21 - 38 of 38 Posts
Discussion Starter · #23 ·
OUR 1.4 TURBO SIGN UP LISTS (please pop your hood and verify)
FOR THE 1.4 TURBO CARS WITH FIVE RIB PULLEYS:
2011 – 2015 CRUZE 5 rib -- NST71405
2012 – 2014 SONIC 5 rib -- NST71405
00. NonStopTuning - RED
01. RazerCruze15 - RED
02.
03.
FOR THE 1.4 TURBO CARS WITH SIX RIB PULLEYS:
2012 – 2015 SONIC 6 rib -- NST71406
01.
02.
03.
02. Cruzester - BLACK
03.
C'mon everyone sign up...After a Tune, this probably the last best chance to squeeze any bit of juice out of this this puny lawnmotor engine...I've had a lightweight pulley on my 93 cavalier, and it did make quite a difference out of the hole...It won't ruin your engine.
03. Theyseemecruzin - GREEN (are we looking at a lime green, or a forest green?)
04. ErickysGSX - BLACK
Discussion Starter · #30 ·
Sadly it looks like the community is not interested in these items. It's really too bad, I had high hopes for this chassis.
Huge thanks to the few who showed interested, unfortunately we will not be able to move forward if the majority of the community seems uninterested.
Thanks again.
Your article on the harmonic damper makes a lot of claims without the evidence to back things up which made me hesitant from wanting to take part in the group buy.
Particularly:
The crank pulley found on many modern engines is often called a harmonic damper. This damper is a thin rubber band, less than (1/8 inch) 2mm, built into the crank pulley. This rubber is used to absorb something called NVH, noise/vibration/harshness. Suffice it to say, this rubber is actually not very good at performing its intended purpose after as little as a few thousand miles. What happens to rubber after exposure to weather conditions such as humidity, snow, rain, etc? It often becomes brittle, hard, and crunchy. Can something with these properties actually absorb vibrations very well? Many NST customers have reported smoother running engines with NST pulleys, especially at idle. How is this possible if the rubber is such a vital important piece? As it turns out, the rubber is not as important as it is cracked up to be.
The argument is very weak and not convincing as you don't provide any evidence supporting that fact that "this rubber is actually not very good at performing". I would have liked to see data to support this claim to have made me feel more secure that it wouldn't damage or increase wear the engine. They dyno graphs show very little performance increase and do not necessarily prove that pulley itself increases horsepower "Correlation does not mean causation." As for smoother idle, isn't it possible that the people had worn harmonic balancer at the time of purchase? I would assume if they are purchasing a high performance pulley they are hard on their cars.
Talk to the thousands of NST customers across the globe and you'll find 99+ positive reviews regarding our products and their safety.
Lots of people on the internet purchase things and do things that are not safe. What are the odds that majority of the customers after driving 25,000 miles came back to the site to give feedback? So this does not really help us.
I would have been really interested if I just had a little more confidence.
What does a harmonic balancer do? | HowStuffWorks
I second what both XtremeRevolution and johnnydicamillo said.
If it was put up on FB too I might have seen it.
But also, I'd also be worried on damage/increase wear on the engine. Do you have any further data? Perhaps from a test platform (LUJ/LUV) engine that you have been developing against? Or is the part for this platform still speculatory at this point?
aww thats to bad:(
21 - 38 of 38 Posts
