Once agian, EuroDezigns.com has proven their customer service is second to none. When they say they strive to be the best, they prove it with a great product and great customer service.
Anyway, I installed the pair of H13 Xenon/Krytpon bulbs that EuroDezigns.com sent me the other day after the first ones weren't working properly. It was finally warm enough to go outside and do it.
I am pleased to announce that EVERYTHING is working NORMALLY!!! No more backwards!!!
Below is a pic of the lights all done and VERY bright and VERY freaking cool!!!...
Very nice! So which H13's did they replace your originally ordered H13's with? There's only 1 available on the site. I assume you got both fogs and headlamps in blue since you said they were 8500K?
I called EuroDezigns and explained the problem and they sent me a replacement set, free of charge, and told me to go ahead and keep the ones I already had.
So the ones they sent worked just fine as you can see in the photo.
I would just assume the ones they replaced them with are the same, but from a different batch that was made.
Sounds good and looking great! Well done. Thanks for the info.
Buy from them with confidence because if it isn't right they WILL make it right.
