1 - 3 of 3 Posts
· Administrator
This is what I have found so far, although I vaguely remember posting something like this in the past here, but I could not find it. If you find any errors or some information to be added, please let me know. I think these apply to the Korean built Cruze.
Cruze Error Code Vehicle message
1 Change engine oil
2 No radio remote control detected, depress clutch pedal for a restart
3 Engine coolant level low
4 Air conditioning off
5 Steering wheel is locked
6 Depress brake pedal to release electrical parking brake
7 Turn steering wheel, switch ignition off and then on
8 Switch ignition off and then on, repeat breath test
9 Turn steering wheel, start engine again
11 Brake pads worn
12 Vehicle overloaded
13 Compressor overheated
15 Centre high-mounted brake light failure
16 Service brake lights
17 Headlight levelling malfunction
18 Left low beam failure
19 Rear fog light failure
20 Right low beam failure
21 Left front sidelight failure
22 Right front sidelight failure
23 Reversing light failure
24 Number plate light failure
25 Left front turn signal failure
26 Left rear turn signal failure
27 Right front turn signal failure
28 Right rear turn signal failure
29 Check trailer brake light
30 Check trailer reversing light
31 Check left trailer turn signal
32 Check right trailer turn signal
33 Check trailer rear fog light
34 Check trailer rear light
35 Replace battery in radio remote control
48 Clean side blind zone alert system
49 Lane departure warning unavailable
50 Activated pedestrian protection system, reset bonnet
51 Compass unavailable
53 Tighten fuel filler cap
54 Water in diesel fuel filter
56 Tyre pressure imbalance on front axle
57 Tyre pressure imbalance on rear axle
58 Tyres without TPMS sensors detected
59 Open and then close driver window
60 Open and then close front passenger window
61 Open and then close rear left window
62 Open and then close rear right window
65 Theft attempted
66 Service anti-theft alarm system
67 Service steering wheel lock
68 Service power steering
69 Service suspension system
70 Service level control system
71 Service rear axle
73 Service All-wheel drive system
74 Service AFL
75 Service air conditioning
76 Service side blind zone alert system
77 Service lane departure warning
78 Service pedestrian protection system
79 Top up engine oil
80 Change transmission fluid
81 Service transmission
82 Change engine oil soon
83 Service adaptive cruise control
84 Engine power is reduced
EDIT: 89 appears to be the thermostat from what I can find although others seem to think it may be the battery and another thinks it is a code for an oil change requirement.
91 Push Remote key to Cockpit to STOP
92 Push Remote key to Cockpit and Step on brake pedal to START
94 Push Gear to Park (P)
95 Service airbag
· Administrator
Discussion Starter · #2 ·
Code 67 (this is translated so ...)
For the starter button press ..
1. Sit in the car, close all the doors.
2. Press and hold the start button (no need to step on the brake) to make all dashboard lights go out
3. Get off the car and press the wheel button. #Only the remote
4. Walk away from the car about 10 meters for 5 minutes
5. Press release the wheel C # with the remote control only
6. Get into the car and close all the doors. Then step on the brake press start the car normally .. just this all code will disappear
1 - 3 of 3 Posts
