So basically when I originally bought the car, the heat would not work at all so I took it in to get serviced and it turns out there was basically no coolant in it. They checked for leaks and everything and ended up repairing or installing a new water pump, one of the two.
Anyways, since that repair the heat has worked just fine, but I notice an odor MOSTLY when the car sits idle for awhile (overnight, during work before or after lunch, etc.).
I originally thought it smelled a lot like fuel and thought there was a huge issue, then I kind of thought it smells like an exhaust leak, but now I don't know if it's just a coolant odor leak or something (read a few posts regarding Cruze coolant odor leaking into the cabin).
The smell is usually confined to the cabin and not outside of the vehicle but once I turn the car on, drive a bit, have the A/C and **** on, the odor disappears until the next long-idle period of time.
Does anyone have any ideas or quick/easy ways to check/verify what could be wrong?
Thank you!
