2013 1.4L turbo, 61,000 miles: No codes or misfires, no unusual repairs or maintenance issues aside from brakes, oil changes, etc. Bought the car at about 12,000. Mobil 1 and Wix ever since. I find no signs of the dreaded PCV fault. No sucking sound, no oil in the throttle area, no noticeable oil consumption, no excessive cam cover leakage.
I recently changed out the spark plugs for the first time and inspected the cylinders with a borescope. I found that the plug from Cylinder 2 had some oil film on it. Not drippy but a film. The others were dry. Same with the cylinders. Cylinders 1, 3, 4 were dry with a slight carbon film. Cylinder 2 showed an oil film on the piston top. PLEASE NOTE: ALL SPARK PLUG WELLS WERE DRY. NO GASKET LEAKAGE.
The usual ways for oil to get into a cylinder, aside from coming in on the intake air, is ring leakage or valve guide leakage. My question: is there some fault in the 1.4L that is commonly known to leak oil into a cylinder?
Many thanks!
Many thanks!
