OBD-II Codes (this is from an overseas source, so they may not be the same as US built Cruzes)
5885 10
P001 - P0194
P0201 - P0433
P0434 - P0640
P0846 - P0920
P0921 - P1321
P1322 - P1791
P1792 - P2130
P2131 - P2715
P2716 - U0010
U0011 - U300
U301 - U0327
Cruze OBD-II Codes
P0001 Fuel Amount Adjustment Control Circuit (Open)
P0002 Fuel Amount Control Circuit Range / Performance
P0003 Complete control, adjust the fuel amount (low)
P0004 Complete control, adjust the fuel amount (high)
P0005 Fuel shutoff valve control circuit (open)
P0006 Fuel shut-off valve control circuit (low)
P0007 Fuel shutoff valve control circuit (high)
P0008 Engine position system performance (bank 1)
P0009 Engine Position System Performance (bank 2)
P0010 Crankshaft A Actual Position Circuit (Bank 1)
P0011 `` A '' crankshaft position - timing over-advanced or system performance (bank 1)
P0012 `` A '' Camshaft Position - Timing Over-Retarded (Bank 1)
P0013 Crankshaft position B operating (bank 1)
P0014 Crank B Song Position - Over-Advance Timing or Performance (bank 1)
P0015 'B' Crankshaft Position - Timing Over-Retarded (Bank 1)
P0016 Crankshaft Position-Camshaft Position Correlation (Bank 1, Sensor A)
P0017 Crankshaft Position-Camshaft Position Correlation (Bank 1, Sensor B)
P0018 Crankshaft Position-Camshaft Position Correlation (Bank 2, Sensor A)
P0019 Crankshaft position-camshaft position correlation (bank 2, sensor B)
P0020 Crankshaft A Actual Position Circuit (Bank 2)
P0021 A camshaft position - timing over-ahead (bank 2)
P0022 A camshaft position - timing delay over (bank 2)
P0023 Camshaft position B - operating circuit (bank 2)
P0024 B camshaft position - timing too advanced or system work (bank 2)
P0025 B camshaft position - timing delay over (bank 2)
P0026 Intake valve control solenoid circuit (bank 1)
P0027 Exhaust valve control solenoid circuit (bank 1)
P0028 Intake valve control solenoid circuit (bank 2)
P0029 Exhaust valve control solenoid circuit (bank 2)
P0030 HO2S heater control circuit (bank 1, sensor 1)
P0031 Heater Sensor Control Circuit Low (bank 1, sensor 1)
P0032 Heated Sensor Control Circuit High (bank 1, sensor 1)
P0033 Turbocharger bypass valve control circuit
P0034 Turbocharger bypass valve control circuit (low)
P0035 Turbocharger bypass valve control circuit (high)
P0036 HO2S heater control circuit (bank 1, sensor 2)
P0037 Heater Sensor Control Circuit Low (bank 1, sensor 2)
P0038 HO2S heater control circuit, high (bank 1, sensor 2)
P0039 Turbocharger bypass valve control circuit
P0040 O2 sensor signal swapped bank 1, sensor 1 / bank 2, sensor 1
P0041 O2 Sensor Signal Swapped Bank 1 Sensor 2 / Bank 2 Sensor 2
P0042 HO2S heater control circuit (bank 1, sensor 3)
P0043 Heater Sensor Control Circuit Low (bank 1, sensor 3)
P0044 Heater Sensor Control Circuit High (bank 1, sensor 3)
P0045 Turbocharger Control Solenoid Circuit (Open)
P0046 Turbocharger control circuit, range or performance problem
P0047 Turbocharger Control Solenoid Circuit (Low)
P0048 Turbocharger Control Solenoid Circuit (High)
P0049 Turbo speed too high
P0050 HO2S heater control circuit (bank 2, sensor 1)
P0051 Heater Sensor Control Circuit Low (bank 2, sensor 1)
P0052 Heater Sensor Control Circuit High (bank 2, sensor 1)
P0053 HO2S heater resistance (bank 1, sensor 1)
P0054 HO2S heater resistance (bank 1, sensor 2)
P0055 HO2S heater resistance (bank 1, sensor 3)
P0056 HO2S heater control circuit (bank 2, sensor 2)
P0057 Heater Sensor Control Circuit Low (bank 2, sensor 2)
P0058 Heated Sensor Control Circuit High (Bank 2, Sensor 2)
P0059 HO2S heater resistance (bank 2, sensor 1)
P0060 HO2S heater resistance (bank 2, sensor 2)
P0061 HO2S heater resistance (bank 2, sensor 3)
P0062 HO2S heater control circuit (bank 2, sensor 3)
P0063 Heater Sensor Control Circuit Low (bank 2, sensor 3)
P0064 Heated Sensor Control Circuit High (Bank 2, Sensor 3)
P0065 Injector Control Range / Performance
P0066 Injector control circuit or low
P0067 Injector control circuit or high
P0068 MAP / MAF relative to throttle position
P0069 MAP / BP pressure correlation
P0070 Ambient Air Temperature Sensor Circuit
P0071 Ambient Air Temperature Sensor Range / Performance
P0072 Ambient Air Temperature Sensor Circuit (Low)
P0073 Intake Air Temperature Sensor Circuit (High)
P0074 Ambient Air Temperature Sensor Circuit Intermittent
P0075 Intake valve control solenoid circuit (bank 1)
P0076 Intake valve control solenoid circuit low (bank 1)
P0077 Intake valve control solenoid circuit high (bank 1)
P0078 Exhaust valve control solenoid circuit (bank 1)
P0079 Exhaust valve control solenoid circuit low (bank 1)
P0080 Exhaust valve control solenoid circuit high (bank 1)
P0081 Intake valve control solenoid circuit (bank 2)
P0082 Intake valve control solenoid circuit low (bank 2)
P0083 Intake valve control solenoid circuit high (bank 2)
P0084 Exhaust valve control solenoid circuit (bank 2)
P0085 Exhaust valve control solenoid circuit low (bank 2)
P0086 Exhaust valve control solenoid circuit high (bank 2)
P0087 System Pressure Very Low
P0088 System fuel pressure very high
P0089 Fuel Pressure Regulator 1
P0090 Fuel Pressure Regulator 1 Control Circuit
P0091 Fuel Pressure Regulator 1 Control Circuit Low
P0092 Fuel Pressure Regulator 1 Control Circuit High
P0093 Oil System Leak Detected - Extreme Leak
P0094 Oil System Leak Detected - Little Leak
P0095 Intake Air Temperature Sensor 2 Circuit
P0096 Intake Air Temperature Sensor 2 Circuit Range / Performance
P0097 Intake Air Temperature Sensor 2 Circuit Low
P0098 Intake Air Temperature Sensor 2 Circuit High
P0099 Intake Air Temperature Sensor 2 Circuit Intermittent / Unstable
P0100 Mass air flow (air flow) circuit
P0101 Mass air flow (air flow) circuit, range or performance problem
P0102 Mass air flow (air flow) circuit low
P0103 Mass air flow (air flow) circuit high
P0104 Mass Air Flow (Air Flow) Circuit Intermittent
P0105 Manifold pressure / barometric pressure circuit
P0106 Pressure circuit, range or performance problem Manifold / Barometric
P0107 Manifold / Barometric Pressure Circuit Low
P0108 Manifold pressure / barometric pressure circuit, high
P0109 Manifold / Barometric Pressure Circuit, Intermittent
P0110 Intake Temperature Sensor # 1 Circuit
P0111 Intake Temperature Sensor 1 Circuit Range / Performance
P0112 Intake Air Temperature Sensor 1 Circuit Low
P0113 Intake Air Temperature Sensor 1 Circuit High
P0114 Intake Air Temperature Sensor 1 Circuit Intermittent
P0115 Engine coolant temperature circuit
P0116 Coolant temperature circuit, range or performance problem
P0117 Engine coolant temperature circuit, low
P0118 Engine coolant temperature circuit, high
P0119 Engine coolant temperature circuit, intermittent
P0120 Throttle / Pedal Position Sensor / Switch Circuit
P0121 Throttle / Pedal Position Sensor / Switch Circuit Range / Performance
P0122 Throttle / Pedal Position Sensor / Switch Circuit Low
P0123 Throttle / Pedal Position Sensor / Switch Circuit High
P0124 Throttle / Pedal Position Sensor / Switch Circuit Intermittent
P0125 Insufficient coolant temperature to close the oil circuit
P0126 Insufficient coolant temperature for operation
P0127 Intake temperature too high.
P0128 Coolant thermostat (coolant temperature is below thermostat temperature)
P0129 Barometric pressure too low
P0130 O2 sensor circuit (bank 1, sensor 1)
P0131 O2 sensor circuit Low voltage (bank 1, sensor 1)
P0132 O2 sensor circuit High voltage (bank 1, sensor 1)
P0133 O2 sensor circuit Slow Response (Bank 1, Sensor 1)
P0134 O2 sensor circuit not working (bank 1, sensor 1)
P0135 O2 sensor heater heater circuit (bank 1, sensor 1)
P0136 O2 sensor circuit (bank 1, sensor 2)
P0137 O2 sensor circuit Low voltage (bank 1 sensor 2)
P0138 O2 sensor circuit High voltage (bank 1 sensor 2)
P0139 O2 sensor circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 sensor circuit not working (bank 1, sensor 2)
P0141 O2 sensor heater heater circuit (bank 1, sensor 2)
P0142 O2 sensor circuit (bank 1, sensor 3)
P0143 O2 sensor circuit Low voltage (bank 1 sensor 3)
P0144 O2 sensor circuit High voltage (bank 1 sensor 3)
P0145 O2 sensor circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 sensor circuit not working (bank 1, sensor 3)
P0147 O2 sensor heater heater circuit (bank 1, sensor 3)
P0148 Fuel Delivery Malfunction
P0149 Fuel timing error
P0150 O2 sensor circuit (bank 2, sensor 1)
P0151 O2 sensor circuit Low voltage (bank 2, sensor 1)
P0152 O2 sensor circuit High voltage voltage (bank 2, sensor 1)
P0153 O2 sensor circuit Slow Response (Bank 2, Sensor 1)
P0154 O2 sensor circuit not working (bank 2, sensor 1)
P0155 O2 sensor heater circuit (bank 2, sensor 1)
P0156 O2 sensor circuit (bank 2, sensor 2)
P0157 O2 sensor circuit Low voltage (bank 2, sensor 2)
P0158 O2 sensor circuit High voltage voltage (bank 2 sensor 2)
P0159 O2 sensor circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 sensor circuit not working (bank 2, sensor 2)
P0161 O2 sensor heater circuit (bank 2, sensor 2)
P0162 O2 sensor circuit (bank 2, sensor 3)
P0163 O2 sensor circuit Low voltage (bank 2, sensor 3)
P0164 O2 sensor circuit High voltage (bank 2 sensor 3)
P0165 O2 sensor circuit Slow response time (bank 2, sensor 3)
P0166 O2 sensor circuit not working (bank 2, sensor 3)
P0167 O2 sensor heater circuit (bank 2, sensor 3)
P0168 Fuel temperature too high
P0169 Incorrect fuel delivery
P0170 Fuel Trim (bank 1)
P0171 System too thin (bank 1)
P0172 System too thick (bank 1)
P0173 Fuel Trim (bank 2)
P0174 System Too Lean (Bank 2)
P0175 System too thick (bank 2)
P0176 Fuel supply sensor circuit
P0177 Fuel supply sensor circuit, range or performance problem
P0178 Fuel supply sensor circuit, low
P0179 Fuel supply sensor circuit, high
P0180 Fuel temperature sensor A circuit
P0181 Fuel Temperature Sensor A Circuit Range / Performance
P0182 Fuel temperature sensor A circuit, low
P0183 Fuel temperature sensor A circuit, high
P0184 Fuel temperature sensor A circuit, intermittent
P0185 Fuel temperature sensor B circuit
P0186 Fuel temperature sensor B circuit, range or performance problem
P0187 Fuel temperature sensor B circuit, low
P0188 Fuel temperature sensor B circuit high
P0189 Fuel temperature sensor B circuit, intermittent
P0190 Oil pressure sensor circuit
P0191 Fuel pressure sensor circuit, range or performance problem
P0192 Fuel Pressure Sensor Circuit Low
P0193 Fuel Pressure Sensor Circuit High
P0194 Fuel pressure sensor circuit, intermittent
1 - 11 of 11 Posts
· Administrator
P001 - P0194
P0201 - P0433
P0434 - P0640
P0846 - P0920
P0921 - P1321
P1322 - P1791
P1792 - P2130
P2131 - P2715
P2716 - U0010
U0011 - U300
U301 - U0327
P0201 Injector Circuit Open - Cylinder 1
P0202 Injector Circuit Open - Cylinder 2
P0203 Injector Circuit Open - Cylinder 3
P0204 Injector Circuit Open - Cylinder 4
P0205 Injector Circuit / Open - Cylinder 5
P0206 Injector Circuit / Open - Cylinder 6
P0207 Injector Circuit / Open - Cylinder 7
P0208 Injector Circuit Open - Cylinder 8
P0209 Injector Circuit Open - Cylinder 9
P0210 Injector Circuit Open - Cylinder 10
P0211 Injector Circuit Open - Cylinder 11
P0212 Injector Circuit Open - Cylinder 12
P0213 Cold start injector 1
P0214 Cold start injector 2
P0215 Engine shut off solenoid
P0216 Injector Timing Control Circuit
P0217 High coolant temperature conditions
P0218 Transmission fluid temperature condition, high
P0219 Engine speed, high
P0220 Throttle / Pedal Position Sensor / Switch Band
P0221 Throttle / Pedal Position Sensor / Switch Band Performance
P0222 Throttle / Pedal Position Sensor / Switch Circuit Low
P0223 Throttle / Pedal Position Sensor / Switch Circuit High
P0224 Throttle / Pedal Position Sensor / Switch Circuit Intermittent
P0225 Throttle / Pedal Position Sensor / Switch Circuit
P0226 Throttle / Pedal Position Sensor / Switch Circuit Range / Performance
P0227 Throttle / Pedal Position Sensor / Switch Circuit Low
P0228 Throttle / Pedal Position Sensor / Switch Circuit High
P0229 Throttle / Pedal Position Sensor / Switch Circuit Intermittent
P0230 Fuel pump pressure circuit low
P0231 Fuel pump secondary circuit, high (low)
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit (Intermittent)
P0234 Turbo / Super Charger Overboost condition
P0235 Turbo / Supercharger Sensor A Circuit
P0236 Turbo / Supercharger Sensor A Circuit Range / Performance
P0237 Turbocharger Sensor A Circuit Low
P0238 Turbocharger Sensor A Circuit High
P0239 Turbocharger Sensor B Circuit
P0240 Turbo / Supercharger Sensor B Circuit Range / Performance
P0241 Turbocharger Sensor B Circuit Low
P0242 Turbocharger Sensor B Circuit High
P0243 Solenoid A Turbocharger
P0244 Turbo / supercharger solenoid, range or performance problem
P0245 Solenoid A Turbo / Super Charger Low
P0246 Turbocharger solenoid A, high
P0247 Solenoid B Turbo / Supercharger
P0248 Turbo / supercharger solenoid B, range or performance problem
P0249 Turbo / supercharged solenoid B low
P0250 Turbo / supercharged solenoid B
P0251 Injection fuel metering control pump "A" (cam / rotor / injector)
P0252 Injector fuel metering control pump, range or performance problem (cam / rotor / injector)
P0253 Injector fuel metering control pump “A” (cam / rotor / injector) low
P0254 Injection fuel metering control pump "A" (cam / rotor / injector) high
P0255 Injection pump fuel metering control "A" (cam / rotor / injector) intermittent
P0256 Injection fuel metering control pump “B” (cam / rotor / injector)
P0257 Injector fuel metering control pump “B”, range or performance problem (cam / rotor / injector)
P0258 Injector fuel metering control pump “B” (cam / rotor / injector) low
P0259 Injection fuel metering control pump “B” (cam / rotor / injector) high
P0260 Injector fuel metering control pump “B” (cam / rotor / injector) intermittent
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 injector circuit, high
P0263 Cylinder 1 Contribution / Balance
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 injector circuit high
P0266 Cylinder 2 Contribution / Balance
P0267 Cylinder 3 injector circuit low
P0268 Cylinder 3 injector circuit high
P0269 Cylinder 3 Contribution / Balance
P0270 Cylinder 4 injector circuit low
P0271 Cylinder 4 injector circuit, high
P0272 Cylinder 4 Contribution / Balance
P0273 Cylinder 5 injector circuit, low
P0274 Cylinder 5 injector circuit, high
P0275 Cylinder 5 Contribution / Balance
P0276 Cylinder 6 injector circuit, low
P0277 Cylinder 6 injector circuit high
P0278 Cylinder 6 Contribution / Balance
P0279 Cylinder injector 7 circuit low
P0280 Cylinder 7 injector circuit high
P0281 Cylinder 7 Contribution / Balance
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 injector circuit, high
P0284 Cylinder 8 Contribution / Balance
P0285 Cylinder injector 9 circuit, low
P0286 Cylinder injector 9 circuit high
P0287 Cylinder 9 Contribution / Balance
P0288 Cylinder injector 10 circuit, low
P0289 Cylinder injector 10 circuit high
P0290 Cylinder 10 Contribution / Balance
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder injector 11 circuit high
P0293 Cylinder 11 Contribution / Balance
P0294 Cylinder injector 12 circuit, low
P0295 Cylinder injector 12 circuit high
P0296 Cylinder 12 Contribution / Balance
P0297 Vehicle speed too high
P0298 Engine oil temperature, high
P0299 Turbo / Supercharge condition Underboost
P0300 Multiple cylinder misfire detonated
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0313 Misfire ignition Low fuel
P0314 One cylinder misfire detected
P0315 Crankshaft position system not variable according to configuration
P0316 Engine malfunction while starting (1000 rpm)
P0317 Off-road device not displayed
P0318 A signal circuit detects a fault road
P0319 Malfunction of road signal B circuit
P0320 Ignition / supply circuit Engine speed
P0321 Ignition / supply circuit, range or performance problem Engine speed
P0322 Ignition / supply circuit Engine speed, no signal
P0323 Ignition / supply circuit Intermittent engine speed
P0324 Knock Control System Malfunction
P0325 Knock sensor 1 circuit (bank 1 or sensor signal)
P0326 Knock sensor 1 circuit, range or performance problem (bank 1 or sensor signal)
P0327 Knock sensor 1 circuit, low (bank 1 or sensor signal)
P0328 Knock sensor 1 circuit, high (bank 1 or sensor signal)
P0329 Knock sensor 1 circuit (bank 1 or sensor signal), intermittent
P0330 Knock sensor 2 circuit (bank 2)
P0331 Knock sensor 2 circuit, range or performance problem (bank 2)
P0332 Knock sensor 2 circuit (bank 2), low
P0333 Knock sensor 2 circuit (bank 2), high
P0334 Knock sensor 2 circuit (bank 2), intermittent
P0335 Crankshaft Position Sensor "A" Circuit
P0336 Crankshaft Position Sensor "A" Circuit Range / Performance
P0337 Crankshaft Position Sensor "A" Circuit Low
P0338 Crankshaft Position Sensor "A" Circuit High
P0339 Crankshaft Position Sensor "A" Circuit Intermittent
P0340 Camshaft Position Sensor “A” Circuit (Bank 1 or Sensor Signal)
P0341 Camshaft position sensor “A”, range or performance problem (bank 1 or sensor signal)
P0342 Camshaft Position Sensor “A” Circuit Low (Bank 1 or Sensor Signal)
P0343 Camshaft Position Sensor “A” Circuit High (Bank 1 or Sensor Signal)
P0344 Crankshaft Position Sensor "A" Circuit Intermittent (Bank 1 or Sensor Signal)
P0345 Camshaft Position Sensor `` A '' Circuit (Bank 2)
P0346 Camshaft Position Sensor “A” Circuit Range / Performance (bank 2)
P0347 Camshaft position sensor “A” circuit, low (bank 2)
P0348 Camshaft position sensor “A” circuit high (bank 2)
P0349 Camshaft Position Sensor “A” Circuit Intermittent (Bank 2)
P0350 Ignition Coil Primary / Secondary Circuit
P0351 Ignition Coil Primary / Secondary Circuit
P0352 Ignition Coil Primary / Secondary Circuit
P0353 Ignition Coil “C” Primary / Secondary Circuit
P0354 Ignition Coil 'D' Primary / Secondary Circuit
P0355 Ignition Coil Primary / Secondary Circuit
P0356 Ignition Coil “F” Primary / Secondary Circuit
P0357 Ignition Coil Secondary / Secondary “G” Circuit
P0358 Ignition Coil “H” Primary / Secondary Circuit
P0359 Ignition Coil “I” Primary / Secondary Circuit
P0360 Ignition Coil Primary / Secondary Circuit 'J'
P0361 Ignition Coil “K” Primary / Secondary Circuit
P0362 Ignition Coil 'L' Primary / Secondary Circuit
P0363 Misfire ignition - Incomplete fuel system
P0364 spare.
P0365 Camshaft Position Sensor “B” Circuit (Bank 1)
P0366 Camshaft Position Sensor “B” Circuit Range / Performance (bank 1)
P0367 Camshaft Position Sensor “B” Circuit Low (Bank 1)
P0368 Camshaft position sensor “B” circuit high (bank 1)
P0369 Camshaft Position Sensor “B” Circuit Intermittent (Bank 1)
P0370 Timing reference high resolution signal "A"
P0371 Timing reference high resolution signal “A” has stopped consecutively.
P0372 High RPM Reference Signal “A” intermittent pulsation
P0373 Timing reference high resolution signal “A” intermittent.
P0374 Timing reference high resolution signal "A" no pulse signal.
P0375 Timing reference high resolution signal "B"
P0376 Timing reference high resolution signal “B” has stopped for a long time.
P0377 High RPM Reference Signal “B” intermittent pulsation
P0378 Hi-Speed Timing Reference Signal “B” Intermittent
P0379 Timing reference high resolution signal “B” no pulse signal.
P0380 Glow plug heater "A" circuit
P0381 Glow plug heater circuit A
P0382 Glow plug preheating circuit "B"
P0385 Crankshaft Position Sensor "B" Circuit
P0386 Crankshaft Position Sensor "B" Circuit Range / Performance
P0387 Crankshaft Position Sensor "B" Circuit Low
P0388 Crankshaft Position Sensor "B" Circuit High
P0389 Crankshaft Position Sensor "B" Circuit Intermittent
P0390 Crankshaft Position Sensor "B" Circuit (Bank 2)
P0391 Crankshaft position sensor "B" circuit, range or performance problem (bank 2)
P0392 Crankshaft position sensor "B" circuit low (bank 2)
P0393 Crankshaft position sensor "B" (bank 2) circuit high
P0394 Crankshaft Position Sensor "B" (Bank 2) Circuit Intermittent
P0400 Exhaust gas recirculation
P0401 Insufficient exhaust gas recirculation
P0402 Exhaust gas loop flow overload
P0403 Exhaust gas flow control circuit
P0404 Exhaust gas recirculation control circuit, range or performance problem
P0405 Exhaust gas recirculation sensor "A" circuit low
P0406 Exhaust gas recirculation sensor "A" circuit high
P0407 Exhaust gas recirculation sensor "B" circuit low
P0408 Exhaust gas recirculation sensor "B" circuit high
P0409 Exhaust gas recirculation sensor "A" circuit
P0410 Secondary air injection system
P0411 Secondary Air Injection System Incorrect Flow
P0412 Secondary Injection System Switch Valve "A" Circuit
P0413 Secondary air injection system switch valve "A" circuit open
P0414 High pressure injection system switch valve "A" circuit shorted
P0415 Secondary Injection System Switch Valve "B"
P0416 Secondary air injection system switch valve "B" circuit open
P0417 High pressure injection system switch valve "B" circuit shorted
P0418 Secondary Air Injection System Control Circuit "A"
P0419 Secondary air injection system control circuit "B"
P0420 Catalog system is lower than entrance (bank 1)
P0421 Catalyst preheating efficiency below entrance (bank 1)
P0422 Main catalytic performance below entrance (bank 1)
P0423 Catalyst heat lower than entrance (bank 1)
P0424 Catalyst heating temperature below entrance (bank 1)
P0425 Catalyst temperature sensor (bank 1)
P0426 Catalyst temperature sensor, range or performance problem (bank 1)
P0427 Catalyst temperature sensor, low (bank 1)
P0428 Catalyst temperature sensor, high (bank 1)
P0429 Catalyst Heater Control Circuit
P0430 Catalyst system performance below threshold (bank 2)
P0431 Warm-up performance below Catalyst threshold (bank 2)
P0432 Primary Catalyst Performance Below Threshold (Bank 2)
P0433 Accelerated performance is below threshold (bank 2)
· Administrator
P001 - P0194
P0201 - P0433
P0434 - P0640
P0846 - P0920
P0921 - P1321
P1322 - P1791
P1792 - P2130
P2131 - P2715
P2716 - U0010
U0011 - U300
U301 - U0327
P0434 Thermal catalyst temperature below threshold (tank 2)
P0435 Catalyst temperature sensor (bank 2)
P0436 Catalyst temperature sensor range / display (bank 2)
P0437 Catalyst temperature sensor, low (bank 2)
P0438 Catalyst temperature sensor, high (bank 2)
P0439 Catalyst Heater Control Circuit
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge
P0442 Evaporative Emission System Leakage (Small leak) detected
P0443 Evaporative Emission System Purge Control Valve Circuit
P0444 Evaporative Emission System Purge Control Valve Circuit Open
P0445 Evaporative Emission System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Vent Control System Circuit Malfunction
P0447 Evaporative Emission Ventilation System Control Circuit Open
P0448 Evaporative emission control system, shorted release control circuit
P0449 Evaporative emission control system, vent valve / solenoid circuit malfunction
P0450 Evaporative pressure control system, exhaust pressure sensor
P0451 Evaporative emission control system, pressure sensor range / performance
P0452 Evaporative emission control system, pressure sensor low input
P0453 Evaporative emission control system, pressure sensor high input
P0454 Evaporative Emission System Pressure Sensor Intermittent
P0455 Evaporative Emission System Leak Detected (Gross Leak)
P0456 Evaporative Emission System Leak Detected
P0457 Evaporative Emission Control System Leak Detected
P0458 Evaporative Emission System Emission Control Valve Circuit Low
P0459 Evaporative Emission System Purge Control Valve Circuit High
P0460 Fuel level sensor circuit malfunction
P0461 Fuel level sensor circuit, range / performance
P0462 Fuel level sensor circuit, low input
P0463 Fuel level sensor circuit high input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge flow sensor circuit malfunction
P0466 Purge flow sensor circuit range / performance
P0467 Purge flow sensor circuit, low input
P0468 Purge flow sensor circuit, high input
P0469 Purge Speed Sensor Circuit Continuous
P0470 Exhausted, pressure sensor malfunction.
P0471 Exhaust pressure sensor range / performance
P0472 Exhaust pressure sensor low
P0473 Exhaust pressure sensor, high
P0474 Exhaust pressure sensor, high
P0475 Exhaust pressure control valve malfunction
P0476 Exhaust Pressure Control Valve Range / Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Control Valve High Pressure
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling fan control circuit malfunction
P0481 Cooling fan control circuit malfunction 2
P0482 Cooling fan 3 control circuit malfunction
P0483 Fan cause malfunction, check cooling.
P0484 Cooling fan circuit, over current
P0485 Cooling fan power / floor circuit malfunction
P0486 Exhaust gas recirculation sensor "B" circuit
P0487 Throttle position control loop and exhaust gas
P0488 Exhaust Gas Recirculation Throttle Position Control Range / Performance
P0489 Exhaust gas recirculation control circuit low
P0490 Exhaust gas recirculation control circuit, high
P0491 High pressure air injection system (tank 1)
P0492 High pressure air injection system (tank 2)
P0493 Fan speed too high
P0494 Fan speed, low
P0495 Fan speed high
P0496 Evaporative Emission System, high flow
P0497 Evaporative Emission System, low emissions
P0498 Evaporative Emission System Vent Valve Control Circuit Low
P0499 Evaporative emission system vent valve control circuit high
P0500 Vehicle Speed Sensor "A"
P0501 Vehicle speed sensor "A", range or performance problem
P0502 Vehicle speed sensor "A" circuit low
P0503 Vehicle speed chain “A” intermittent / high
P0504 Brake Switch "A" Correlation
P0505 Idle Air Control System
P0506 Idle air control system, rev lower than lack
P0507 Idle air control system, rev higher than lack
P0508 Idle Air Control System Circuit Low
P0509 Idle Air Control System Circuit High
P0510 Throttle Low Switch Off
P0511 Idle Air Control Circuit
P0512 Starter circuit
P0513
P0514 Battery temperature sensor circuit, range or performance problem
P0515 Battery temperature sensor circuit
P0516 Battery temperature sensor circuit, low
P0517 Battery temperature sensor circuit high
P0518 Battery temperature sensor circuit, intermittent
P0519 Idle Air Control System Range / Performance
P0520 Engine Oil Pressure Sensor / Switch Circuit
P0521 Engine Oil Pressure Sensor / Switch Range / Performance
P0522 Engine oil pressure sensor / switch low
P0523 Engine oil pressure sensor / switch high
P0524 Engine oil pressure too low
P0525 Speed Control Circuit Range / Performance
P0526 Fan speed sensor circuit
P0527 Fan speed sensor circuit, range or performance problem
P0528 Fan speed sensor circuit, no signal
P0529 Fan Speed Sensor Circuit Intermittent
P0530 Turbine pressure sensor "A" circuit
P0531 Pressure sensor "A", range or performance problem
P0532 Pressure compressor sensor "A" circuit low
P0533 Pressure sensor A / C compressor circuit high
P0534 charging system loss
P0535 Air compressor temperature sensor circuit
P0536 Air compressor temperature sensor circuit, range or performance problem
P0537 Air compressor temperature sensor circuit low
P0538 Air compressor temperature sensor circuit high
P0539 Air compressor temperature sensor circuit, intermittent
P0540 Intake heater circuit "A"
P0541 Intake heater "A" circuit low
P0542 Intake heater "A" circuit high
P0543 Intake heater "A" circuit open
P0544 Exhaust gas temperature sensor circuit (bank 1, sensor 1)
P0545 Exhaust gas temperature sensor circuit low (bank 1, sensor 1)
P0546 Exhaust gas temperature sensor circuit high (bank 1, sensor 1)
P0547 Exhaust gas temperature sensor circuit (bank 2 sensor 1)
P0548 Exhaust gas temperature sensor circuit low (bank 2 sensor 1)
P0549 Exhaust gas temperature sensor (bank 2 sensor 1) circuit high
P0550 Power Steering Pressure Sensor / Switch Circuit
P0551 Power Steering Pressure Sensor / Switch Circuit Range / Performance
P0552 Power steering pressure sensor / switch circuit low
P0553 Power steering pressure sensor / switch circuit high
P0554 Power Steering Pressure Sensor / Switch Circuit Intermittent
P0555 Brake pressure sensor circuit
P0556 Pressure sensor circuit, range or performance problem
P0557 Brake Pressure Sensor Circuit Low
P0558 Brake pressure sensor circuit high
P0559 Brake Pressure Sensor Circuit Intermittent
P0560 Voltage system
P0561 System voltage unstable
P0562 System voltage low
P0563 System voltage high
P0564 Speed control circuit
P0565 Cruise control signal open
P0566 Off speed control signal
P0567 Speed control signal on / off
P0568 Adaptive speed control signal
P0567 Continuous speed control sensor
P0569 Continuous speed control signal
P0570 Acceleration control signal
P0571 Brake Switch "A" Circuit
P0572 Brake switch "A" loop, low
P0573 Brake switch "A" loop high
P0574 Cruise control system - vehicle speed too high
P0575 Speed system ignition circuit
P0576 Low speed system ignition circuit
P0577 High speed system ignition circuit
P0578 Speed control system "A" power supply circuit
P0579 Cruise control system "A" circuit, range or performance problem
P0580 Speed control system "A" circuit low
P0581 Speed control system “A” circuit high
P0582 Cruise control circuit, open
P0583 Speed control circuit, low
P0584 High speed control circuit
P0585 "A / B" speed control system power supply circuit, correlated
P0586 Speed control circuit open
P0587 Speed control circuit, low
P0588 Speed control circuit, high
P0589 Speed control system “B” ignition circuit
P0590 Speed Control System "B" Stuck Circuit
P0591 Speed control system "B" ignition circuit, range or performance
P0592 Fast air intake control system “B” circuit low
P0593 Fast air intake control system "B" circuit high
P0594 Cruise control circuit, open
P0595 Speed control control circuit, low
P0596 Speed control control circuit, high
P0597 Thermostat Heater Control Circuit / Open
P0598 Thermostat Heater Control Circuit Low
P0599 Thermostat Heater Control Circuit High
P0600 communication interface
P0601 check internal control memory defective
P0602 Department of control module defect
P0603 Internal live memory control module defective (KAM = keep alive memory).
P0604 Internal read memory control module defective (rom = Read Rom Only Memory)
P0605 Internal memory module read control defective (ROM = Random acccs memory)
P0606 ECM (Engine / Elcclronic control module) PCM (Powertrain controlled moduule)
P0607 Control Module Range / Performance Vehicle speed sensor vss (vehicle speed sensor) Output “A”
P0608 Control Module Sensor Vehicle Speed VSS (Vehicle Speed Sensor) OutPut "A"
P0609 Control Module Sensor Vehicle Speed VSS OutPut "B"
P0610 Control module, vehicle fault
P0611 Fuel injector control module, range or performance problem
P0612 Fuel Injector Control Module Relay Control
P0613 Greer System Control Module
P0614 Engine / Electronic / Transmission Control Module Incomplete
P0615 Starter Relay Circuit
P0616 Starter relay circuit low
P0617 Starter relay circuit high
P0618 Read memory module fault
P0619 RAM / ROM oil control module (ram = Rnadam memory) defective
P0620 Generator Control Circuit
P0621 Generator Left Lamp Right Circuit
P0622 Generator field terminal circuit
P0623 Generator lamp terminal circuit
P0624 Fuel cap lamp control circuit
P0625 Generator field terminal circuit low
P0626 Generator field terminal circuit high
P0627 Fuel pump control circuit "A" open
P0628 Fuel pump control circuit "A" low
P0629 Fuel pump control circuit "A" high
P0630 ECM / PCM incomplete vin not programmcd
P0631 Incomplete Control Module (TCM) vin not programmcd
P0632 Incomplete Engine / Electronic Control Module Odemcter Not Prograammed
P0633 Engine / Electronic Control Module Incomplete Immobillizer Not Programmed
P0634 PCM / ECM / TCM Engine / Electronic Control Module Temperature Too High
P0635 Power steering control circuit
P0636 Power steering control circuit low
P0637 Power steering control circuit high
P0638 Throttle control range / performance function (tank 1)
P0639 Throttle control function, range 2, range or performance problem
P0640 Intake Heater Control Circuit
· Administrator
P001 - P0194
P0201 - P0433
P0434 - P0640
P0846 - P0920
P0921 - P1321
P1322 - P1791
P1792 - P2130
P2131 - P2715
P2716 - U0010
U0011 - U300
U301 - U0327
P0846 Transmission Fluid Pressure Sensor / Switch "B" Circuit Range / Performance
P0847 Transmission Fluid Pressure Sensor / Switch “B” Circuit Low
P0848 Transmission Fluid Pressure Sensor / Switch “B” Circuit High
P0849 Transmission Fluid Pressure Sensor / Switch "B" Circuit Intermittent oil
P0850 Central Park (Noutral) Switch Input Circuit
P0851 Middle (Noutral) Switch Input Circuit, Low
P0852 Middle (Noutral) Switch Input Circuit, High
P0853 Drive position switch input circuit
P0854, low drive position switch input circuit
P0855 Drive switch input circuit, high
P0856 Power signal entering the wing
P0857 Control wing signal, performance
P0858 Low wing control signal
P0859 A high signal to control the wing
P0860 Gcar Shift Module Communication Circuit
P0861 Gcar Shift Module Communication Circuit Low
P0862 Gcar Shift Module Communication Circuit High
P0863 Module and Transmission Communication Circuit
P0864 TCM Transmission Control Module Communication Circuit Range / Performance
P0865 TCM Transmission Control Module Communication Circuit Low Range / Performance
P0866 TCM Transmission Control Module Communication Circuit High
P0867 Transmission fluid pressure
P0868 Transmission oil pressure low
P0869 Transmission fluid pressure high
P0870 Transmission Fluid Pressure Sensor / Switch "C" Circuit
P0871 Transmission Fluid Pressure Sensor / Switch “C” Circuit Range / Performance
P0872 Transmission Fluid Pressure Sensor / Switch “C” Circuit Low
P0873 Transmission Fluid Pressure Sensor / Switch “C” Circuit High
P0874 Transmission Fluid Pressure Sensor / Switch "C" Circuit Intermittent
P0875 Transmission Fluid Pressure Sensor / Switch “D” Circuit
P0876 Transmission Fluid Pressure Sensor / Switch “D” Circuit Range / Performance
P0877 Transmission Fluid Pressure Sensor / Switch “D” Circuit Low
P0878 Transmission Fluid Pressure Sensor / Switch “D” Circuit High
P0879 Transmission Fluid Pressure Sensor / Switch “D” Circuit Intermittent
P0880 Transmission control module power input signal
P0881 Transmission control module input power, range or performance
P0882 Transmission control module power input signal high
P0883 Transmission control module power input signal low
P0884 Transmission control module power input signal intermittent
P0885 Transmission control module power relay - circuit open
P0886 Transmission control module power relay circuit low P0641 Power reference sensor circuit, open "A"
P0642 Power reference sensor circuit, low "A"
P0643 Reference voltage sensor circuit high "A"
P0644 Driver communication circuit
P0645 A / C clutch relay control circuit
P0646 A / C clutch relay control circuit low
P0647 A / C clutch relay control circuit high
P0648 Immobillizer lamp control circuit
P0649 Speed control lamp control circuit
P0650 Lamp control circuit (mil)
P0651 Power reference sensor circuit, open
P0652 Power reference sensor circuit, low
P0653 Reference voltage sensor circuit high "B"
P0654 Engine RPM Speed Control Circuit
P0655 Engine heater lamp control circuit
P0656 Fuel level circuit
P0657 Supply voltage supply circuit, open
P0658 Supply voltage circuit, low
P0659 Supply voltage, circuit high
P0660 Intake manifold valve control loop (tank 1) open
P0661 Intake manifold valve control loop (tank 1) low
P0662 Intake manifold valve control loop (tank 1) high
P0663 Intake manifold valve control loop (tank 2) open
P0664 Intake manifold valve control loop (tank 2) low
P0665 Intake manifold valve control loop (tank 2) high
P0666 PCM / ECM / TCM Internal Temperature Sensor Circuit
P0667 PCM / ECM / TCM Internal Temperature Sensor Circuit Range / Performance
P0668 PCM / ECM / TCM Internal Temperature Sensor Circuit Low
P0669 PCM / ECM / TCM Internal Temperature Sensor Circuit High
P0670 Glow Plug Module Control Circuit
P0671 Cylinder 1 Glow Plug Circuit
P0672 Cylinder 2 Glow Plug Circuit
P0673 Cylinder 3 Glow Plug Circuit
P0674 Cylinder 4 Glow Plug Circuit
P0675 Cylinder 5 Glow Plug Circuit
P0676 Cylinder 6 Glow Plug Circuit
P0677 Cylinder 7 Glow Plug Circuit
P0678 Cylinder 8 Glow Plug Circuit
P0683 Glow Plug Control Module to PCM Communication Circuit
P0684 Glow Plug Control Module to PCM Communication Circuit Range / Performance
P0685 ECM / PCM Relay Control Circuit / Open
P0686 ECM / PCM Relay Control Circuit Low
P0687 ECM / PCM Relay Control Circuit High
P0688 ECM / PCM Power Relay Circuit / Open
P0689 ECM / PCM Relay Circuit Low
P0690 ECM / PCM Relay Signal Circuit High
P0691 Fan 1 Control Circuit Low
P0692 Fan 1 control circuit, high
P0693 Fan 2 Control Circuit Low
P0694 Fan 2 control circuit, high
P0695 Fan 3 Control Circuit Low
P0696 Fan 3 control circuit, high
P0697 Movement reference sensor, lamp “C” open.
P0698 Power Reference Sensor "C" Low
P0699 Transmission reference sensor "C" high
P0700 Transmission Control System
P0701, power relay (transmission) range, performance
P0702 Transmission control electric system (transmission)
P0703 Brake switch "B" circuit
P0704 Clutch Switch Circuit
P0705 Power Relay (Transmission) Sensor Circuit
P0706 Transmission sensor circuit, range or performance problem
P0707 Power Relay (Transmission) Sensor Circuit Low
P0708 Power Relay (Transmission) Sensor Circuit High
P0709 Power Relay (Transmission) Sensor Circuit Intermittent
P0710 Transmission fluid temperature sensor circuit
P0711 Transmission fluid temperature sensor circuit, range or performance problem
P0712 Transmission fluid temperature sensor circuit low
P0713 Transmission fluid temperature sensor circuit high
P0714 Transmission fluid temperature sensor circuit intermittent
P0715 Turbine speed sensor circuit
P0716 Turbine speed sensor, range or performance problem
P0717 Turbine speed sensor circuit, no signal
P0718 Turbine Speed Sensor Circuit Intermittent
P0719 Switchbake "B" circuit, low
P0720 Speed sensor circuit
P0721 Speed sensor circuit, range or performance problem
P0722 Speed sensor circuit, no signal
P0723 Speed Sensor Circuit Intermittent
P0724 Brake switch "B" circuit, high
P0725 Vehicle speed sensor circuit
P0726 Vehicle speed sensor circuit, range or performance problem
P0727 Vehicle speed sensor circuit, no signal
P0728 Engine Speed Sensor Circuit Intermittent
P0729 Incorrect 6th gear ratio
P0730 Incorrect gear ratio
P0731 Incorrect gear ratio 1
P0732 Incorrect 2nd gear ratio
P0733 Incorrect 3rd gear ratio
P0734 Incorrect 4th gear ratio
P0735 Incorrect 5th gear ratio
P0736 Incorrect 6th gear ratio
P0737 TCM Engine Speed Output Circuit
P0738 TCM Vehicle Speed Transmission Control Module Circuit Low
P0739 TCM Vehicle Speed Transmission Control Module Circuit High
P0740 TCM Engine Speed Output Circuit Open
P0741 Torque converter clutch circuit
P0742 Torque converter clutch circuit, open
P0743 Torque converter clutch circuit
P0744 Throttle converter clutch circuit, intermittent
P0745 Pressure control solenoid "A"
P0746 Pressure solenoid “A” control range, performance or off
P0747 Solenoid “A” control range, performance problem open
P0748 Pressure control solenoid "A"
P0749 Pressure control, sonoid "A" intermittent.
P0750 Shift solenoid "A"
P0751 Shift solenoid “A” or off
P0752 Shift solenoid “A” open
P0753 Electric Throttle (Shift) Solenoid "A"
P0754 Shift solenoid “A” intermittent
P0755 Shift solenoid "B"
P0756 Shift solenoid “B”, performance or short circuit
P0757 Shift solenoid “B” open
P0758 Electric Shift (Shift) Solenoid “B”
P0759 Shift solenoid “B” intermittent
P0760 Shift solenoid "C"
P0761 Shift solenoid “C”, range or performance problem closed
P0762 Shift solenoid “C”, performance problem open
P0763 Electric Shift (Shift) Solenoid C
P0764 Shift solenoid “C” intermittent
P0765 Shift solenoid "B"
P0766 Shift solenoid “D”, performance or problem open
P0767 Shift solenoid “D” open
P0768 Electric Shift (Shift) Solenoid “D”
P0769 Shift solenoid, intermittent
P0770 Shift solenoid "E"
P0771 Shift solenoid “E”, performance or shortened
P0772 Shift solenoid “E” open
P0773 Electric Shift (Shift) Solenoid "E"
P0774 Shift solenoid “E” intermittent
P0775 Pressure control solenoid "B"
P0776 Pressure solenoid “B” control range or performance problem closed
P0777 Pressure control solenoid “B” open.
P0778 Pressure Control Solenoid "B" Electrical
P0779 Pressure control solenoid “B” intermittent
P0780 Shift malfunction
P0781 1-2 (Shift)
P0782 2-3 (Shift)
P0783 3-4 (Shift)
P0784 4-5 (Shift)
P0785 Shift / Timing Solenoid
P0786 Shift / Timing Solenoid Performance
P0787 Shift / Timing Solenoid Low
P0788 Shift / Timing Solenoid, High
P0789 Shift / Timing Solenoid Intermittent
P0790 Switch circuit, normal operation
P0791 Intermediate Shaft Speed Sensor "A" Circuit
P0792 Central Speed Sensor "A" Range / Performance
P0793 Intermediate Shaft Speed Sensor "A" Circuit No Signal
P0794 Intermediate Shaft Speed Sensor "A" Circuit Intermittent
P0795 Pressure Control Solenoid "C"
P0796 Solenoid “C” control, performance or open
P0797 Pressure control solenoid “C” open.
P0798 Control Solenoid "C" Electrical
P0799 Pressure Control Solenoid “C” Intermittent
P0800 Transfer Cascade Control System
P0801 Control loop suspend no reverse
P0802 Transmission Control System (Transmission) Circuit Open
P0803 1-4 upshifl solenoid control circuit (Skip Shift)
P0804 1-4 upshifl lamp circuit (Skip Shift)
P0805 Clutch position sensor circuit
P0806 Clutch position sensor circuit, range or performance problem
P0807 Clutch Position Sensor Circuit Low
P0808 Clutch Position Sensor Circuit High
P0809 Clutch position sensor circuit, intermittent
P0810 Clutch Position Sensor Circuit Malfunction
P0811 Clutch too slippery
P0812 Reverse power supply circuit
P0813 Reverse power output circuit
P0814 Relay, power (gear) relay
P0815 UpShift Switch Circuit
P0816 Down Shift Switch Circuit
P0817 Star circuit not working
P0818 Power Switch Input Circuit
P0819 Up and Down Shift Relationship Switch to Power Relay (Gear)
P0820 Sensor circuit to XY gear lever
P0821 Gear lever position circuit x
P0822 Gear lever y position circuit
P0823 Gear lever position x circuit intermittent
P0824 Gear lever y position circuit intermittent
P0825 Gear Lever Lever Switch - Torsion
P0826 Up and Down Shift Switch Circuit
P0827 Up and Down Shift Switch Circuit Low
P0828 Up and Down Shift Switch Circuit High
P0829 5-6 Shift
P0830 Clutch Pedal Switch "A" Circuit
P0831 Clutch pedal switch "A" circuit low
P0832 Clutch pedal switch "A" circuit high
P0833 Clutch Pedal Switch "B" Circuit
P0834 Clutch pedal switch "B" circuit low
P0835 Clutch pedal switch "B" circuit high
P0836 4WD Switch Circuit
P0837 4WD Switch Circuit Range / Performance
P0838 4WD Switch Circuit Low
P0839 4WD Switch Circuit High
P0840 Transmission Fluid Pressure Sensor / Switch “A” Circuit
P0841 Transmission Fluid Pressure Sensor / Switch "A" Circuit Range / Performance
P0842 Transmission Fluid Pressure Sensor / Switch “A” Circuit Low
P0843 Transmission Fluid Pressure Sensor / Switch “A” Circuit High
P0844 Transmission Fluid Pressure Sensor / Switch "A" Circuit Intermittent
P0845 Transmission Fluid Pressure Sensor / Switch "B" Circuit
P0887 Transmission control module power relay circuit high
P0888 Transmission control module power relay control circuit open
P0889 Transmission control module power relay control circuit
P0890 Transmission Control Module Power Relay Circuit Range / Performance
P0891 Transmission control module power relay circuit low
P0892 Transmission control module power relay circuit high
P0893 Transmission control module power relay circuit
P0894 Transmission parts slip
P0895 Shift timing too short
P0896 Shift duration too long
P0897 Transmission fluid quality deteriorated
P0898 Transmission system circuit low
P0899 Transmission system circuit high
P0900 Clutch actuation circuit, open
P0901 Clutch Actuator Circuit Range / Performance
P0902 Clutch Actuator Circuit Low
P0903 Clutch actuation circuit high
P0904 Door select position circuit
P0905 Door open selection position circuit
P0906 Door select position circuit, low
P0907 Door select position circuit high
P0908 Door selection position circuit intermittent
P0909 Door open selection position control error
P0910 Power selection circuit, activated when door is open
P0911 Gate selection circuit, range or performance problem
P0912 Gate selection circuit, range or performance problem
P0913 Door selection circuit, running low
P0914 Operating gate selection circuit high
P0915 Gear Shifl Position Circuit Range / Performance
P0916 Gear Shifl Position Circuit Low
P0917 Gear Shifl Position Circuit High
P0918 Gear Shifl Position Circuit Intermittent
P0919 Gear Shifl Position Circuit Malfunction
P0920 Forward gear circuit, open
· Administrator
P001 - P0194
P0201 - P0433
P0434 - P0640
P0846 - P0920
P0921 - P1321
P1322 - P1791
P1792 - P2130
P2131 - P2715
P2716 - U0010
U0011 - U300
U301 - U0327
P0921 Gear Forward Circuit Range / Performance
P0922 Forward gear circuit low
P0923 Forward gear circuit high
P0924 Walk Behind Gear Circuit Open
P0925 Reverse gear circuit, range or performance problem
P0926 Reverse gear circuit low
P0927 Reverse gear circuit high
P0928 Transmission lock solenoid control circuit open
P0929 Transmission lock solenoid control circuit, range or performance problem
P0930 Transmission lock solenoid control circuit low
P0931 Transmission lock solenoid control circuit high
P0932 Hydraulic Pressure Sensor Circuit
P0933 Hydraulic Pressure Sensor Circuit Range / Performance
P0934 Hydraulic Pressure Sensor Circuit Low
P0935 Hydraulic Pressure Sensor Circuit High
P0936 Hydraulic pressure sensor circuit, intermittent
P0937 Hydraulic Temperature Sensor Circuit
P0938 Hydraulic Temperature Sensor Circuit Range / Performance
P0939 Hydraulic Temperature Sensor Circuit Low
P0940 Hydraulic Temperature Sensor Circuit High
P0941 Hydraulic Temperature Sensor Circuit Intermittent
P0942 Hydraulic pressure unit
P0943 Hydraulic Pressure Unit Recirculation Range
P0944 Hydraulic pressure block loss of pressure
P0945 Hydraulic Pump Relay Circuit / Open
P0946 Hydraulic Pump Relay Circuit Range / Performance
P0947 Hydraulic Pump Relay Circuit Low
P0948 Hydraulic Pump Relay Circuit High
P0949 AuTo Shift Manual Incomplete
P0950 AuTo Shift Manual Control Circuit
P0951 AuTo Shift Manual Control Circuit Range / Performance
P0952 AuTo Shift Manual Control Circuit Low
P0953 AuTo Shift Manual Control Circuit High
P0954 AuTo Shift Manual Control Circuit Intermittent
P0955 AuTo Shift Manual Mode Circuit
P0956 AuTo Shift Manual Mode Circuit Range / Performance
P0957 AuTo Shift Manual Mode Circuit Low
P0958 AuTo Shift Manual Mode Circuit High
P0959 AuTo Shift Manual Mode Circuit Intermittent
P0960 "A" Solenoid Control Circuit Control, push, open
P0961 "A" Solenoid Control Circuit Low pressure control
P0962 "A" Solenoid Control Circuit High pressure control
P0963 "A" Solenoid Control Circuit Control, push, open
P0964 "B" Solenoid Control Circuit Control, push, open
P0965 Solenoid "B" Control Circuit Range / Performance Control
P0966 "B" Solenoid Control Circuit Low pressure control
P0967 "B" solenoid control circuit High pressure control
P0968 "C" solenoid control circuit Control, push, open
P0969 "C" solenoid control circuit, range or performance problem Control
P0970 "C" Solenoid Control Circuit Low pressure control
P0971 "C" Solenoid Control Circuit High pressure control
P0972 Control Circuit Range / Performance Shift solenoid "A"
P0973 Control Circuit Range / Performance Low shift solenoid "A"
P0974 Control Circuit Range / Performance High shift solenoid "A"
P0975 Control Circuit Range / Performance Shift solenoid "B"
P0976 Control Circuit Range / Performance Low shift solenoid “B”
P0977 Control Circuit Range / Performance High shift solenoid "B"
P0978 Control Circuit Range / Performance Shift solenoid "C"
P0979 Control Circuit Range / Performance Low shift solenoid "C"
P0980 Control Circuit Range / Performance High shift solenoid "C"
P0981 Control Circuit Range / Performance Shift solenoid "D"
P0982 Control Circuit Range / Performance Low shift solenoid "D"
P0983 Control Circuit Range / Performance High shift solenoid "D"
P0984 Control Circuit Range / Performance Shift solenoid "E"
P0985 Control Circuit Range / Performance Low shift solenoid "E"
P0986 Control circuit range / performance problem High shift solenoid "E"
P0987 Transmission Fluid Pressure Sensor / Switch "E" Circuit
P0988 Transmission Fluid Pressure Sensor / Switch "E" Circuit Range / Performance
P0989 Transmission Fluid Pressure Sensor / Switch "E" Circuit Low
P0990 Transmission Fluid Pressure Sensor / Switch "E" Circuit High
P0991 Transmission Fluid Pressure Sensor / Switch "E" Circuit Intermittent
P0992 Transmission Fluid Pressure Sensor / Switch "F" Circuit
P0993 Transmission Fluid Pressure Sensor / Switch "F" Circuit Range / Performance
P0994 Transmission Fluid Pressure Sensor / Switch "F" Circuit Low
P0995 Transmission Fluid Pressure Sensor / Switch "F" Circuit High
P0996 Transmission Fluid Pressure Sensor / Switch "F" Circuit Intermittent
P0997 Control Circuit Range / Performance Shift solenoid "F"
P0998 Shift solenoid “F” control circuit low
P1013 Heated Sensor You need to check the current BANK control, water heater circuit 1 and 2 Sensor 1.
P1032 Oxygen Sensor Heater Speed Sensor Warm up BANK Control circuit 1 and 2 Sensor 1
P1101 Actual air flow measured from MAF through EGR and TP not in the range of expected airflow.
P1105 Secondary Vacuum Sensor Circuit
P1106 Intake Manifold Pressure (MAP) Intake Pressure Sensor Circuit Intermittent High Pressure
P1107 Intake manifold pressure (MAP) sensor circuit intermittently low voltage sensing
P1108 BaRo Compare Sensor Too High
P1109 Throttle Reserve System Ports
P1111 Climate (iat) Intake Sensor Circuit Intermittent High Pressure
P1112 Climate Temperature (iat) Sensor Circuit Intermittent Low Voltage
P1113 Switching Resonance Volume Solenoid Control Circuit
P1114 Engine Coolant Temperature (ECT) Thermostat Sensor Circuit Low Voltage Intermittent
P1115 Engine Coolant Temperature (ECT) Pressure Sensor Circuit Intermittent High
P1116 ECT Unstable or Intermittent Signal
P1117 Intermittent Engine Cooled, Minimum Qut-Of-Range Output
P1118 Transient Cooling Engine Qut-Of-Range Output High
P1119 ECT Qut-of-Range Signal With TFT Sensor Display
P1120 Low Throttle Sensor (TP) Circuit 1 Circuit
P1121 Throttle Position (TP) Sensor Circuit High Voltage Intermittent
P1122 Throttle Position Sensor (TP) Circuit Low Voltage Intermittent
P1125 Throttle (APP) System Position
P1130 Heated Oxygen Sensor (HO2S) Minimum Perforation 1 Sensor circuit 1
P1131 Heated Oxygen Sensor (HO2S) Minimum Perforation 1 Sensor circuit 2
P1132 Heated Oxygen Sensor (HO2S) Circuit Low Pulsation 2 1 Sensor
P1133 Insufficient Heated Oxygen Sensor (HO2S) Switching 1 Sensor 1
P1134 Heated Oxygen Sensor (HO2S) Shift Ratio Between Time 1 Sensor 1
P1135 Heated Oxygen Sensor (HO2S) Blue Average 1 Sensor 1
P1136 Rich Heated Oxygen Sensor (HO2S) means Bank 1 Sensor 1
P1137 Heated Oxygen Sensor (HO2S) Bank 1 2 Sensor System
P1138 Heated Oxygen Sensor (HO2S) Bank Change 12 Sensor Rich or High
P1139 Heated Oxygen Sensor (HO2S) INSUff Switching Bonk 1 Sensor 2
P1140 Heated Oxygen Sensor (HO2S) Bank Change Rates Between 1 Sensor 2
P1141 Heated Oxygen Sensor (HO2S) Control Circuit Tank 1 Sensor 2
P1143 Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Lean or Strong System Voltage Low
P1144 Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 High Voltage Is Rich?
P1145 Heated Oxygen Sensor (HO2S) Across BANK1 Sensor 3
P1153 Heated Oxygen Sensor (HO2S) Switch Insufficient Bank 2 Sensor 1
P1154 Heated Oxygen Sensor (HO2S) BANK Ratio 2 Sensor 1
P1155 Heated Oxygen Sensor (HO2S) Lean Average of Tank 2 Sensor 1
P1156 Rich Oxygen Sensor (HO2S) means Bonk 2 Sensor 1
P1157 Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Lean or Low Voltage
P1158 Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 High Voltage Is Over Too?
P1159 Heated Oxygen Sensor (HO2S) Bank Count 2 Sensor 2
P1161 Heated Oxygen Sensor (HO2S) Water Heater Control 2 Bank Sensor Circuit 2
P1163 Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Lean or Strong Voltage Low
P1164 Heated Oxygen (HO2S) Sensor Bank 2 3 Pressure Sensor Rich or High
P1165 Heated Oxygen Sensor (HO2S) Across Tank Count 2 Sensor 3
P1170 Cut Off Fuel Oil Compensation
P1171 Fuel System Lean During Acceleration
P1172 Fuel Transfer Insufficient pump flow transfer
P1185 Engine Oil Temperature Circuit
P1186 EOT Circuit Performance
P1187 Sensor Mains Voltage in EOT Circuit Low
P1188 Sensor, voltage in the EOT circuit high
P1189 Engine Oil Pressure (EOP) Switch Circuit
P1190 Vacuum Engine Leak
P1191 Intake Air Intake Air Leak
P1200 injector control circuit
P1201 Mass Gas (Alt. Fuel) Sensor Circuit / Performance
P1202 Mass Gas (Alt. Fuel) Sensor Circuit Low Frequency
P1203 Mass Gas (Alt. Fuel) Sensor High Frequency
P1211 Mass Air Flow Circuit Intermittent
P1212 Mass Air Flow Circuit Continuous Low
P1214 Injection pump offset timing
P1215 Checked Ground Fault noted
P1216 Fuel Solenoid Response Time Too Short
P1217 Fuel Solenoid Response Time Too Long
P1218 Injection Pump Calibration Circuit
P1219 Low Reference Pressure Sensor Position
P1220 Throttle Position Sensor (tP) 2 Circuit
P1221 Fuel Secondary Secondary
P1222 Injector Control Circuit Continuous
P1225 Injector 2 Cylinder Circuit Intermittent
P1228 Cylinder Injector 3 Circuit Continuous
P1231 Cylinder Injector 4 Circuit Continuous
P1234 Injector 5 Cylinder Intermittent Circuit
P1237 Injector 6 Intermittent Circuit
P1240 Injector Circuit 7 Cylinder Intermittent
P1243 Cylinder Injector 8 Continuous Circuit
P1245 Plenum Conversion Valve Volume Down
P1250 Heater Evaporated Fuel Pre
P1257 Oveboost system supercharger
P1258 OveetemPerature Heater Blower Motor Over 268F Performance
P1260 Last Test Failed SCCENTER Additional Information
P1270 Accelerator sensor pedal A / D converter position error
P1271 Throttle Position (APP) Sensor Correlation Sensor 1-2
P1272 Acceleralor Sensor Position 2
P1273 Pedal accelerator sensor 1
P1274 Ejector nozzle incorrectly wired
P1275 Accelerator Pedal Position (APP) Sensor 1 Circuit
P1276 Padl Accelerator Sensor Position 1 Circuit Performance
P1277 Acceleralor Pedel 1 Position Sensor Low Voltage
P1278 Pedal Accelerator Sensor Position 1 Circuit High Voltage
P1280 Throttle Position (APP) Sensor 2 Circuit Low
P1281 Acceleralor Sensor Low Pedal Position Circuit Performance 2
P1282 Acceleralor Low Pedal Sensor 2 Low voltage circuit
P1283 Acceleralor Sensor Low Pedal Position Circuit High 2
P1285 Acceleralor Sensor Low Pedal 3 Circuit
P1286 Low Acceleralor Pedal Sensor Circuit Performance 3
P1287 Acceleralor Sensor Low Pedal 3 Circuit Low Voltage
P1288 Acceleralor Sensor Low Pedal Position Circuit High
P1300 circuit
P1305 Ignition Coil 2 main circuit feedback
P1310 Ignition Coil 3 Feedback Mix Circuit
P1315 Ignition Coil 4 Digit Feedback
P1320 ic reference 4x circuit continuity
P1321 Electrical Misfire System
· Administrator
P001 - P0194
P0201 - P0433
P0434 - P0640
P0846 - P0920
P0921 - P1321
P1322 - P1791
P1792 - P2130
P2131 - P2715
P2716 - U0010
U0011 - U300
U301 - U0327
P1322 ei Auxiliary or missing ignition control system
P1323 24X Reference Low Frequency IC Circuit
P1324 Crank RPM Too Low
P1335 CKP Circuit.
P1336 Crankshaft system image, CKP position not learned
P1345 CKP Camshaft Crankshaft Position CMP Correlation
P1346 Intake Camshaft Position CmP Sensor System Performance
P1350 Ignition Control System
P1351 Ignition Coil Control Circuit High Voltage
P1352 ic high output / pulse detected when GND_Cyl2
P1353 ic output high / pulse detected when GND_Cyl3
P1354 ic output high / pulse detected when GND_Cyl4
P1355 ic high output / pulse is detected when GND_Cyl5
P1356 ic output high / pulse is detected when GND_Cyl6
P1357 ic high output / pulse detected when GND_Cyl7
P1358 ic output high / pulse is detected when GND_Cyl8
P1359 Ignition Coil Group 1 Control Circuit
P1360 Ignition Coil Group 2 Control Circuit
P1361 Ignition Control Coil Circuit Low Voltage
P1362 ic cylinder 2 cannot selectively be activated after
P1363 ic cylinder 3 cannot selectively activate after
P1364 ic cylinder 4 cannot be selected after activation
P1365 ic cylinder 5 cannot selectively activated after
P1366 ic cylinder 6 cannot be selected, activated after
P1367 ic cylinder 7 cannot be selected, activated after
P1368 ic cylinder 8 cannot selectively activate after
P1369 4x reference ic circuit, excessive pulses
P1370 4x reference ic circuit, excessive pulses
P1371 24 x reference ic circuit, high voltage
P1372 Ignition Ground Circuit
P1377 pulse ic for 4X pulse reference
P1380 stuck where rough road information cannot be detected
P1381 Stuck Detected No Break Control Module Communication
P1390 Wheel Speed Sensor 1 - G - sensor circuit
P1391 Wheel Speed Sensor 1 - G - Sensor Circuit Performance
P1392 Wheel Speed Sensor 1 - G - Sensor Circuit Low Voltage
P1393 Wheel Speed Sensor 1 - G - Sensor Circuit High Voltage
P1394 Wheel Speed Sensor 1 - G - Sensor Circuit Continuous
P1395 Wheel Speed Sensor 2 - G - Sensor Circuit
P1396 Wheel Speed Sensor 2 - G - Sensor Circuit Performance
P1397 Wheel Speed Sensor 2 - G - Sensor Circuit Low Voltage
P1398 Wheel Speed Sensor 2 - G - Sensor Circuit High Voltage
P1399 Wheel Speed Sensor 2 - G - Sensor Circuit
P1403 Gas Recirculation Exhaust Valve 1 System
P1404 EGR Exhaust Gas Rccirculation Closed Position
P1405 Gas Recirculation Exhaust Valve System 3
P1406 EGR Valve Pintle Angle Circuit
P1407 EGR Intrusion Set To Complete Exhaust EGR Valve
P1408 Manifold Intake Pressure Sensor Circuit
P1409 EGR Vacuum System Leak
P1410 Fuel Tank Pressure System
P1415 Secondary Air Injection AIR System Bonk 1
P1416 Secondary Air Injection AIR Tank 2 System
P1418 Injector Relay Secondary Control System
P1420 Air Intake Switch Circuit Low Voltage
P1421 Low Air Intake Pressure Switch Circuit High
P1423 Intake Air Intake Pressure Switch Circuit High
P1431 Fuel Level Sensor 2 Circuit performance
P1432 Fuel Level Sensor 2 Low voltage circuit
P1433 Fuel Level Sensor 2 High voltage circuit
P1441 Evaporative System Evaporative Flow (EVAP) during non-flushing
P1442 EVAP Vacuum SW Electro-High Between IGN About
P1450 Barometric Pressure Sensor Circuit
P1451 Press Air Sensor Performance
P1460 Cooling System Control Fan
P1480 Fan 1 Cooling Control Circuit High
P1481 Cooling Fan Speed Sensor
P1482 Cooling Fan Output Speed
P1483 Engine Cooling System Performance
P1484 Fan Ventilation System Performance
P1500 Signal circuit, start
P1501 Theft deterrent system
P1502 Vehicle Speed Sensor Circuit Sensor Continuous
P1503 deterrent fire alarm not activated
P1504 Fire deterrent Theft signal is not properly activated.
P1508 Low Speed Idle - Idlt Air Control IAC System Not Responding
P1509 High Speed Idle - Flight Control Idle, IAC Unresponsive
P1510 Pressure Control System
P1511 Control Data Performance
P1514 Correlation with TP Sensor High
P1515 Throttle, Electronic System, Throttle Position
P1516 Actuator Control in Throttle TAC in Throttle Actuator Module Position
P1517 Electronic Throttle Module
P1518 Electronic Throttle Module for PCM Operation
P1519 Actuator Control in Throttle TAC Module Internal Circuit
P1520 transmission loop switch interval
P1521 Transmission Joint Throttle High Angle
P1522 Park / Mid Drive / Reverse at High Rounds
P1523 Valve position performance
P1524 Valve position performance
P1525 Throttle Body Srvicerequired
P1526 Lows, wing pitch, not learned.
P1527 Transmission range to a correlation pressure switch
P1529 Thermal Problem
P1530 Actuator Control in Throttle (TAC) Module Internal Circuit
P1531 A / Side C Temperature Sensor Malfunction
P1532 A / C Cold Temperature Sens Circuit Low Voltage
P1533 A / C Cold Temperature Sens Circuit High Voltage
P1534 A / C Side Temperature High Low voltage sensing sensors
P1535 A / Side Emission Temperature Sensor Circuit
P1536 Engine Cooling Overtemperature A / C air conditioner
P1537 A / C Circuit Low, Low
P1538 A / C Circuit, High Voltage
P1539 Clutch Pressure A / C Clutch state circuit
P1540 A / C A / C Engine Too Cold, A / C A / C
P1541 A / C Ambient Temperature
P1542 A / C System Pressure High
P1543 A / C System Performance
P1544 A / C Cold Condition C Very Low
P1545 Air Conditioning A / C Clutch Relay Control Circuit
P1546 A / C Clutch State Circuit Low Voltage
P1547 A / C Reduction System Performance
P1548 A / C recirculation circuit
P1551 in Throttle Velve, not reached during learning
P1554 Cruise Tour Control Circuit
P1555 Export Electronic Component Orifiee
P1558 Servo Cruise Control Low Level
P1560 transaxle is not included in the driver. Handicapped boat control
P1561 Cruise Solenoid
P1562 Solenoid Vecuum
P1563 Cruise Control with Differential Speed / Location High
P1564 Cruise Control Too High - Cripple Control
P1565 Cruise Control Position Sensor
P1566 Engine RPM Too High, Cruise Control Off
P1567 bank Active Cruise Control Consumption Off
P1570 Active Traction Control Handicapped boat control
P1571 Stroke Control Circuit
P1572 ASR Active Circuit Too Low
P1573 Pcm EBTCM Serial Data Circuit
P1574 Stoplamp Switch Circuit
P1575 Travel Brake Switch Amplifier Circuit
P1576 BBV Sensor Circuit High Low
P1577 BBV Voltage Detected Circuit Low
P1578 BBV Vacuum Cleaner Circuit Low Sensor
P1579 P / N to D / R at high throttle angle - Active mode dropped last active
P1580 Cruising Circuit Low Voltage
P1581 High power electric cruise move circuit
P1582 Cruise Circuit Low Voltage Circuit Direction
P1583 Cruise Control Pressure CireuitHigh
P1584 Ship Control Disabled
P1585 Boat Control Suppresses Output Circuit
P1586 Cruise Control switch brake 2 circuit
P1587 Cruise Control Clutch Control Circuit Low
P1588 Cruise Control Clutch Control Circuit High
P1599 Floating powder, engine, or nearby flotation that must be found
P1600 Watchtlog internal operations tcm
P1601 Serial communication There is a problem with device 1
P1602 Sensor (KS) Knock Module Performance
P1603 Loss of SDM Serial Data
P1604 Loss of IPC Serial Data
P1605 Loss of HVAC Serial Data
P1606 Serial Communication Problem 6 Devices
P1607 Serial Communication Problem 7 Devices
P1608 Serial Communication Problem 8 Devices
P1609 Loss of TCS Serial Data
P1610 Loss of PZM Serial Data
P1611 Loss of CVRTD Serial Data
P1612 Loss of IPM Serial Data
P1613 Serial DIM Loss
P1614 Loss of Serial Data RIM
P1615 Loss of Serial VTD Data
P1617 Engine Oil Level Circuit
P1619 E ngine Oil Life Check Reset Circuit
P1620 Coolant Circuit
P1622 Selector Cylinder
P1623 Temp Resistor Pull -up
P1624 Shapshot requested by a customer Available data
P1625 Reset TCM System
P1626 Delerrent Fuel Turn On Alarm Not Received
P1627 A / D Performance
P1628 ECU Resistor Pull-Up
P1629 Cranking Signal Burglar Alarm System
P1630 Deteitent Steal Signal Activated
P1631 Started Deterrent Theft Disable Received Signal
P1632 Fuel Theft Deterrent Off Disabled Signal Received
P1633 Ignition 0 Circuit Level
P1634 Ignition Switch 1 Circuit
P1635 5 Volt Reference Circuit
P1636 PCM Stack Overrun
P1637 Generator L- terminal Circuit
P1638 Generator F- terminal Circuit
P1639 5 Volt 2 Circuit Reference
P1640 Driver-1 input, high voltage.
P1641 Faulty Indicator Lamp (Million Baht) Control Circuit
P1642 Vehicle Speed Output Circuit
P1643 Engine Speed Output Circuit
P1644 Long Slip Controls Twisted Transmission Output Circuit
P1645 Evaporative Ventilation Solenoid (EVAP) contorl circuit
P1646 Evaporative Ventilation Solenoid (EVAP) Control Circuit
P1647 Driver 1 Line 7
P1650 Output Control Module B Circuit
P1652 Fan 1 Relay Control Circuit
P1653 Oil Lamp Water Level Control Circuit
P1654 Dull Control Output Circuit
P1655 EVAP Transmission Control Solenoid
P1656 Driver 2 Line 6
P1657 Solenoid 1-4 Upshift Regulator Circuit
P1658 Start Relay Control Circuit Enable
P1660 Cooling Fan Control Circuit
P1661 mil Control Circuit
P1662 Cruise Control Lamp Circuit
P1663 Life Oil Lamp Control Circuit
P1664 1-4 Upshift Control Circuit Lamp
P1665 Driver 3 Line 5
P1666 Driver No. 36
P1667 Reverse Inhibit Solenoid Control Circuit
P1669 ABS unit to be expected
P1670 4 Driver
P1671 4 1st Band Driver
P1672 Low Engine Oil Level Control Circuit Lamp
P1673 Engine Hot Lamp Control Circuit
P1674 Tachometer Control Circuit
P1675 Vent Solenoid EVAP Control Circuit
P1676 - line 4-6 driver
P1677 - line 4-7 driver
P1680 - 5 Driver (ECU Malfunction)
P1681P1681 - Driver 5, Section 1
P1682 - Driver 5, Section 2
P1683 - driver 5 line 3
P1684 - driver 5 line 4
P1685 - driver 5 line 5
P1686 - driver 5 line 6
P1687 - driver 5 line 7
P1689 Wrong Torque Transmission Crouch Circuit
P1690 ECM Day Overrun
P1691 Gage Coolant Pressure Circuit
P1692 Circuit - Coolant Gage Pressure High
P1693 Measure Circuit Low Voltage
P1694 Measure circuit, high voltage
P1695 Keyless Entry Remote Circuit Low
P1696 High Remote Keyless Entry Voltage
P1700 TCM Transmission Control Module MIL Fire Requirements
P1701 Trans Request MIL Circuit
P1705 P / N Signal Circuit
P1719 Incorrectly shifting TCM detected
P1740 Twisted Signal Circuit
P1743 Tp Signal From ECM
P1760 TCM pressure interrupted
P1779 Engine Torque Sent To TCM Signal
P1780 PARK / Low Position Neutral PNP Switching Circuit
P1781 Engine Cranked Signal Circuit
P1790 Transmission Control Checksum Module
P1791 Transmission Control Loop Module
P1791 Wing Low / Pedal Signal 2000+
· Administrator
P001 - P0194
P0201 - P0433
P0434 - P0640
P0846 - P0920
P0921 - P1321
P1322 - P1791
P1792 - P2130
P2131 - P2715
P2716 - U0010
U0011 - U300
U301 - U0327
P1792 Memory Control New
P1792 ECM To Cool The TCM Engine Signal
P1793 Wheel Speed Signal 2000+
P1795 CAN Bus Throttle Body Position
P1800 TCM Power Relay Control Circuit
P1847 Shift Solenoid 2-3 Electrical Circuit High
P1850 Band Brake Operated Solenoid Circuit
P1851 Band Brake Solenoid Performance
P1852 Band is used to push the SolenoidLow cable.
P1853 Band Brake with Solenoid High Pressure
P1860 TCI PWM Solenoid Electrical Circuit
P1864 Twisted Clutch Circuit
P1865 Transmission 4-5 Solenoid SS Electrical Control Circuit High
P1866 TCC Clutch Pulse Width Frequency PWM Control Solenoid Low Voltage
P1867 TCC Pulsed Clutch Pulse Width PWM Solenoid Control Circuit High
P1868 Transmission Fluid Life
P1870 Transmission parts skid
P1871 Gear ratio undefined
P1873 Torque Clutch Stator Switch Circuit
P1874 Clutch Torque Stator High Switch Circuit
P1875 4WD Switch Circuit Low
P1884 Clutch Torque Open / Shift Switch Circuit Signal
P1886 Shift Time Solenoid
P1887 TCHee Switch Circuit Release
P1890 ECM Input Data
P1890 Low Throttle Position Input Signal
P1891 Throttle Pedal Sensor Position PWM Signal Low Signal
P1892 Throttle Sensor Position PWM Signal High
P1893 Engine Torque, High Voltage Signal
P1894 Engine Torque Signal High Voltage
P1895 TCM To ECM Torque Reduction Circuit
P1801 failed selection toggle.
P1804 Ground Control Relay
P1810 TFP Circuit Switch Position
P1811 Height Adjust and Long Shift
P1812 Transmit temperature condition
P1813 Torque control
P1814 Twisted Cverstressed
P1815 Transmission range changed - Starts invalid range
P1816 Valve Position TFP Sw Neu Drive Ratio
P1817 Reverse TFP Sw Position Valve with Drive Rate
P1818 Valve Position TFP SW Drive with Drive Ratio
P1819 Internal mode change starts without / valid range
P1820 Internal Switch Mode Circuit Low
P1822 Picture Switch Mode In Circuit B High
P1823 Picture Switch Mode in P Circuit Low
P1825 Picture Mode Changed In - Invalid Range
P1826 Switch Mode Under C Circuit High
P1831 Pressure Control PC Solenoid Circuit Low Voltage
P1832 Pressure Control PC Shift Solenoid
P1833 A / T Solenoids Circuit - Low Voltage
P1834 TCC Clutch Pressure Shift Solenoid SS Control Circuit High Voltage
P1835 kicked down a switching circuit
P1836 Kick Down Switch Failed To Off
P1837 Kick Down Switch Failed Short
P1842 Shift Solenoid 1-2 Relay Voltage Low
P1843 Shift Solenoid 1-2 Electrical Circuit High
P1844 Torque Reduction Circuit Required by TCM
P1845 Shift Solenoid 2-3 Main Circuit Low Voltage
P2000 Oxygen oxide trap efficiency lower than inlet (tank 1).
P2001 Nitrogen oxides capture efficiency lower than inlet (tank 2)
P2002, trap performance is lower than inlet (tank 1)
P2003 performance, capture speed is lower than inlet (tank 2)
P2004 Intake manifold flow regulator open (bank 1)
P2005 Intake Manifold Flow Control Closed (Tank 2)
P2006 Intake Manifold Flow Control Open (Bank 1)
P2007 Intake Manifold Flow Control Closed (Bank 2)
P2008 Intake Manifold Flow Control Circuit Open (Bank 1)
P2009 Intake Manifold Flow Control Circuit Low (Bank 1)
P2010 Intake manifold flow control circuit high (bank 1)
P2011 Intake Manifold Flow Control Circuit Open (Bank 1)
P2012 Intake Manifold Flow Control Circuit Low (Bank 2)
P2013 Intake manifold flow control circuit high (bank 2)
P2014 Intake Manifold Flow Position Sensor / Switch Circuit (Bonk 1)
P2015 Intake Manifold Flow Sensor / Switch Circuit Range / Performance (Bon 1)
P2016 Intake Manifold Flow Sensor / Switch Circuit Low (Bank 1)
P2017 Intake Manifold Flow Sensor / Switch Circuit High (Bonk 1)
P2018 Intake Manifold Flow Position Sensor / Switch Circuit Intermittent (Bonk 1)
P2019 Intake Manifold Flow Sensor / Switch Circuit (Unit 2)
P2020 Intake Manifold Flow Sensor / Switch Circuit Range / Performance (Bonk 2)
P2021 Intake Manifold Flow Sensor / Switch Circuit Low (Bonk 2)
P2022 Intake Manifold Flow Sensor / Switch Circuit High (Bonk 2)
P2023 Intake Manifold Flow Position Sensor / Switch Circuit Intermittent (Bonk 2)
P2024 Evaporative Emission Temperature Sensor Circuit
P2025 Evaporative Emission Temperature Sensor Circuit Range / Performance
P2026 Evaporative Emission Temperature Sensor Circuit
P2027 Evaporative Emission Temperature Sensor Circuit Low electric mobility
P2028 Evaporative Emission Temperature Sensor Circuit High displacement
P2029 Oil Heater Not Working
P2030 Oil Heater Operation
P2031 Exhaust Gas Temperature Sensor Circuit (Bank 1, Sensor 2)
P2032 Exhaust Gas Temperature Sensor Circuit Low (Bank 1, Sensor 2)
P2033 Exhaust Gas Temperature Sensor Circuit High (Bank 1 Sensor 2)
P2034 Exhaust Gas Temperature Sensor Circuit (Bank 2, Sensor 2)
P2035 Exhaust Gas Temperature Sensor Circuit Low (Bank 2, Sensor 2)
P2036 Exhaust Gas Temperature Sensor Circuit High (Bank 2 Sensor 2)
P2037 Injector Air Pressure Sensor Circuit Decreased
P2038 Injector Air Pressure Sensor Circuit Decreased Range of Performance
P2039 Injector Intake Air Pressure Sensor Circuit Low
P2040 Injector Intake Air Pressure Sensor Circuit High
P2041 Injector Air Pressure Sensor Circuit Decreased Intermittent
P2042 Temperature sensor circuit has decreased
P2043 Temperature Sensor Circuit Decreased Range
P2044 Temperature sensor circuit drops low
P2045 Temperature sensor circuit very high
P2046 Temperature sensor circuit drooling, intermittent
P2047 Injector circuit open (bank 1 unit 1)
P2048 Injector Circuit Low (Bank 1 Unit 1)
P2049 Injector Circuit High (Bank 1 Unit 1)
P2050 Injector Circuit Open (Bank 2 Unit 1)
P2051 Injector Circuit Low (Bank 2 Unit 1)
P2052 Injector circuit high (bank 2 unit 1)
P2053 Injector circuit open (bank 2 unit 1)
P2054 Injector Circuit Low (Bank 1 Unit 2)
P2055 Injector Circuit High (Bank 1 Unit 2)
P2056 Injector circuit open (bank 2 unit 2)
P2057 Injector Circuit Low (Bank 2 Unit 2)
P2058 Injector Circuit High (Bank 2 Unit 2)
P2059 Reduced nozzle air pump control circuit open
P2060 Injector Air Pump Control Circuit Low
P2061 Injector Air Pump Control Circuit High
P2062 Injector Supply Control Circuit / Open
P2063 Injector supply control circuit low
P2064 Injector supply control circuit high
P2065 Oil level "B" circuit
P2066 Oil level "B" circuit performance
P2067 Fuel level "B" circuit low
P2068 Oil level "B" circuit high
P2069 Fuel level "B" circuit intermittent.
P2070 Valve intake Manifold (IMT) open
P2071 Valve intake Manifold (IMT) closed
P2075 Intake Manifold (IMT) Valve Position Sensor Switch / Circuit
P2076 Intake Manifold (IMT) Valve Position Sensor / Switch Range / Performance
P2077 Intake Manifold (IMT) Valve Position Sensor / Switch Low
P2078 Intake Manifold (IMT) Valve Position Sensor / Switch High
P2079 Intake Manifold (IMT) Valve Position Sensor / Switch Range / Performance
P2080 Exhaust Gas Temperature Sensor Circuit Range / Performance (Bank 1, Sensor 1)
P2081 Exhaust Gas Temperature Sensor Circuit Intermittent Range / Performance (Bank 1, Sensor 1)
P2082 Exhaust Gas Temperature Sensor Circuit Range / Performance (Bank 2 Sensor 1) Circuit Range / Performance
P2083 Exhaust Gas Temperature Sensor Circuit Intermittent Range / Performance (Bank 2 Sensor 1)
P2084 Exhaust Gas Temperature Sensor Circuit Range / Performance (Bank 1 Sensor 2)
P2085 Exhaust Gas Temperature Sensor Circuit Intermittent Range of Performance (Bank 1 Sensor 2)
P2086 Exhaust Gas Temperature Sensor Circuit Range / Performance (Bank 2 Sensor 2)
P2087 Exhaust Gas Temperature Sensor Circuit Intermittent Range Performance (Bank 2 Sensor 2)
P2088 "A" circuit controls the camshaft position while running low (Bonk 1)
P2089 "A" control circuit for high working camshaft position (Bonk 1)
P2090 “B” circuit controls the camshaft position while running low (bonk 1)
P2091 “B” circuit controls high working camshaft position (Bonk 1)
P2092 "A" circuit controls the camshaft position while running low (Bonk 2)
P2093 “B” circuit controls high working camshaft position (Bonk 2)
P2094 “B” circuit controls the camshaft position while running low (Bonk 2)
P2095 “B” control circuit for high working camshaft position (Bonk 2)
P2096 Eqtalite Disk Oil Management System Too Thin (Bon 1)
P2097 Spotlight Disc Oil Management System Too Thick (Bon 1)
P2098 Eqtalite Disk Oil Management System Too Thin (Bon 2)
P2099 Eqtalite Fluid Management System Too Thick (Bon 2)
P2100 Throttle Actuator Control Motor Circuit / Open
P2101 Throttle Actuator Control Motor Circuit Range / Performance
P2102 Throttle Actuator Control Motor Circuit Low
P2103 Throttle Actuator Control Motor Circuit High
P2104 Throttle Actuator Control System
P2105 Throttle Actuator Control System The engine power off
P2106 Throttle Actuator Control System Rong Power Co., Ltd.
P2107 Modular Throttle Actuator Control System
P2108 Throttle Actuator Control System Module Active
P2109 Throttle / Pedal Position Sensor “A” Minimum Stop Performance
P2110 Throttle Actuation Control System Limited Cycle
P2111 Throttle actuator control system open
P2112 Closed throttle actuator control system
P2113 Throttle / Pedal Position Sensor “B” Minimum Stop Performance
P2114 Throttle / Pedal Position Sensor “C” Minimum Stop Performance
P2115 Throttle / Pedal Position Sensor “D” Minimum Stop Performance
P2116 Throttle / Pedal Position Sensor “E” Minimum Stop Performance
P2117 Throttle / Pedal Position Sensor “F” Minimum Stop Performance
P2118 Throttle Actuator Motor Range / Performance
P2119 Throttle Actuator Performance Control
P2120 Throttle / Pedal Position Sensor / Switch "D" Circuit Low
P2121 Throttle / Pedal Position Sensor / Switch "D" Circuit High
P2122 Throttle / Pedal Position Sensor Switch “D” Circuit Low
P2123 Throttle / Pedal Position Sensor Switch “D” Circuit High
P2124 Throttle / Pedal Position Sensor Switch “D” Circuit Intermittent
P2125 Throttle / Pedal Position Sensor Switch “E” Circuit
P2126 Throttle / Pedal Position Sensor / Switch "E" Circuit Range / Performance
P2127 Throttle / Pedal Position Sensor Switch “E” Circuit Low
P2128 Throttle / Pedal Position Sensor Switch “E” Circuit High
P2129 Throttle / Pedal Position Sensor Switch “E” Circuit Intermittent
P2130 Throttle / Pedal Position Sensor Switch “F” Circuit
· Administrator
P001 - P0194
P0201 - P0433
P0434 - P0640
P0846 - P0920
P0921 - P1321
P1322 - P1791
P1792 - P2130
P2131 - P2715
P2716 - U0010
U0011 - U300
U301 - U0327
P2131 Throttle / Pedal Position Sensor / Switch “F” Circuit Range / Performance
P2132 Throttle / Pedal Position Sensor Switch “F” Circuit Low
P2133 Throttle / Pedal Position Sensor Switch “F” Circuit High
P2134 Throttle / Pedal Position Sensor Switch “F” Circuit Intermittent
P2135 Throttle / Pedal Position Sensor / Switch The electric mobility "A" / "B" is related.
P2136 Throttle / Pedal Position Sensor / Switch The electric mobility "A" / "C" is related.
P2137 Throttle / Pedal Position Sensor / Switch The electric mobility "B" / "C" is related.
P2138 Throttle / Pedal Position Sensor / Switch The electric mobility "D" / "E" is related.
P2139 Throttle / Pedal Position Sensor / Switch The electric "D" / "F" is related.
P2140 Throttle / Pedal Position Sensor / Switch The electric mobility "E" / "F" is related.
P2141 Exhaust gas flow control throttle circuit low
P2142 Exhaust gas flow control throttle circuit high
P2143 Exhaust manifold airflow control circuit open
P2144 Exhaust manifold throttle control circuit low
P2145 Whirlpool Intake Control Circuit High
P2146 Fuel injector group “A” electric starter circuit is open.
P2147 Fuel injector group “A” electric starter circuit low
P2148 Fuel injector group “A” electric starter circuit high
P2149 Fuel injector group “B” electric starter circuit is open.
P2150 Fuel Injector Group “B” Electricity Circuit Low
P2151 Fuel injector group “B” electric starter circuit high
P2152 Fuel injector group “C” electric starter circuit is open.
P2153 Fuel injector group "C" power supply circuit low
P2154 Fuel injector group "C" power supply circuit high
P2155 Fuel Injector Group "B" Power Supply Circuit Open
P2156 Fuel injector group "D" power supply circuit low
P2157 Fuel injector group "D" power supply circuit high
P2158 Vehicle speed sensor "B"
P2159 Vehicle speed sensor "B" function
P2160 Speed "B" sensor circuit intermittent
P2161 Intermittent vehicle speed sensor "B"
P2162 Vehicle Speed Sensor "A" / "B" Correlation
P2163 Throttle / Pedal Position Sensor "A" Maximum Stop
P2164 Throttle / Pedal Position Sensor "B" Maximum Stop
P2165 Throttle / Pedal Position Sensor "C" Maximum Stop
P2166 Throttle / Pedal Position Sensor "D" Maximum Stop
P2167 Throttle / Pedal Position Sensor "E" Maximum Stop
P2168 Throttle / Pedal Position Sensor "F" Maximum Stop
P2169 Solenoid Control Circuit The exhaust vent is adjustable.
P2170 Solenoid Control Circuit Low exhaust pressure adjustment vent
P2171 Solenoid Control Circuit High exhaust pressure adjustment vent
P2172 Throttle Actuator Control System-Sudden High Flow Air
P2173 Throttle Actuator Control System - High Air Flow
P2174 Throttle Actuator Control System - Sudden High Air Flow
P2175 Throttle Actuator Control System - Air Flow High Low
P2176 Throttle Actuator Control System - Idle
P2177 Idle closed System is too thin (Class 1)
P2178 Idle off The system is too thick (Class 1)
P2179 Idle closed The system is too thin (Class 2)
P2180 Idle off The system is too thick (Class 2)
P2181 Cooling system performance
P2182 Engine Coolant Temperature Sensor 2 Circuit
P2183 Engine Coolant Temperature Sensor 2 Circuit Range / Performance
P2184 Engine Coolant Temperature Sensor 2 Circuit Low
P2185 Engine Coolant Temperature Sensor 2 Circuit High
P2186 Engine Coolant Temperature Sensor 2 Circuit Intermittent
P2187 System is too thin at idle (bank 1)
P2188 System is too thick at idle (bon 1)
P2189 System is too thin at idle (Class 2)
P2190 System Too Thick at Idle (Bon 2)
P2191 System too thin at higher condition (bank 1)
P2192 System is too thick at higher condition (bon 1)
P2193 System Too Thin at Higher Condition (Bank 2)
P2194 System too thick, higher condition (bank 2)
P2195 Thin Oxygen Sensor Signal (Bank 1, Sensor 1)
P2196 Thick Oxygen Sensor Signal (Bank 1, Sensor 1)
P2197 Thin Oxygen Sensor Signal (Bank 2, Sensor 1)
P2198 Thick Oxygen Sensor Signal (Bank 2, Sensor 1)
P2199 Intake Temperature Sensor 1/2 Correlation
P2200 Knock Sensor Circuit
P2201 Knock sensor range / performance (bon 1)
P2202 Knock sensor (bank 1) circuit low
P2203 Knock sensor (bank 1) circuit high
P2204 Knock sensor (bank 1) circuit intermittent
P2205 NOx sensor heater control circuit open (bank 1)
P2206 NOx Sensor Heater Control Circuit Low (bank 1)
P2207 NOx sensor heater control circuit high (bon 1)
P2208 NOx Sensor Heater Circuit open (bon 1)
P2209 Shock sensor heat sensor circuit, range or performance problem (bon 1)
P2210 Knock sensor (bank 1) recognition circuit low
P2211 Knock sensor (bank 1) recognition circuit high
P2212 Knock Sensor (Bank 1) Recognition Circuit Intermittent
P2213 Shock Sensor Circuit (Bank 2)
P2214 Shock Sensor Circuit Range / Performance (bank 2)
P2215 Shock Sensor (Bank 2) Circuit Low
P2216 Shock sensor (bank 2) circuit high
P2217 Shock Sensor (Bank 2) Circuit Intermittent
P2218 NOx Sensor Heater Control Circuit Open (Bank 2)
P2219 NOx Sensor Heater Control Circuit Low (Bank 2)
P2220 NOx Sensor Heater Control Circuit High (Bank 2)
P2221 NOx Sensor Heater Control Circuit Open (Bank 2)
P2222 Shock sensor heat sensation circuit, range or performance problem
P2223 NOx Sensor Heater Sensor Circuit Low (Bank 2)
P2224 Shock sensor heat sensor circuit high (bank 2)
P2225 NOx Sensor Heat Sensitivity Circuit Intermittent (Bank 2)
P2226 Barometric Pressure Circuit
P2227 Barometric Pressure Circuit Range / Performance
P2228 Barometric Pressure Circuit Low
P2229 Barometric Pressure Circuit High
P2230 Barometric Pressure Circuit Intermittent
P2231 Proximity oxygen sensor signal circuit (shock) at heating circuit (bank 1, sensor 1)
P2232 Proximity oxygen sensor signal circuit (shock) at heating circuit (bank 1, sensor 2)
P2233 Proximity oxygen sensor signal circuit (shock) at heating circuit (bank 1, sensor 3)
P2234 Proximity oxygen sensor signal circuit (shock) at heating circuit (bank 1, sensor 1)
P2235 Proximity oxygen sensor signal circuit (shock) at heating circuit (bank 1, sensor 2)
P2236 Proximity oxygen sensor signal circuit (shock) at heating circuit (bank 1, sensor 3)
P2237 O2 sensor positive lamp circuit / open (bank 2, sensor 1)
P2238 Oxygen Sensor Positive Gas Circuit Low (Bank 1, Sensor 1)
P2239 Oxygen Sensor Positive Gas Circuit High (Bank 1, Sensor 1)
P2240 Positive oxygen sensor gas circuit open (bank 2, sensor 1)
P2241 Oxygen Sensor Positive Torch Circuit Low (Bank 2, Sensor 1)
P2242 Fuel positive oxygen sensor circuit high (bank 2, sensor 1)
P2243 Oxygen Sensor Reference Voltage Circuit Open (Bank 1, Sensor 1)
P2244 Electricity circuit performance Oxygen Sensor Reference (Bank 1 Sensor 1)
P2245 Oxygen Sensor Reference Voltage Circuit Low (Bank 1, Sensor 1)
P2246 Oxygen reference voltage high circuit (bank 1, sensor 1)
P2247 Oxygen reference voltage circuit On (Bank 2 Sensor 1)
P2248 Inoxigen Electricity Circuit Range / Performance (Bank 2 Sensor 1)
P2249 Oxygen oscillating electromotive circuit
P2250 Oxygen sensor reference voltage circuit high
P2251 Oxygen Sensor Barrel Control Circuit Open (Bank 1, Sensor 1)
P2252 Oxygen Sensor Cartridge Control Circuit Low (Bank 1 Ser1)
P2253 Oxygen Sensor Cartridge Control Circuit High (Bank 1 Ser1)
P2254 Oxygen Sensor Regulator Control Circuit On (Bank 2 Sensor 1)
P2255 Oxygen Sensor Cartridge Control Circuit Low (Bank 2, Sensor 1)
P2256 Oxygen Sensor Cartridge Control Circuit High (Bank 2, Sensor 1)
P2257 Air conditioning control circuit high pressure high low
P2258 Intake Air Intake Sensor "A" Circuit High Voltage
P2259 Intake Air Intake Sensor "B" Circuit High Low
P2260 Intake Air Intake Sensor "B" Circuit High Voltage
P2261 Guiding valve bypass set Turbo / Supercharge
P2262 No Turbocharger Trigger Set
P2263 Turbo / Supercharger Boot Performance
P2264 Fuel Sensor Circuit
P2265 Oil In Fuel Sensor Circuit Range / Performance
P2266 Low Fuel Sensor Circuit
P2267 Fuel Sensor Circuit High
P2268 Fuel In-Oil Sensor Circuit Intermittent
P2269 water in oil condition
P2270 Low signal oxygen sensor (bank 1 sensor 2)
P2271 Thick oxygen sensor signal (bank 1, sensor 2)
P2272 Thin signal oxygen sensor (bank 1 sensor 2)
P2273 Thick oxygen sensor signal (bank 2, sensor 2)
P2274 Oxygen sensor signal Thin (Bank 2 Sensor 3)
P2275 Thick oxygen sensor signal (bank 1, sensor 3)
P2276 Thin signal oxygen sensor (bank 2 sensor 3)
P2277 Thick oxygen sensor signal (bank 2, sensor 3)
P2278 Oxygen Sensor Signal Swapped Tank 1 Sensor 3 / Tank 2 Sensor 3
P2279 Intake system leak
P2280 turbo / idler Between the air filter and the flow
P2281 intake manifold between the throttle body and the float
P2282 intake manifold between throttle body and intake valve
P2283 Injector Control Pressure Sensor Circuit
P2284 Injector Control Pressure Sensor Circuit Range / Performance
P2285 Injector Control Pressure Sensor Circuit Low
P2286 Injector Control Pressure Sensor Circuit High
P2287 Injector Control Pressure Sensor Circuit Intermittent
P2288 Injector Control Pressure Too High
P2289 Injector Control Pressure Sensor Circuit Too high - engine stops
P2290 Injector Control Pressure Too Low
P2291 Injector Control Pressure Sensor Circuit Too low - Engine does not start (Cranking).
P2292 Injector Control Pressure Sensor Circuit Malfunction
P2293 Fuel Pressure Adjustment Function # 2
P2294 Fuel Pressure Regulator Control Circuit # 2
P2295 Fuel Pressure Regulator 2 Control Circuit Low
P2296 Fuel Pressure Regulator 2 Control Circuit High
P2297 Oxygen Sensor Not working properly while reducing speed (Bank 1 Sensor 1)
P2298 Oxygen Sensor Not working properly while reducing speed (Bank 2 Sensor 1)
P2299 Low Brake Lever Position / Incorrect Throttle Position Low
P2300 Ignition Coil "A" Primary Control Circuit Low
P2301 Ignition Coil “A” Low Voltage Control Circuit High
P2302 High Voltage Ignition Coil “A” Control Circuit
P2303 Ignition Coil “B” Primary Control Circuit Low
P2304 Ignition Coil “B” Primary Control Circuit High
P2305 High Voltage Ignition Coil “B” Control Circuit
P2306 Ignition Coil “C” Primary Control Circuit Low
P2307 Ignition Coil “C” Low Voltage Control Circuit High
P2308 High Voltage Ignition Coil “C” Control Circuit
P2309 Ignition Coil “D” Primary Control Circuit Low
_
P2310 Ignition Coil Secondary "D" Control Circuit High
P2311 Ignition Coil Secondary "D" Control Circuit
P2312 Ignition Coil “E” Primary Control Circuit Low
P2313 Ignition Coil "E" Low Voltage Control Circuit
P2314 Ignition Coil, Secondary "E" Control Circuit
P2315 Ignition Coil "F" Primary Control Circuit Low
P2316 Ignition Coil Low "F" Control Circuit High
P2317 Secondary Ignition Coil "F" Control Circuit
P2318 Ignition Coil “G” Primary Control Circuit Low
P2319 Ignition Coil Secondary "G" Control Circuit High
P2320 High Voltage Ignition Coil "G" Control Circuit
P2321 Ignition Coil “H” Primary Control Circuit Low
P2322 Ignition Coil "H" Primary Control Circuit High
P2323 High Voltage Ignition Coil “H” Control Circuit
P2324 Ignition Coil “H” Low Voltage Control Circuit
P2325 Ignition Coil “I” Primary Control Circuit Low
P2326 High Voltage Ignition Coil “I” Control Circuit
P2327 Ignition Coil “J” Primary Control Circuit Low
P2328 Ignition Coil “J” Primary Control Circuit High
P2329 High Voltage Ignition Coil “J” Control Circuit
P2330 Ignition Coil “K” Primary Control Circuit Low
P2331 Ignition Coil “K” Low Voltage Control Circuit High
P2332 Ignition Coil, Secondary "K" Electrical Control Circuit
P2333 Ignition Coil “L” Primary Control Circuit Low
P2334 Ignition Coil “L” Primary Control Circuit High
P2335 High Voltage Ignition Coil "L" Control Circuit
P2336 Cylinder 1 Knock
P2337 2nd cylinder lock
P2338 3rd cylinder lock
P2339 Cylinder 4 nipple
P2340 Cylinder 5 lock
P2341 Cylinder 6 Knock
P2342 Cylinder 7 Nock
P2343 Cylinder 8 lock
P2344 Cylinder 9 Nock
P2345 Cylinder 10 Knock
P2346 Cylinder 11 Nock
P2347 Shock cylinder 12
P2400 Evaporative Emission System Pump Control Circuit Open
P2401 Evaporative Emission System Pump Control Circuit Low
P2402 Evaporative Emission System Pump Control Circuit High
P2403 Evaporative Emission System Pump Recognition Circuit
P2404 Evaporative Emission System Leak Detection Pump Sense Circuit Range / Performance
P2405 Evaporative Emission System Pump Recognition Circuit Low
P2406 Evaporative Emission System Pump Recognition Circuit High
P2407 Evaporative Emission System Pump Recognition Circuit Lack
P2408 Fuel Cap Sensor / Switch Circuit
P2409 Fuel Cap Sensor / Switch Circuit Range / Performance
P2410 Fuel Cap Sensor / Switch Circuit Low
P2411 Fuel Cap Sensor / Switch Circuit High
P2412 Fuel Cap Sensor / Switch Circuit Intermittent
P2413 Exhaust Gas Recirculation System Range / Performance
P2414 Exhaust sample sensor defective (bank 1, sensor 2)
P2415 Exhaust sample sensor defective (bank 2, sensor 2)
P2416 Oxygen Sensor Swapped (Bank 1 Sensor 2) (Bank 1 Sensor 3)
P2417 Oxygen Sensor Swapped (Bank 2 Sensor 2) (Bank 2 Sensor 3)
P2418 Evaporative Emission System Switching Valve Control Circuit Open
P2419 Evaporative Emission System Switching Valve Control Circuit Low
P2420 Evaporative Emission System Switching Valve Control Circuit High
P2421 Evaporative Emission System Switching Valve Open
P2422 Evaporative Emission System Switching Valve Closed
P2423 Cantalite performance lower than entrance to bon 1
P2424 Cantalite performance is lower than that of Bonk 2 entrance.
P2500 Generator Left Lamp Generator Circuit Low
P2501 Left generator regulator lamp circuit high
P2502 Charging system electric motor
P2503 Charging system electric motion low
P2504 Charged electric motor high
P2505 Ecm / Pcm power input signal Engine / Electric control module
P2506 Ecm / Pcm power input signal range, Engine / Electric control module performance
P2507 Ecm / Pcm power input signal, engine / electric control module low
P2508 Ecm / Pcm power input signal high engine / electric control module
P2509 Ecm / Pcm power input signal, Engine / Electric control module intermittent
P2510 Ecm / Pcm power Relay Sense Circuit Range / Performance
P2511 Ecm / Pcm power Relay Sense Circuit Intermittent / Engine / Electric Control Module
P2512 Data logger circuit open
P2513 Data Recorder Circuit Low
P2514 Data Recorder Circuit High
P2515 Refrigerant pressure sensor "B" circuit
P2516 Air compressor pressure sensor "B" circuit, range or performance problem
P2517 Refrigerant pressure sensor "B" circuit low
P2518 Refrigerant pressure sensor "B" circuit high
P2519 Compressor "A" Circuit
P2520 compressor "A" circuit low
P2521 Compressor "A" circuit high
P2522 Compressor "B" Circuit
P2523 Compressor "B" Circuit Low
P2524 Compressor "B" circuit high
P2525 Tank Pressure Sensing Sensor Circuit
P2526 Tank Pressure Sensor Circuit Range / Performance
P2527 Cylinder pressure sensing sensor circuit, low
P2528 Cylinder pressure sensing sensor circuit high
P2529 Tank Pressure Sensor Intermittent Circuit
P2530 Ignition Switch RUN Position Circuit
P2531 Ignition Switch RUN Position Circuit Low
P2532 Ignition Switch RUN Position Circuit High
P2533 Ignition Switch RUN / Start Position Circuit
P2534 Ignition Switch Run / Start Position Circuit Low
P2535 Ignition Switch RUN / Start Position Circuit High
P2536 Ignition Switch ACCESSORY Low Circuit
P2537 Ignition Switch ACCESSORY Low Circuit
P2538 Ignition Switch ACCESSORY Low Circuit High
P2539 Low Pressure Fuel System Sensor Circuit
P2540 Low Pressure Fuel System Sensor Circuit Range / Performance
P2541 Low Pressure Fuel System Sensor Circuit Low
P2542 Low Pressure Fuel System Sensor Circuit High
P2543 Low Pressure Fuel System Sensor Circuit Intermittent
P2544 mri distortion signal (Managemcnt Requast input) "A"
P2545 mri signal distortion operation (Managemcnt Requast input) "A"
P2546 mri (Managemcnt Requast input) signal “A” low
P2547 mri (Managemcnt Requast input) signal “A” high
P2548 mri distortion signal (Managemcnt Requast input) "B"
P2549 mri signal distortion operation (Managemcnt Requast input) "B"
P2550 mri (Managemcnt Requast input) signal “B” low
P2551 High mri signal (Managemcnt Requast input) "B"
P2552 Throttle valve circuit / oil stop
P2553 Throttle valve circuit / oil stop performance
P2554 Throttle / Stop Oil Circuit Low
P2555 Throttle / Fuel Stop Circuit High
P2556 Engine Coolant Level Sensor / Switch Circuit
P2557 Engine Coolant Level Sensor / Switch Circuit Range / Performance
P2558 Engine Coolant Level Sensor / Switch Circuit Low
P2559 Engine Coolant Level Sensor / Switch Circuit High
P2560 Engine coolant level low
P2600 Coolant Control Circuit Open
P2601 Coolant Pump Control Circuit Range / Performance
P2602 Coolant Pump Control Circuit Low
P2603 Coolant Pump Control Circuit High
P2604 Intake heater circuit "A"
P2605 Intake heater "A" circuit open
P2606 Intake heater circuit "B"
P2607 Intake heater “B” circuit low
P2608 Intake heater "B" circuit high
P2609 Intake heater function
P2610 ECM / PCM Engine Control Module / Electric / Internal Engine Off Timing Performance
P2611 Air compressor valve control circuit open
P2612 Air compressor valve control circuit low
P2613 Dosing valve regulator circuit high
P2614 Camshaft Position Power Supply Circuit Open
P2615 Camshaft Position Output Signal Circuit Low
P2616 Camshaft Position Output Signal Circuit High
P2617 Crankshaft position power supply circuit open
P2618 Crankshaft Position Output Signal Circuit Low
P2619 Crankshaft position power supply circuit high
P2620 Throttle Position Power Supply Circuit / Open
P2621 Throttle Position Power Supply Circuit Low
P2622 Throttle position power supply circuit high
P2623 Injector Pressure Adjustment Circuit Open
P2624 Injector Pressure Regulator Circuit Low
P2625 Injector pressure regulator circuit high
P2626 Pumpimg Trim O2 Sensor Circuit Open (Bank 1, Sensor 1)
P2627 Pumpimg Trim O2 Sensor Circuit Low (Bank 1, Sensor 1)
P2628 Pumpimg Trim oxygen sensor circuit high (bank 1, sensor 1)
P2629 Pumpimg Trim O2 Sensor Circuit Open (Bank 2, Sensor 1)
P2630 Pumpimg Trim Oxygen Sensor Circuit Low (Bank 2, Sensor 1)
P2631 Pumpimg Trim Oxygen Sensor Circuit High (Bank 2, Sensor 1)
P2632 Fuel Pump "B" Control Circuit Open
P2633 Fuel pump "B" control circuit low
P2634 Fuel pump "B" control circuit high
P2635 Low Flow Fuel Pump "A" Performance
P2636 Fuel Pump "B" Low Flow Performance
P2637 MFS (Management facd Signai) signal "A"
P2638 MFS (Management facd Signai) signal "A" signal error
P2639 MFS (Management facd Signai) strong signal “A” low
P2640 MFS (Management facd Signai) strong signal “A” high
P2641 MFS (Management facd Signai) signal "B"
P2642 MFS signal operation (Management facd Signai) “B”
P2643 MFS (Management facd Signai) signal “B” low
P2644 MFS (Management facd Signai) signal "B" high
P2645 Thrust valve "A" control circuit
P2646 Throttle control circuit "A" (bank 1) closed
P2647 Throttle control circuit "A" (bank 1) open
P2648 Throttle valve "A" control circuit low (bank 1)
P2649 Throttle control circuit "A" (bank 1) high
P2650 Thrust control valve "B" (bank 1) open
P2651 Throttle control circuit "B" (bank 1) closed
P2652 Throttle control circuit "B" (bank 1) open
P2653 Throttle control circuit "B" (bank 1) low
P2654 Throttle control circuit "B" (bank 1) high
P2655 Thrust Control Valve "A" (Bank 2) Open
P2656 Throttle control circuit actuation “A” (bank 2) closed
P2657 Throttle control circuit "A" (bank 2) open
P2658 Throttle control circuit "A" (bank 2) low
P2659 Throttle control circuit "A" (bank 2) high
P2660 Idle Thrust Control Circuit “B” (Bank 2) Open
P2661 Thrust valve "B" control circuit / performance problem (bank 2) closed
P2662 Thrust valve "B" control circuit (bank 2) open
P2663 Thrust thrust control circuit "B" (bank 2) low
P2664 Thrust valve "B" control circuit high (bank 2)
P2700 Transmission "A" friction performance
P2701 Transmission "B" friction operation
P2702 Transmission "C" friction operation
P2703 Transmission "D" friction operation
P2704 Transmission "E" friction operation
P2705 Transmission "F" friction operation
P2706 Shift Solenoid “F”
P2707 Shift solenoid “F” performance off
P2708 Shift solenoid “F” open
P2709 Shift solenoid “F” electric
P2710 Shift solenoid "F" intermittent
P2711 Gear shift mechanism comes out
P2712 Hydraulic Power Unit Leak
P2713 Pressure Control Solenoid "D"
P2714 Pressure Control Solenoid “D” Performance Off
P2715 Pressure Control Solenoid “D” Open
· Administrator
Discussion Starter · #9 · (Edited)
P001 - P0194
P0201 - P0433
P0434 - P0640
P0846 - P0920
P0921 - P1321
P1322 - P1791
P1792 - P2130
P2131 - P2715
P2716 - U0010
U0011 - U300
U301 - U0327
P2716 Pressure Control Solenoid "D" Electrical
P2717 Pressure Control Solenoid "D" Intermittent
P2718 Pressure Control Solenoid “D” Open
P2719 Pressure Control Solenoid “D” Circuit Range / Performance
P2720 Pressure control solenoid "D" circuit low
P2721 Pressure control solenoid "D" circuit high
P2722 Pressure Control Solenoid "E"
P2723 Pressure Control Solenoid “E” Performance Off
P2724 Pressure Control Solenoid "E" Open
P2725 Pressure Control Solenoid "E" Electrical
P2726 Pressure Control Solenoid "E" Intermittent
P2727 Pressure Control Solenoid "E" Circuit Open
P2728 Pressure Control Solenoid "E" Circuit Range / Performance
P2729 Pressure control solenoid "E" circuit low
P2730 Pressure control solenoid "E" high circuit
P2731 Pressure Control Solenoid "F"
P2732 Pressure Control Solenoid "F" Performance Off
P2733 Pressure Control Solenoid "F" Open
P2734 Pressure Control Solenoid "F" Electrical
P2735 Pressure Control Solenoid "F" Intermittent
P2736 Pressure Control Solenoid "F" Circuit Open
P2737 Pressure Control Solenoid "F" Circuit Range / Performance
P2738 Pressure control solenoid "F" circuit low
P2739 Pressure control solenoid "F" circuit high
P2740 Transmission fluid temperature "B" circuit
P2741 Transmission fluid temperature "B" circuit range or performance problem
P2742 Transmission fluid temperature "B" circuit low
P2743 Transmission fluid temperature "B" circuit high
P2744 Transmission fluid temperature "B" circuit intermittent
P2745 Intermediate Shaft Speed Sensor "B"
P2746 Intermediate Shaft Speed Sensor "B" Range of Performance
P2747 Intermediate Shaft Speed Sensor "B" No Signal
P2748 Intermediate Shaft Speed Sensor “B” Intermittent
P2749 Intermediate Shaft Speed Sensor "C"
P2750 Intermediate Shaft Speed Sensor "C" Circuit Range / Performance
P2751 Intermediate Shaft Speed Sensor "C" Circuit No Signal
P2752 Intermediate Shaft Speed Sensor "C" Circuit Intermittent
P2753 Transmission Fluid Coolant Control Circuit Open
P2754 Transmission Fluid Coolant Control Circuit Low
P2755 Transmission Fluid Coolant Control Circuit High
P2756 Pressure control solenoid, torque converter clutch
P2757 Torcconverter Clutch Pressure Control Solenoid Closed
P2758 Torque Conector Clutch Pressure Control Solenoid Open
P2759 Torque converter clutch pressure control solenoid circuit
P2760 Torque Conector Clutch Pressure Control Solenoid Circuit Intermittent
P2761 Torque Converter Clutch Solenoid Circuit Open
P2762 Torque Conector Clutch Solenoid Circuit Range / Performance
P2763 Torque converter clutch pressure control solenoid circuit high
P2764 Torque converter clutch pressure control solenoid circuit low
P2765 Turbine Speed Sensor "B" Circuit
P2766 Turbine Speed Sensor "B" Circuit Range / Performance
P2767 Turbine Speed Sensor "B" Circuit No Signal
P2768 Turbine Speed Sensor "B" Circuit Intermittent
P2769 Clutch converter circuit low
P2770 Clutch converter circuit high
P2A00 Oxygen Sensor Circuit Range / Performance (Bank 1 Sensor 1)
P2A01 Oxygen Sensor Circuit Range / Performance (Bank 1 Sensor 2)
P2A23 Oxygen Sensor Circuit Range / Performance (Bank 1 Sensor 3)
P2A03 Oxygen Sensor Circuit Range / Performance (Bank 2 Sensor 1)
P2A04 Oxygen Sensor Circuit Range / Performance (Bank 2 Sensor 2)
P2A05 Oxygen Sensor Circuit Range / Performance (Bank 2 Sensor 3)
P3400 Cylinder system
P3401 Intake / Cylinder 1 Control Circuit / Open
P3402 Intake / cylinder 1 control circuit, range or performance problem
P3403 Intake / cylinder 1 control circuit low
P3404 Intake / cylinder 1 control circuit high
P3405 1st Exhaust / Cylinder Control Circuit / Open
P3406 Exhaust / Cylinder 1 Control Circuit Range / Performance
P3407 1st Exhaust / Cylinder Control Circuit Low
P3408 1st cylinder exhaust / control circuit high
P3409 Exhaust / Cylinder 2 Control Circuit / Open
P3410 Exhaust / Cylinder 2 Control Circuit Range / Performance
P3411 Exhaust / Cylinder 2 Control Circuit Low
P3412 Exhaust / Cylinder 2 Control Circuit High
P3413 2nd Exhaust / Cylinder Control Circuit Open
P3414 Exhaust / Cylinder 2 Control Circuit Low / Performance
P3415 Exhaust / Cylinder 2 Control Circuit Low
P3416 Exhaust / Cylinder 2 Control Circuit High
P3417 3rd Intake / Cylinder Control Circuit / Open
P3418 Intake / 3rd Cylinder Control Circuit Range / Performance
P3419 Intake / Cylinder 3 Control Circuit Low
P3420 Intake / Cylinder 3 Control Circuit High
P3421 Intake / 3rd Cylinder Control Circuit / Open
P3422 Exhaust / Cylinder 3 Control Circuit Range / Performance
P3423 Intake / Cylinder 3 Control Circuit Low
P3424 Intake / Cylinder 3 Control Circuit High
P3425 Intake / Cylinder 4 Control Circuit Open
P3426 Intake / Cylinder 4 Control Circuit Range / Performance
P3427 Intake / Cylinder 4 Control Circuit Low
P3428 Intake / Cylinder 4 Control Circuit High
P3429 Exhaust / Cylinder 4 Control Circuit / Open
P3430 Exhaust / Cylinder 4 Control Circuit Range / Performance
P3431 Exhaust / Cylinder 4 Control Circuit Low
P3432 Exhaust / Cylinder 4 Control Circuit High
P3433 Intake / 5th Cylinder Control Circuit / Open
P3434 Intake / Cylinder 5 Control Circuit Range / Performance
P3435 Intake / Cylinder 5 Control Circuit Low
P3436 Intake / Cylinder 5 Control Circuit High
P3437 Exhaust / Cylinder 5 Control Circuit / Open
P3438 Exhaust / Cylinder 5 Control Circuit Range / Performance
P3439 Exhaust / Cylinder 5 Control Circuit Low
P3440 Exhaust / Cylinder 5 Control Circuit High
P3441 Intake / Cylinder 6 Control Circuit Open
P3442 Intake / Cylinder 6 Control Circuit Range / Performance
P3443 Intake / Cylinder 6 Control Circuit Low
P3444 Intake / Cylinder 6 Control Circuit High
P3445 Exhaust / Cylinder 6 Control Circuit Open
P3446 Exhaust / Cylinder 6 Control Circuit Range / Performance
P3447 6th Exhaust / Cylinder Control Circuit Low
P3448 Exhaust / Cylinder 6 Control Circuit High
P3449 Intake / Cylinder 7 Control Circuit Open
P3450 Intake / Cylinder 7 Control Circuit Range / Performance
P3451 Intake / Cylinder 7 Control Circuit Low
P3452 Exhaust / Cylinder 7 Control Circuit High
P3453 7th Exhaust / Cylinder Control Circuit Open
P3454 Cylinder 7 Exhaust Control Performance
P3455 Exhaust / Cylinder 7 Control Circuit Low
P3456 Exhaust / cylinder control circuit at 7 high
P3457 8th Cylinder Exhaust Control Circuit Open
P3458 Intake / 8th cylinder control function
P3459 Intake / Cylinder 8 Control Circuit Low
P3460 Intake / Cylinder 8 Control Circuit High
P3461 Exhaust / Cylinder 8 Control Circuit Open
P3462 Exhaust / Cylinder 8 Control Circuit Range / Performance
P3463 Exhaust / Cylinder 8 Control Circuit Low
P3464 Exhaust / Cylinder 8 Control Circuit High
P3465 Intake / Cylinder 9 Control Circuit Open
P3466 Intake / Cylinder 9 Control Circuit Range / Performance
P3467 Intake / Cylinder 9 Control Circuit Low
P3468 Intake / Cylinder 9 Control Circuit High
P3469 9th Exhaust / Cylinder Control Circuit Open
P3470 Exhaust / Cylinder 9 Control Circuit Range / Performance
P3471 Cylinder 9 Exhaust Control Circuit Low
P3472 Cylinder 9 Exhaust Control Circuit High
P3473 Intake 10 Control Circuit Open
P3474 Intake / Cylinder 10 Control Circuit Range / Performance
P3475 Intake / Cylinder 10 Control Circuit Low
P3476 Intake / Cylinder 10 Control Circuit High
P3477 10th Exhaust / Cylinder Control Circuit Open
P3478 Exhaust / Cylinder 10 Control Circuit Range / Performance
P3479 Exhaust / Cylinder 10 Control Circuit Low
P3480 Exhaust Control / Cylinder 10 Circuit High
P3481 Intake / Cylinder 11 Control Circuit
P3482 11th Intake / Cylinder Control Circuit / Performance Open
P3483 Intake / Cylinder 11 Control Circuit Low
P3484 Intake / cylinder control circuit 11 high
P3485 11th Exhaust / Cylinder Control Circuit Open
P3486 11th Exhaust / Cylinder Control Circuit Range / Performance
P3487 Exhaust / Cylinder 11 control circuit low
P3488 Exhaust / cylinder 11 control circuit high
P3489 12th intake / cylinder control circuit open
P3490 Intake / Cylinder 12 Control Circuit Range / Performance
P3491 Intake / Cylinder 12 Control Circuit Low
P3492 Intake / Cylinder 12 Control Circuit High
P3493 Exhaust / Cylinder 12 Control Circuit Open
P3494 12th Exhaust / Cylinder Control Circuit Range / Performance
P3495 Exhaust / Cylinder 12 Control Circuit Low
P3496 Exhaust / Cylinder 12 Control Circuit High
P0A00 Electric Motor Coolant Temperature Sensor Circuit
P0A01 Sensor Circuit Range / Performance Electric motor coolant temperature
P0A02 Motor coolant temperature sensor circuit low
P0A03 Motor coolant temperature sensor circuit high
P0A04 Electric Motor Coolant Temperature Sensor Circuit Intermittent
P0A05 Coolant Pump Electric Motor Control Circuit Open
P0A06 Coolant Pump Electric Motor Control Circuit Low
P0A07 Coolant Pump Electric Motor Control Circuit High
P0A08 DC / DC converter image state circuit
P0A09 DC / DC converter image state circuit low
P0A10 DC / DC converter image state circuit high
P0A11 DC / DC power image state circuit, open
P0A12 DC / DC power image state circuit low
P0A13 DC / DC Voltage Picture Circuit High
P0A14 Engine Mount Control Circuit Open
P0A15 Engine mount control circuit low
P0A16 Engine mount control circuit high
P0A17 torque motor sensor circuit
P0A18 Torcenter Sensor Circuit Range / Performance
P0A19 Torcenter Sensor Circuit Low
P0A20 Torcenter Sensor Circuit High
P0A21 Torcenter Sensor Circuit Intermittent
P0A22, torque sensor circuit
P0A23, torque sensor circuit, range or performance problem
P0A24 Torque Sensor Circuit Low
P0A25 torque sensor circuit high
P0A26, torque sensor circuit intermittent
P0A27 Battery power circuit off
P0A28 Battery power circuit open
P0A29 Battery power circuit high
U0001 High Speed Communication CAN RUS
U0002 High-speed communication operation with CAN BUS
U0003 High-speed communication operation CAN BUS + Open
U0004 High Speed CAN BUS + Communication Operation Low
U0005 High Speed CAN BUS + Communication Operation
U0006 High-speed CAN BUS-Open communication operation
U0007 High Speed CAN BUS-Low Communication Operation
U0008 High Speed CAN BUS-High Communication Operation
U0009 High-speed CAN BUS communication operation - Short circuit at Bus +
U0010 Communications Moderate CAN BUS
· Administrator
Discussion Starter · #10 ·
U0011 Interoperability Communication Intermediate CAN BUS
U0012 Communications Moderate CAN BUS + Open
U0013 Communications Moderate CAN BUS + Off
U0014 Communications Moderate CAN BUS + High
U0015 Communications Moderate CAN BUS - Open
U0016 Communication Moderate CAN BUS - Low
U0017 Communications Moderate CAN BUS - High
U0018 CAN BUS Intermediate Communication - Shorted at BUS +
U0019 Low Speed Communication CAN BUS
U0020 Low speed communication function CAN BUS
U0021 Low Speed Communication CAN BUS + Open
U0022 Low Speed Communication CAN BUS + Off
U0023 Low Speed Communication CAN BUS + High
U0024 Low Speed Communication CAN BUS - Open
U0025 Low Speed Communication CAN BUS - Low
U0026 Low Speed CAN BUS - High
U0027 Low Speed CAN BUS Communication - Shorted at BUS +
U0028 Vehicle communication BUS A
U0029 Vehicle communication function BUS A
U0030 Vehicle communication BUS A + open
U0031 Vehicle communication BUS A + off
U0032 Communication Vehicle BUS A + Hi
U0033 Vehicle Communications BUS A - Open
U0034 Vehicle Communications BUS A - Low
U0035 Vehicle Communications BUS A - High
U0036 BUS A communication vehicle - shorted to BUS +
U0037 Vehicle Communications BUS B
U0038 Vehicle BUS B communication function
U0039 Vehicle Communications BUS B + Open
U0040 Vehicle Communications BUS B + Low
U0041 Vehicle Communications BUS B + Hi
U0042 Vehicle Communications BUS B-Open
U0043 Vehicle Communications BUS B-Low
U0044 Vehicle Communications BUS B-Hi
U0045 Car Communications BUS B Crate Circuit at BUS B +
U0046 Vehicle Communications BUS C
U0047 Vehicle Communication Bus C Operation
U0048 Vehicle Communications BUS C + Open
U0049 Vehicle Communications BUS C + Low
U0050 Communication Vehicle BUS C + Hi
U0051 Vehicle Communications BUS C-Open
U0052 Vehicle Communications BUS C-Low
U0053 Vehicle Communications BUS C-Hi
U0054 Vehicle communication BUS C - BUS + short circuit
U0055 Vehicle Communications BUS D
U0056 Vehicle communication function BUS D
U0057 Vehicle communication BUS D + open
U0058 Vehicle Communications BUS D + Low
U0059 Vehicle Communications BUS D + Hi
U0060 Vehicle Communications BUS D - Open
U0061 Vehicle Communications BUS D - Low
U0062 Vehicle Communications BUS D - High
U0063 BUS D vehicle communication - BUS D + short circuit
U0064 Vehicle Communications BUS E
U0065 Vehicle Communication Operation BUS E
U0066 Vehicle communication BUS E + open
U0067 Vehicle Communications BUS E + Low
U0068 Vehicle communication BUS E + high
U0069 Vehicle Communications BUS E-Open
U0070 Vehicle Communications BUS E - Low
U0071 Vehicle Communications BUS E - High
U0072 BUS E vehicle communication - shorted at BUS D +
U0073 Communication control module BUS OFF
U0100 Not communicating with Engine / Electric control module (ECM / PCM) "A"
U0101 Cannot communicate with the Transmission Control Module (TCM).
U0102 Cannot communicate with Transfer Cace Control module.
U0103 Cannot communicate with Gear Shift Module.
U0104 Cannot communicate with Speed control module
U0105 cannot communicate with Injector control module
U0106 Cannot communicate with Mide control burner
U0107 Cannot communicate with Midal control throttle
U0108 Cannot communicate with Mild fuel control
U0109 Cannot communicate with Mild balance controls the fuel pump
U0110 cannot communicate with Mid-range motor driver control
U0111 Cannot communicate with Mild balance controls energy battery "A"
U0112 cannot communicate with No balance controls energy battery "B"
U0113 Cannot communicate with Exhaust data control unit
U0114 Cannot communicate with 4-wheel drive clutch control module
U0115 Cannot communicate with ECM / PCM “B”.
U0121 cannot communicate with ABS braking system control module
U0122 cannot communicate with Vehicle control module
U0123 cannot communicate with Yaw RAte Sensor Module
U0124 Cannot communicate with Throttle sensor module
U0125 cannot communicate with Multi-axle throttle sensor module
U0126 Cannot communicate with Steering Angle Sensor Module
U0127 Cannot communicate with Tire pressure control module
U0128 cannot communicate with Handbrake control module
U0129 cannot communicate with Brake control module
U0130 cannot communicate with Steering wheel control module
U0131 cannot communicate with Power steering control module
U0132 cannot communicate with The module controls the drive level.
U040 cannot communicate with Body control module
U0141 cannot communicate with Body control module "A"
U0142 cannot communicate with Body control module "B"
U0143 cannot communicate with Body control module "C"
U0144 Could not communicate with Body control module "D"
U0145 Cannot communicate with Body control module "E"
U0146 Unable to communicate with Gateway “A”.
U0147 Unable to communicate with Gateway “B”.
U0148 Unable to communicate with Gateway “C”.
U0149 Unable to communicate with Gateway “D”.
U0150 cannot communicate with Gateway “E”.
U0151 Unable to communicate with Restraints control module
U0152 Unable to communicate with Restraints control module (left)
U0153 Unable to communicate with Restraints control module (right
U0154 Unable to communicate with Oecupant Sening control module.
U0155 cannot communicate with The light control module is shown on the face powder.
U0156 Could not communicate with Central Information "A"
U0157 Could not communicate with Global information "B"
U0158 Cannot communicate with Head Up Display.
U0159 Cannot communicate with Parking Assist control module
U0160 cannot communicate with Alarm control module
U0161 Cannot communicate with Campass control module.
U0162 Cannot communicate with Display navigation control module.
U0163 Cannot communicate with the navigation control module
U0164 Cannot communicate with heater and cooling control modules
U0165 Cannot communicate with heater and cooling control module (back)
U0166 Cannot communicate with the heater control module
U0167 Unable to communicate with Vehicle lmmobillzer control module.
U0168 Unable to communicate with vehicle security control module
U0169 Cannot communicate with sunroof control module
The U0170 cannot communicate with the control module “Restraints system Sensor A”.
U0171 Cannot communicate with control module “Restraints system Sensor B”.
U0172 Cannot communicate with control module “Restraints system Sensor C”.
U0173 Cannot communicate with control module “Restraints system Sensor D”.
U0174 Cannot communicate with control module “Restraints system Sensor E”.
U0175 Cannot communicate with control module “Restraints system Sensor F”.
U0176 Cannot communicate with control module “Restraints system Sensor G”.
U0177 Cannot communicate with control module “Restraints system Sensor H”.
U0178 Cannot communicate with control module “Restraints system Sensor I”.
U0179 Cannot communicate with control module “Restraints system Sensor J”.
The U0180 cannot communicate with the automatic lighting control module.
U0181 Unable to communicate with large lamp level control module.
U0182 Cannot communicate with headlight level control module.
U0183 Unable to communicate with backlight level control module
U0184 cannot communicate with radio
U0185 Cannot communicate with antenna control module.
U0186 cannot communicate with Ampify Radio
U0187 cannot communicate with Playback / Switch control module via CD Digiitel “A”.
U0188 cannot communicate with Playback / Switch control module via CD Digiitel “B”.
U0189 cannot communicate with Playback / Switch control module via CD Digiitel “C”.
U0190 cannot communicate with Playback / Switch control module via CD Digiitel “D”.
U0191 cannot communicate with TV
U0192 Unable to communicate with pc computer personal computer
U0193 Cannot communicate with private digital radio control module.
The U0194 cannot communicate with digital radio control module “A”.
The U0195 cannot communicate with digital radio control module “B”.
U0196 Could not communicate with Back seat entertainment
U0197 Cannot communicate with Telecommunication control module
U0198 Could not communicate with Automatic phone module
U0199 Could not communicate with Door control module "A
U0200 cannot communicate with Door control module "B"
U0201 cannot communicate with Door control module "C"
U0202 cannot communicate with Door control module "D"
U0203 cannot communicate with Door control module "E"
U0204 cannot communicate with Door control module "F
U0205 cannot communicate with Door control module "G"
U0206 Cannot communicate with Folding Top control module.
U0207 cannot communicate with The module controls the movement, turn on and off after the
U0208 cannot communicate with Seat control module "A"
U0209 cannot communicate with Seat control module "B"
U0210 Cannot communicate with Seat control module `` C ''
U0211 Cannot communicate with Seat control module "D"
U0212 Cannot communicate with Steering column control module
U0213 Cannot communicate with Side rearview mirror control module
U0214 Cannot communicate with Remote operation
U0215 Cannot communicate with door switch “A”.
U0216 Cannot communicate with door switch “B”.
U0217 Cannot communicate with door switch “C”.
U0218 Cannot communicate with door switch “D”.
U0219 Cannot communicate with door switch “E”.
U0220 Cannot communicate with door switch “F”.
U0221 Cannot communicate with door switch “G”.
U0222 cannot communicate with Window door motor "A
U0223 cannot communicate with Window door motor "B"
U0224 cannot communicate with Window door motor "C"
U0225 cannot communicate with Window door motor "D"
U0226 cannot communicate with Window door motor "E"
U0227 cannot communicate with Window door motor "F"
U0228 Cannot communicate with Window door motor "G"
U0229 Cannot communicate with Heated Steering Wheel module.
U0230 Cannot communicate with gate module
U0231 Cannot communicate with module knowing it is raining
U0232 Cannot communicate with The control module must be thrown to the side (left).
U0233 Cannot communicate with The control module must catch an obstacle to the side (right).
U0234 cannot communicate with Control module, recursion, comfort
U0235 Cannot communicate with the speed sensor
U0300 Software control module is not accepted.
· Administrator
Discussion Starter · #11 · (Edited)
P001 - P0194
P0201 - P0433
P0434 - P0640
P0846 - P0920
P0921 - P1321
P1322 - P1791
P1792 - P2130
P2131 - P2715
P2716 - U0010
U0011 - U300
U301 - U0327
U0301 softwares not accepted with engine / electric control modules (ECM / PCM).
U0302 Softwares not accepted with transmission control modules
U0303 Software not accepted with Transfer Case control module.
U0304 Softwares not accepted with Gear Fhift control module.
U0305 Softwares not accepted with speed control modules
U0306 Softwares not accepted with fuel injector control module
U0307 Softwares not accepted with burner control modules
U0308 Softwares not accepted with throttle control modules
U0309 Softwares not accepted with fuel control module
U0310 Softwares not accepting fuel pump control module
U0311 Softwares not accepting driver motor control modules
U0312 Softwares not accepted with battery power control module "A"
U0313 Softwares not accepted with battery power control module "B"
U0314 Softwares not accepted with 4-wheel drive clutch control module
U0315 Softwares not accepted with ABS brake control module
U0316 Softwares not accepted with drive car control modules
U0317 Softwares not accepted with hand brake control module
U0318 Softwares not accepting brake control modules
U0319 Softwares not accepted with steering wheel control modules
U0320 Softwares not accepting power steering control modules
U0321 Softwares not accepted with drive level control modules
U0322 Softwares not accepted with body control modules
U0323 Softwire not accepting the headlight control module
U0324 Software does not accept heater and cooling control modules.
U0325 Softwares not accepted with room heater control module
U0326 Software does not accept lmmoditizer control module.
U0327 Softwares not accepted with vehicle power-free control modules
1 - 11 of 11 Posts
