My 2013 1.8 auto needed a new engine. I've replaced the engine only, using the original harness.
After I finished hooking everything back up and filling the oil and coolant, it has a no crank issue.
There is power at the starter and if you jump the solenoid it will crank but not start.
With the key on, all lights on the dash come on, but if I turn the key to crank, the dash and display lose all power and no sounds or cranking happens.
I've checked all fuses and relays. I'm running out of things to check before I start taking everything apart again.
I'm hoping someone here can think of some ideas that I cant think of.
Thanks for any help!
o_O
Our old Mitsubishi Eclipse did that and turned out to be that the negative battery clamp was heavily corroded internally. It was a 2 piece clamp (sleeve and clamp) that had a terrible infestation of corrosion between the clamp and sleeve. New solid clamp fixed it
I had a similar no crank issue. Check the wiring that comes off the rack and pinion. It’s Under the car driver side and runs up to the front. It’s a 4 wire sensor. If that is damaged you will get your exact symptoms.
I went through and checked every connector on the wiring harness.
I checked the wire from the rack. It looks fine, it is not something I touched during the engine replacement.
I've jumped the negative battery cable to rule that out.
I'm starting to think it is the antitheft or immobilizer. Does anyone know a specific way to reset this? Im reading so many different methods online.
o_O
I have a 2012 Chevy Cruz with a 1.4 for about my mother is blue I had to replace it with the information out of a 2013 Using the original computer and wiring harness the car has no power to the light car will not turn over all clean and I was thinking my issue is does the computer have to be reprogrammed for all this to work The car drives fine before and now it won’t do anything Key is stuck in ingition help
Only problem I had is that I have a 2012 Chevy Cruze With 1.4 and I put a 2013 Chevy Cruz 1.4 L engine in my 2012 using the same computer after everything was put back in and with new battery and stuff none of the cars interior lights outside lights car will not crank or turn over at all I don’t know what happened everything worked before when I had my original motor using the original computer as well and it works fine to replace the engine so I don’t know if my computer needs to be reprogrammed for everything to work again or not it’s a newer car I’ve never had to have a computer program on engine swap if that’s the case y’all need to let me know cause I’m going to GM to find out tomorrow I thought that maybe something wasn’t hooked up right but everything is hooked up correct
check the main fuse / fuseable link ? sounds like your not getting power
o_O
Hello, I have the same problem. I put a 2013 engine into my 2015 and it wont crank. It does a bunch of wierd things when I turn the key on, wipers go on, lights flashing, etc...
I went underneath and jumped the starter and it turns over as it should. I beleive it is probably a security system / anti theft problem. Did you ever find out what was wrong with your car and how did you fix it?
Hello, I have the same problem with my 2015 cruze. Did you fix the problem and how did you do it?
Did anyone resolve their issues? I have just done an engine change on an Australian built 2012 Holden Cruze 1.8 litre(JH2) petrol and am encountering exactly the same problem.
