P0379 Timing Reference High Resolution Signal B No Pulses ,Ignition System
P0380 Glow Plug/Heater Circuit A Malfunction ,Diesel
P0381 Glow Plug/Heater Indicator Circuit Malfunction ,Diesel
P0382 Exhaust Gas Recirculation Flow Malfunction ,Emissions
P0385 Crankshaft Position (CKP) Sensor B Circuit ,Sensors
P0386 Crankshaft Position (CKP) Sensor B Performance ,Sensors
P0387 Crankshaft Position Sensor B Circuit Low Input ,Sensors
P0388 Crankshaft Position Sensor B Circuit High Input ,Sensors
P0389 Crankshaft Position Sensor B Circuit Intermittent ,Sensors
P0390 Exhaust Camshaft Position (CMP) Bank 2 Sensor Circuit ,Cam Phasing
P0391 Exhaust Camshaft Position Sensor Circuit Range/Performance Bank 2,Cam Phasing
P0400 Exhaust Gas Recirculation Flow Malfunction ,Emissions
P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient ,Emissions
P0402 Exhaust Gas Recirculation Flow Excessive Detected ,Emissions
P0403 Exhaust Gas Recirculation (EGR) Solenoid Control Circuit ,Emissions
P0404 Exhaust Gas Recirculation (EGR) Open Position Performance ,Emissions
P0405 Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage ,Emissions
P0406 Exhaust Gas Recirculation Sensor A Circuit High ,Emissions
P0407 Exhaust Gas Recirculation Sensor B Circuit Low ,Emissions
P0408 Exhaust Gas Recirculation Sensor B Circuit High ,Emissions
P0410 Secondary Air Injection (AIR) System ,Emissions
P0411 Secondary Air Injection (AIR) System ,Emissions
P0412 Secondary Air Injection (AIR) Solenoid Relay Control Circuit Bank 1 ,Emissions
P0413 Secondary Air Injection System Switching Valve A Circuit Open ,Emissions
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted ,Emissions
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction ,Emissions
P0416 Secondary Air Injection System Switching Valve B Circuit Open ,Emissions
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted ,Emissions
P0418 Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 1 ,Emissions
P0419 Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 2 ,Emissions
P0420 Catalyst System Low Efficiency ,Emissions
P042E Exhaust Gas Recirculation A Control Stuck Open ,Emissions
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1) ,Emissions
P0422 Catalyst System Low Efficiency Bank 1 ,Emissions
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1) ,Emissions
P0424 Heated Catalyst Temperature Below Threshold (Bank 1) ,Emissions
P0430 Catalyst System Low Efficiency Bank 2 ,Emissions
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2) ,Emissions
P0432 Catalyst System Low Efficiency Bank 2 ,Emissions
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2) ,Emissions
P0434 Heated Catalyst Temperature Below Threshold (Bank 2) ,Emissions
P043E Evaporative Emission System Leak Detection Reference Orifice Low Flow ,Emissions
P043F Evaporative Emission System Leak Detection Reference Orifice High Flow ,Emissions
P0440 Evaporative Emission (EVAP) System ,Emissions
P0441 Evaporative Emission Control System Incorrect Purge Flow ,Emissions
P0442 Evaporative Emission (EVAP) System Small Leak Detected ,Emissions
P0443 EVAP Purge Solenoid Valve 1 Control Circuit ,Emissions
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open ,Emissions
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted ,Emissions
P0446 EVAP Vent Solenoid Valve Control System ,Emissions
P0447 Evaporative Emission Control System Vent Control Circuit Open ,Emissions
P0448 Evaporative Emission Control System Vent Control Circuit Shorted ,Emissions
P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit ,Emissions
P0450 Fuel Tank Pressure Sensor Circuit ,Emissions
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance ,Emissions
P0452 Fuel Tank Pressure Sensor Circuit Low Voltage ,Emissions
P0453 Fuel Tank Pressure Sensor Circuit High Voltage ,Emissions
P0454 Evaporative Emission Control System Pressure Sensor Intermittent ,Emissions
P0455 Evaporative Emission (EVAP) System Leak Detected ,Emissions
P0458 Evaporative Emission System Purge Control Valve Circuit Low,Emissions
P0459 Evaporative Emission System Purge Control Valve Circuit High,Emissions
P0460 Fuel Level Sensor Circuit ,Sensors
P0461 Fuel Level Sensor Performance ,Sensors
P0462 Fuel Level Sensor Circuit Low Voltage ,Sensors
P0463 Fuel Level Sensor Circuit High Voltage ,Sensors
P0464 Fuel Level Sensor Circuit Intermittent ,Sensors
P0465 Purge Flow Sensor Circuit Malfunction ,Emissions
P0466 Purge Flow Sensor Circuit Range/Performance ,Emissions
P0467 Purge Flow Sensor Circuit Low Input ,Emissions
P0468 Purge Flow Sensor Circuit High Input ,Emissions
P0469 Purge Flow Sensor Circuit Intermittent ,Emissions
P0470 Exhaust Pressure Sensor Malfunction ,Emissions
P0471 Exhaust Pressure Sensor Range/Performance ,Emissions
P0472 Exhaust Pressure Sensor Low ,Emissions
P0473 Exhaust Pressure Sensor High ,Emissions
P0474 Exhaust Pressure Sensor Intermittent ,Emissions
P0475 Exhaust Pressure Control Valve Malfunction ,Emissions
P0476 Exhaust Pressure Control Valve Range/Performance ,Emissions
P0477 Exhaust Pressure Control Valve Low ,Emissions
P0478 Exhaust Pressure Control Valve High ,Emissions
P0479 Exhaust Pressure Control Valve Intermittent ,Emissions
P0480 Cooling Fan Relay 1 Control Circuit ,Cooling
P0481 Cooling Fan Relay 2 Control Circuit ,Cooling
P0482 Cooling Fan 3 Control Circuit Malfunction ,Cooling
P0483 Cooling Fan Rationality Check Malfunction ,Cooling
P0484 Cooling Fan Circuit Over Current ,Cooling
P0485 Cooling Fan Power/Ground Circuit Malfunction,Cooling
P0493 Cooling Fan Overspeed,Cooling
P0495 Cooling Fan Speed High,Cooling
P0496 Evaporative Emission (EVAP) System Flow During Non-Purge ,Emissions
P0497 Evaporative Emission System Low Purge Flow,Emissions
P0498 Evaporative Emission System Vent Valve Control Circuit Low,Emissions
P0499 Evaporative Emission System Vent Valve Control Circuit High,Emissions
P0500 Vehicle Speed Sensor (VSS) Circuit ,Sensors
P0501 Vehicle Speed Sensor Range/Performance ,Sensors
P0502 Vehicle Speed Sensor (VSS) Circuit Low Input ,Sensors
P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent ,Sensors
P0505 Idle Control System Malfunction ,ETC Control
P0506 Idle Speed Low ,ETC Control
P0507 Idle Speed High ,ETC Control
P050A Cold Start Idle Air Control System Performance,ETC Control
P050B Cold Start Ignition Timing Performance,Engine Operation
P050D Cold Start Rough Idle,Engine Operation
P050E Cold Start Engine Exhaust Temperature Too Low,Engine Operation
P050F Brake Assist Vacuum Too Low
P0510 Closed Throttle Position Switch Malfunction ,ETC Control
P0512 Start Switch Circuit
P0513 Incorrect Immobilizer Key ,Security
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction ,Sensors
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance ,Sensors
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage ,Sensors
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage ,Sensors
P0526 Cooling Fan Speed Sensor Circuit ,Cooling
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction ,Air Conditioning
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance ,Air Conditioning
P0532 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage ,Air Conditioning
P0533 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage ,Air Conditioning
P0534 Air Conditioner Refrigerant Charge Loss ,Air Conditioning
P0550 Power Steering Pressure (PSP) Switch Circuit
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0556 Brake Booster Pressure Sensor Circuit Range/Performance
P0557 Brake Booster Pressure Sensor Circuit Low
P0558 Brake Booster Pressure Sensor Circuit High
P0560 System Voltage
P0561 System Voltage Unstable
P0562 System Voltage Low (TCM) ,Transmission
P0563 System Voltage High (TCM) ,Transmission
P0564 Cruise Control Multi-Function Switch Circuit (PCM)
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P056C Cruise Control Coast System Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control Brake Switch Circuit
P0572 Cruise/Brake Switch Circuit Low Input Conditions
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Vehicle Speed Too High above 110 mph Cruise Control Disabled
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P057C Cruise Control Related Malfunction
P057D Cruise Control Related Malfunction
P057E Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
P0581 Cruise Control Multi-Function Input A Circuit High
P0597 Thermostat Heater Control Circuit/Open,Cooling
P0598 Thermostat Heater Control Circuit Low,Cooling
P0599 Thermostat Heater Control Circuit High,Cooling
P0600 Serial Communication Link Malfunction
P0601 Control Module Read Only Memory (ROM)
P0602 Control Module Not Programmed
P0603 Control Module Long Term Memory Reset
P0604 Control Module Random Access Memory (RAM)
P0605 Control Module Programming Read Only Memory (ROM)
P0606 Control Module Internal Performance
P0607 ECU Malfunction
P0608 Control Module VSS Output A Malfunction
P0609 Control Module VSS Output B Malfunction
P0610 Control Module Vehicle Options Incorrect
P0611 Fuel Injector Control Module Performance ,Injector Control
P0615 Starter Relay Control Circuit
P0616 Starter Relay Control Circuit Low Voltage
P0617 Starter Relay Control Circuit High Voltage
P0620 Generator Control Circuit Malfunction
P0621 Generator L-Terminal Circuit
P0622 Generator F-Terminal Circuit
P0625 Generator F-Terminal Circuit Low Voltage
P0626 Generator F-Terminal Circuit High Voltage
P0627 Fuel Pump A Control Circuit/Open,Fuel Pump
P0628 Fuel Pump Relay Control Circuit Low Voltage ,Fuel Pump
P0629 Fuel Pump Relay Control Circuit High Voltage ,Fuel Pump
P062B Internal Control Module Fuel Injector Control Performance,Injector Control
P062F Control Module Long Term Memory Performance
P0630 VIN Not Programmed or Mismatched — Engine Control Module (ECM),Security
P0633 Immobilizer Key Not Programmed,Security
P0638 Throttle Actuator Control (TAC) Command Performance ,ETC Control
P0641 PCM voltage out of tolerance condition on the 5-volt reference circuit
P0642 Sensor Reference Voltage A Circuit Low
P0643 Sensor Reference Voltage A Circuit High
P0645 Air Conditioning (A/C) Clutch Relay Control Circuit ,Air Conditioning
P0646 Air Conditioning (A/C) Clutch Relay Control Circuit ,Air Conditioning
P0647 Air Conditioning (A/C) Clutch Relay Control Circuit ,Air Conditioning
P064D Internal Control Module O2 Sensor Processor Performance Bank 1,O2 Sensor
P0650 Malfunction Indicator Lamp (MIL) Control Circuit
P0651 PCM voltage out of tolerance condition on the 5-volt reference circuit
P0652 Sensor Reference Voltage B Circuit Low
P0653 Sensor Reference Voltage B Circuit High
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfucntion
P0656 Fuel Level Output Circuit Malfunction
P0660 Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit
P0661 Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit Low Voltage
P0662 Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit High Voltage
P0685 Engine Controls Ignition Relay Control Circuit (PCM)
P0686 ECM/PCM Power Relay Control Circuit Low
P0687 ECM/PCM Power Relay Control Circuit High
P0689 ECM/PCM Power Relay Sense Circuit Low
P0690 ECM/PCM Power Relay Sense Circuit High
P0691 Cooling Fan Relay Control Circuit Low Voltage ,Cooling
P0693 Cooling Fan Relay Control Circuit Low Voltage ,Cooling
P0692 Cooling Fan Relay Control Circuit High Voltage ,Cooling
P0694 Cooling Fan Relay Control Circuit High Voltage ,Cooling
P0695 Cooling Fan 3 Control Circuit Low,Cooling
P0696 Cooling Fan 3 Control Circuit High,Cooling
P0697 Sensor Reference Voltage C Circuit/Open
P0698 Sensor Reference Voltage C Circuit Low
P0699 Sensor Reference Voltage C Circuit High
P069E Fuel Pump Control Module Requested MIL Illumination
P06A3 5V Reference 4 Circuit
P06AF Torque Management System - Forced Engine Shutdown
P06B6 Control Module Knock Sensor Processor 1 Performance ,Ignition System
P06B7 Control Module Knock Sensor Processor 2 Performance,Ignition System
P06E4 No Additional Information
P0700 Transmission Control System Malfunction ,Transmission
P0701 Transmission Control System Range/Performance ,Transmission
P0702 Transmission Control System Electrical ,Transmission
P0703 Brake Switch Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Trans Range Switch Circuit ,Transmission
P0706 Trans Range Switch Performance ,Transmission
P0707 Transmission Range Sensor Circuit Low Input ,Transmission
P0708 Transmission Range Sensor Circuit High Input ,Transmission
P0709 Transmission Range Sensor Circuit Intermittent ,Transmission
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction ,Transmission
P0711 TFT Sensor Circuit Range/Performance ,Transmission
P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input ,Transmission
P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input ,Transmission
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent ,Transmission
P0715 Input/Turbine Speed Sensor Circuit Malfunction ,Transmission
P0716 Input Speed Sensor Circuit Intermittent ,Transmission
P0717 Input Speed Sensor Circuit Low Input ,Transmission
P0718 Input/Turbine Speed Sensor Circuit Intermittent ,Transmission
P0719 Brake Switch Circuit Low Input
P071A Transmission Tow Mode Switch Circuit,Transmission
P071D Transmission Mode Switch B Circuit,Transmission
P0720 Output Speed Sensor Circuit Malfunction ,Transmission
P0721 Output Speed Sensor Range/Performance ,Transmission
P0722 Output Speed Sensor Circuit Low Input ,Transmission
P0723 Output Speed Sensor Intermittent ,Transmission
P0724 Brake Switch Circuit High Input
P0725 Engine Speed Input Circuit
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio ,Transmission
P0731 Incorrect 1st Gear Ratio ,Transmission
P0732 Incorrect 2nd Gear Ratio ,Transmission
P0733 Incorrect 3rd Gear Ratio ,Transmission
P0734 Incorrect 4th Gear Ratio ,Transmission
P0735 Gear 5 Incorrect ratio ,Transmission
P0736 Reverse incorrect gear ratio ,Transmission
P0740 TCC Enable Solenoid Circuit Electrical ,Transmission
P0741 TCC System Stuck Off ,Transmission
P0742 TCC System Stuck On ,Transmission
P0743 TCC Enable Solenoid Circuit Electrical ,Transmission
P0744 Torque Converter Clutch Circuit Intermittent ,Transmission
P0745 Pressure Control Solenoid Malfunction ,Transmission
P0746 Pressure Control Solenoid Performance or Stuck Off ,Transmission
P0747 Pressure Control Solenoid Stuck On ,Transmission
P0748 Pressure Control Solenoid Circuit Electrical ,Transmission
P0749 Pressure Control Solenoid Intermittent ,Transmission
P0750 Shift Solenoid A Malfunction ,Transmission
P0751 1-2 Shift Solenoid Valve Performance No First or Fourth Gear ,Transmission
P0752 1-2 Shift Solenoid Valve Performance No Second or Third Gear ,Transmission
P0753 1-2 Shift Solenoid Circuit Electrical ,Transmission
P0754 Shift Solenoid A Intermittent ,Transmission
P0755 Shift Solenoid B Malfunction ,Transmission
P0756 2-3 Shift Solenoid Valve Performance No First or Second Gear ,Transmission
P0757 2-3 Shift Solenoid Valve Performance No Third or Fourth Gear ,Transmission
P0758 2-3 Shift Solenoid Circuit Electrical ,Transmission
P0759 Shift Solenoid B Intermittent ,Transmission
P0760 Shift Solenoid C Malfunction ,Transmission
P0761 Shift Solenoid C Performance or Stuck Off ,Transmission
P0762 Shift Solenoid C Stuck On ,Transmission
P0763 Shift Solenoid C Electrical ,Transmission
P0764 Shift Solenoid C Intermittent ,Transmission
P0765 Shift Solenoid D Malfunction ,Transmission
P0766 Shift Solenoid D Performance or Stuck Off ,Transmission
P0767 Shift Solenoid D Stuck On ,Transmission
P0768 Shift Solenoid D Electrical ,Transmission
P0769 Shift Solenoid D Intermittent ,Transmission
P0770 Shift Solenoid E Malfunction ,Transmission
P0771 Shift Solenoid E Performance or Stuck Off ,Transmission
P0772 Shift Solenoid E Stuck On ,Transmission
P0773 Shift Solenoid E Electrical ,Transmission
P0774 Shift Solenoid E Intermittent ,Transmission
P077B Output Speed Sensor Direction Incorrect ,Transmission
P07B5 Transmission Park Position Sensor/Switch A Circuit Performance/Low,Transmission
P07B6 Transmission Park Position Sensor/Switch A Circuit Performance High,Transmission
P0780 Shift Malfunction ,Transmission
P0781 1-2 Shift Malfunction ,Transmission
P0782 2-3 Shift Malfunction ,Transmission
P0783 3-4 Shift Malfunction ,Transmission
P0784 4-5 Shift Malfunction ,Transmission
P0785 3-2 Shift Solenoid Circuit Electrical ,Transmission
P0786 Shift/Timing Solenoid Range/Performance ,Transmission
P0787 Shift/Timing Solenoid Low ,Transmission
P0788 Shift/Timing Solenoid High ,Transmission
P0789 Shift/Timing Solenoid Intermittent ,Transmission
P0790 Normal/Performance Switch Circuit Malfunction ,Transmission
P0800 Transfer Case Control System (MIL Request),Transmission
P0801 Reverse Inhibit Control Circuit Malfunction ,Transmission
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction ,Transmission
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction ,Transmission
P0806 Clutch Position Sensor Circuit Range/Performance,Transmission
P0807 Clutch Position Sensor Circuit Low,Transmission
P0808 Clutch Position Sensor Circuit High,Transmission
P080A Clutch Position Not Learned,Transmission
P080C Upshift/Skip Shift Solenoid Control Circuit Low,Transmission
P080D Upshift/Skip Shift Solenoid Control Circuit High,Transmission
P0812 Reverse Position Switch Circuit Malfunction ,Transmission
P0831 Clutch Pedal Switch A Circuit Low,Transmission
P0833 Clutch Pedal Switch B Circuit,Transmission
P0850 Park/Neutral Position (PNP) Switch Circuit ,Transmission
P0851 Park/Neutral Position (PNP) Switch Circuit Low Voltage,Transmission
P0852 Park/Neutral Position (PNP) Switch Circuit High Voltage,Transmission
P0856 Powertrain Indicated Traction Control Malfunction
P086A No Additional Information
P086B No Additional Information
P086C No Additional Information
P086D No Additional Information
P086F No Additional Information
P0894 Transmission Component Slipping ,Transmission
P0897 PCM detects a calculated transmission fluid life of 10 percent or less ,Transmission
P0962 Line Pressure Control (PC) Solenoid Control Circuit Low Voltage (TCM) ,Transmission
P0963 Line Pressure Control (PC) Solenoid Control Circuit High Voltage (TCM) ,Transmission
P0966 Clutch Pressure Control (PC) Solenoid Control Circuit Low Voltage (TCM) ,Transmission
P0967 Clutch Pressure Control (PC) Solenoid Control Circuit High Voltage (TCM) ,Transmission
P0970 Shift Pressure control (PC) Solenoid Control Circuit Low Voltage (TCM) ,Transmission
P0971 Shift Pressure Control (PC) Solenoid Control High Voltage (TCM) ,Transmission
P0973 PCM detects an open or short to ground in the 1-2 SS valve circuit ,Transmission
P0974 PCM detects a continuous short to voltage in the 1-2 SS valve circuit ,Transmission
P0976 PCM detects a continuous open or short to ground in the 2-3 SS valve circuit ,Transmission
P0977 PCM detects a continuous short to voltage in the 2-3 SS valve circuit ,Transmission
P0979 Shift Solenoid (SS) 3 Control Circuit Low Voltage (TCM) ,Transmission
P0980 Shift Solenoid (SS) 3 Control Circuit High Voltage (TCM) ,Transmission
P0982 Shift Solenoid (SS) 4 Control Circuit High Voltage (TCM) ,Transmission
P0983 Shift Solenoid (SS) 4 Control Circuit High Voltage (TCM) ,Transmission
P0985 Shift Solenoid (SS) 5 Control Circuit Low Voltage (TCM) ,Transmission
P0986 Shift Solenoid (SS) 5 Control Circuit High Voltage (TCM) ,Transmission
P0A01 Motor Electronics Coolant Temperature Sensor Circuit Range/Performance,Hybrid
P0A02 Motor Electronics Coolant Temperature Sensor Circuit Low,Hybrid
P0A03 Motor Electronics Coolant Temperature Sensor Circuit High,Hybrid
P0A05 Motor Electronics Coolant Pump A Control Circuit/Open,Hybrid
P0A06 Motor Electronics Coolant Pump A Control Circuit Low,Hybrid
P0A07 Motor Electronics Coolant Pump A Control Circuit High,Hybrid
P0A1D Hybrid Powertrain Control Module Internal Performance ,Hybrid
P0AB9 Hybrid System Performance ,Hybrid
P0AC4 Hybrid Powertrain Control Module Requested MIL Illumination ,Hybrid
P0B38 Motor Electronics Coolant Pump B Control Circuit/Open,Hybrid
P0B39 Motor Electronics Coolant Pump B Control Circuit Low,Hybrid
P0B3A Motor Electronics Coolant Pump B Control Circuit High,Hybrid
P1031 Heated Oxygen Sensor (HO2S) Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1 ,O2 Sensor
P1032 Heated Oxygen Sensor (HO2S) Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1 ,O2 Sensor
P1101 Actual measured airflow from MAF, MAP, EGR, and TP is not within range of the calculated airflow ,Sensors
P1105 Secondary Vacuum Sensor Circuit ,Sensors
P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage ,Sensors
P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage ,Sensors
P1108 BARO to MAP Sensor Comparison Too High ,Sensors
P1109 Secondary Port Throttle System ,ETC Control
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage ,Sensors
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage ,Sensors
P1113 Intake Resonance Switchover Solenoid Control Circuit
P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage ,Sensors
P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage ,Sensors
P1116 ECT Signal Unstable or Intermittent ,Sensors
P1117 Engine Coolant Temp. Signal Out-Of-Range Low ,Sensors
P1118 Engine Coolant Temp. Signal Out-Of-Range High ,Sensors
P1119 ECT Signal Out-Of-Range With TFT Sensor ,Sensors
P111E No Additional Information
P1120 Throttle Position (TP) Sensor 1 Circuit ,ETC Control
P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage ,ETC Control
P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage ,ETC Control
P1125 Accelerator Pedal Position (APP) System ,ETC Control
P112B Intake Air Temperature (IAT) Sensor 3 Performance,Sensors
P112C Intake Air Temperature (IAT) Sensor 3 Circuit Low Voltage,Sensors
P112D Intake Air Temperature (IAT) Sensor 3 Circuit High Voltage,Sensors
P112E Intake Air Temperature (IAT) Sensor 3 Circuit Intermittent,Sensors
P112F No Additional Information
P1130 Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 1 ,O2 Sensor
P1131 Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 2 ,O2 Sensor
P1132 Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 2 Sensor 1 ,O2 Sensor
P1133 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1 ,O2 Sensor
P1134 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1 ,O2 Sensor
P1135 Heated Oxygen Sensor (HO2S) Lean Mean Bank 1 Sensor 1 ,O2 Sensor
P1136 Heated Oxygen Sensor (HO2S) Rich Mean Bank 1 Sensor 1 ,O2 Sensor
P1137 Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Lean System or Low Voltage ,O2 Sensor (Rear)
P1138 Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Rich or High Voltage ,O2 Sensor (Rear)
P1139 Heated Oxygen Sensor (HO2S) Insuff. Switching Bank 1 Sensor 2 ,O2 Sensor (Rear)
P1140 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 2 ,O2 Sensor (Rear)
P1141 Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2 ,O2 Sensor (Rear)
P1143 Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Lean System or Low Voltage ,O2 Sensor
P1144 Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Rich or High Voltage ,O2 Sensor
P1145 Heated Oxygen Sensor (HO2S) Cross Counts Bank 1 Sensor 3 ,O2 Sensor
P1153 Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1 ,O2 Sensor
P1154 Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1 ,O2 Sensor
P1155 Heated Oxygen Sensor (HO2S) Lean Mean Bank 2 Sensor 1 ,O2 Sensor
