Noticed what is cracked? All I see is the split in the loom. That cloth tape all looks fine.
Oh...I feel rather dumb now 😅 Good to know, thank you!Noticed what is cracked? All I see is the split in the loom. That cloth tape all looks fine.
I thought you were trolling us...Oh...I feel rather dumb now 😅 Good to know, thank you!
It can also keep the moisture in, especially on a split loom facing upwards collecting water like a bucket...Wrapping the split loom in electrical tape wouldn't be a bad idea to keep the dirt out.
It depends on how the ends are handled. In this case I'd think it would be a good idea to wrap it to prevent water from going on. Either that or replace it with a loom where the gap is pointing down.It can also keep the moisture in, especially on a split loom facing upwards collecting water like a bucket...
Naw remove the plastic loom crap and go with sealtite conduit like they should have done in the first placeIt depends on how the ends are handled. In this case I'd think it would be a good idea to wrap it to prevent water from going on. Either that or replace it with a loom where the gap is pointing down.
Either way, not a big deal, just some car lovin'.
Nope, just clueless and new to cars 😅I thought you were trolling us...
Dealing with those exact same issues right now here r my picks:I bought my ... cruze in 2021 and immediately started having coolant leaks... I'd check the stem on the overflow reservoir(coolant tank) that is fitted to the top hose and make sure it's not cracked. Then I'd check the water inlet valve on the right side of the engine for leaks. I had issues with both and I think they're notorious for leaks.
