Hi guys I’m having problems with a no crank no start. I checked all fuses on the car, swapped starter relays with good ones, Car has a new battery, swapped out starter for a known good one and still nothing. Is there anything I should be looking at other than that?
if the cover will come off the starter relay , pop it off and push the relay contacts together if the starter runs then the problem is in the control side of the circuit, park neutral , ignition switch etc.
