Before i start removing panels, can anyone tell me how to access the obd2 port on the Cruze?
Pics please if possible.
Thanks so much!
Thanks so much!
Knee pads is the only tool I can think of, but that is optional, its right there under the lower left dash panel in plain site. Not sure what good it will do you, my OBD II scanner wouldn't pick up the C0504 steering code. Dealer has all brand new stuff, told me even his GM Tech II scanner is worthless.Thanks for the info. What panels do i need to remove to get to it, and what tools are required?
What some probably are not realizing is, how lucky you & I are, but my DLC was actually not where it was supposed to be... took it to the dealership & they found my cars DLC tucked way up in dash & it had to pulled back into the holder. See thread labeled Torque... for more info. & pics.Before i start removing panels, can anyone tell me how to access the obd2 port on the Cruze?
Thanks so much!
That's where it's kept from the time it's installed in the car to the time the underdash mount is installed. Apparently someone didn't pull it down after installing the undermount dash.What some probably are not realizing is, how lucky you & I are, but my DLC was actually not where it was supposed to be... took it to the dealership & they found my cars DLC tucked way up in dash & it had to pulled back into the holder. See thread labeled Torque... for more info. & pics.
Sent from my Galaxy Nexus using AutoGuide.Com Free App
Hi there, I'm not sure if you're still looking, but I found your car's obd if you're still looking for it: Odbfinder.comBefore i start removing panels, can anyone tell me how to access the obd2 port on the Cruze?
Thanks so much!
