an electric power steering.
4.Engine light on. Error code P0171. Some videos on youtube suggest i replaced the pcv valve. But i want to know if its ok to drive around.
Car was 54000m when i purchased it and I'm currently at 56100m. Any help on above will be much appreciated. Thanks.
