Merry Christmas to all!
My daughter arrived home from college last night in her 2011 1.4 turbo cruze and calls as she's pulling into the driveway after a 200 mile trip saying "come outside my car is smelling again". Recently she had the overflow reservoir crack, lost a bunch of coolant, and had the car overheat. Dealer fixed all this and claims that a pressure check was good and didn't believe the head gasket was blown or anything like that. They also did an oil change. This was 3 weeks ago. My first thought when she mentioned the smell was that there was probably some leftover coolant that was causing it. Well, I popped the hood and saw this!
I saw some smoke coming off the manifold and heat shield so I told her to shut it off. First thought was "oh God, it ran itself out of oil" so I pulled the dipstick - and to my surprise the level was completely full. I looked in the oil filter cap (not sure why exactly lol) and everything seemed fine. Then I had her start it again and rev to 2000, then 3000, then 4000... no spray anywhere that I could see. So she shut it off and it has sat since last night. I've done a ton of reading and it sounds like it could be as simple as the oil filler cap not having been seated correctly from the oil change (wish I would have known that so I would have been more conscious when I removed the cap to see if it was fully seated), or it could be a bad PCV component, or a turbo oil line seal, or perhaps other things I haven't come across yet. Given that nobody is open today/tomorrow and she was supposed to go back to school for work the morning of the 26th, I feel massive pressure to get this resolved and know 100% that I have done so. I can't put her back on the highway not knowing if it is fixed and risk her having a car fire or something. But the fact that I saw no spray, when the oil had clearly sprayed very recently, I'm a bit baffled. Any initial thoughts from you gurus on the most likely cause?
Thank you!
Thank you!
