1 - 16 of 16 Posts
Hi all
this is my first post so be gentile i have a chevy cruse LT 1.6 hatchback I am lovin it . i've lpged it and bought and installed a gps / stereo system it has the reverse camera option which i'm using with my old reverse camera but would like to install the numberplate camera
CHEVROLET EPICA/LOVA/AVEO/CAPTIVA/CRUZE REARVIEW CAMERA | eBay
it has the option of screws but i dont see any screws on my light fittings any ideas ?
any input welcome
Welcome to CruzeTalk. Can you get us hatchbackless folks in the Colonies some pictures? GM decided in their infinite wisdom that hatchbacks won't sell here.
Hi PHANTOM yes i had it converted just over a month ago and its running great {so far} it holds around 50 liters and is working out about half the running costs {apparently the tanks only hold 80% of their capacity}. it starts on petrol until the engine is warm enough then automatically goes onto lpg , when the lpg runs out it goes straight back to petrol Land vehicle Vehicle Car Auto part Engine
Auto part Pipe Exhaust system Automotive exhaust Muffler
wow! thats a lot of savings.
LPG conversion here in the PH costs an arm and a leg. LoL
But, majority of taxi cabs back here run on LPG though.
anyways, back on topic.
maybe the hatchback plate lights are locked in by tabs? either you have to pry it out with a prying tool or something, or access it thru the rear door/hatch panels?
but if the above is the case, you'd need to find a way to make the reverse cam from ebay to stay put. that is, if it has the same size as the stock plate lights?
on another note, maybe there is a reverse cam availlable for hatchback Cruzes on eBay somewhere? :)
Discussion Starter · #11 ·
Hi Phantom
Lpg costs a fortune here too but due to the mileage i do it should pay its self back within a year that means the next few years that i intend to keep the car for will be worth the investment. ill have a look at the back panel within the boot i just didnt want to start pulling it apart and end up breaking something
So that's what the Cruze hatchback looks like! Personally, I would buy it if we had it here in the States. I love the utility!
As for your camera, I don't know if this is any help, but I just bought and installed the same one. The US model has screws on the outside of the light, so it's literally a direct swap. BUT, in order to do it properly and run all the wiring, you have to remove the trunk lid liner (easy, it comes off with a flathead screwdriver by gently popping them up, then out). Then reach inside and remove the 4 nuts that hold the rear chrome trim piece on (where the rear plate lights are located). You may want to take a look in there and see how the light sits in the hole. You may be able to use the camera and exisiting screws. The existing clear lens may just be a "snap in" type that is covering the holes.
The whole thing of disassembly, mounting camera, running wires, putting everything back together took about an hour with one flathead screwdriver, one phillips screwdriver, and one deepwall socket for the nuts holding the chrome trim in place. Pretty easy for a DIY job...
1 - 16 of 16 Posts
