Hey guys, long time no see. We are having an issue with my wife's 2014 Cruze LT.
Vehicle Info:
1.4L Turbo
Auto Trans
~108,000 miles
Issue:
Since we got the car (2014), we've had no issues with the car going over the mountain. It has a pretty decent grade, but was always able to maintain the 45mph + speed limit. The last few days, we get so far up and the car feels like it falls flat on its face. I quickly begin to decelerate while the car can still down shift and hit 4500 RPM's, but there's no pick up. If I shut the car off for a few mins, it's like nothing ever happened. It will not have this issue going home over the same mountain. No CEL. I really don't want to have to get rid of the car just yet.
I can't see it being the transmission, because it shifts fine, but at the same time, its not displacing the power to the wheels. The other thought I had was the turbo.
Discussion Starter #4
Sounds like the Turbo?
I can't map it, I don't have the tools. But its seems to be around the same spot each time. Wastegate maybe? the actuator rod is a little rusted and flaked, maybe not allowing it to work properly?
Discussion Starter #5
Checked the wastegate out, no play whatsoever. Still lost on what it could be.
It is probably triggering an underboost code, which puts the car into limp mode. After several recurrences, it will trigger a check engine light.
Before replacing the turbo, boost leak or smoke test the turbo plumbing. The hose at the throttle body is a very common leaker.
