2012 Cruze 1LT RS 1.4L with 90,000 miles
Replaced Throttle Body(TB) at 65,000 miles
PCV/valve cover replaced at 72,000 miles
I have no check engine light on and no codes show when using Torque. The car is losing/hemorrhaging oil.
Driveway covered in oil, skid plate covered, just a mess under the motor!
Oil in the PCV pipe/hose, TB has oil in it, the outside of the charge air cooler inlet pipe is covered in oil.
While car is running/idle if you pull the dip stick and place your finger over it you can feel it pulling in air.
Turbo oil inlet is clean with no oil or oil residue on it. Actually the engine bay is pretty clean till you look under the car.
Here is a link to some photos of it:
https://goo.gl/photos/UNzV4eEG3fAcmp7f9
I would like some ideas before I go to the dealer and if the possible issue will be covered under the 100K Power train warranty.
Thank you.
Randy
Thank you.
Randy
