I'm guessing the wire you noticed under the seat is for the sensor that tells the car someone is sitting there or if seat belt is buckled or not, however I'm no expert so take that with a grain of salt.
As for the air compressor, I have the exact same problem with that model. I think it's a function of tire pressure. As tire pressure goes up, so does amp draw of compressor. I was able to use it on other cars where I inflated tires to 32 psi no problem. However, when I used it on my truck (I keep those tires at 38 psi), the cord got hot and vehicle fuse would blow at 36 psi every time.
You should NEVER replace the vehicle fuse with one rated higher than what is called for in the owners manual. Remember the fuse size has nothing to do with protecting the components it runs, it is sized for the current rating of the wire itself. It is there to prevent the circuit from drawing more current than the wire can handle. If you replaced it with a higher amperage fuse, it would indeed run the compressor without blowing except now the burning plastic smell would be coming from a wire under your dash. It's a good way to find out how well your insurance policy covers fire.
