1 - 4 of 4 Posts
Hey y'all.
I have a 2011, 1.4 lt turbo, gasoline engine cruze. Its LT and colored silver blue. Current mileage is 150.120.
I own the vehicle for about 6 months and already changed coolant surge tank, hose, pcv valve cover, gas cap and purge valve vapor canister.
Looks like I'm in for a bumpy ride
Welcome Aboard!(y)
You have changed a few of the things that are well documented here. You may run into a few more, but if you keep up, you should get many miles on the car in return. As for the valve cover, that is an engineering defect and may go again, but you will be able to find a suitable work around here.:
GM 1.4L Turbo Intake Manifold PCV Valve Fix Kits
As for anything else, just start a thread in the appropriate sub forum and ask away.
Discussion Starter #4
I saw the thread on the valve cover. At this point I crossed my fingers, hoping that the cover lasts.
1 - 4 of 4 Posts
