First thing to look at would be the swaybar end links. Notorious failure on the Cruze.
Any play will be magnified and transmitted into the car.....usually felt in the floorboards.....slow turns make it worse.
Swaybar bushings at the chassis are the next culprit.
Ball joints and tie rod ends are the least likely failure.
Your uneven tire wear is likely a result of not rotating tires and maintaining even tire pressure.
Let us know what you find.
