1 - 4 of 4 Posts
Well it was my turn for the PCV valve issue.
Car is just under 80K, started whistling and throwing the associated codes.
It really the worst possible timing for me.
My wife's car is in pieces as I'm doing the clutch, struts and and any worn bushing etc in the front end.
Just bought a house that needed some plumbing, electrical and general painting and decorating.
Really not in a place to have just my 20 year old S10 on the road.
All that being said my plan was to swap the valve cover and kick fixing the intake manifold down the road a few thousand miles.
Unfortunately when removing the sparkplugs i found #1 and #4 were soaked in (nice clean) oil.
I want ahead and ordered the check valve kit as I've seen on it stated several times here that it can cause oil to leak from every orifice
So aside from a failed gasket and/or the check valve is there anything else that could cause the oil seepage?
Also the OEM valve cover did not come with a gasket, but it is available to purchase.
It this a case where it is needed/strongly recommended or is it ok to just use RTV?
It is a type of 'O' ring that seats in the channel of the cover.....I've never seen a oem one without the ring pre-installed.
It is to be installed dry.....no sealants.
Discussion Starter #3
I missed the O ring. Thanks
In case anyone else reads this It does need two drops of ATV where the two parts of the head meet,
Replacing the cover cleared the check engine lights and the car is running much better.
Hard to tell but the gasket seemed broken around the plugs. I can't se ehat else would have caused the oil intrusion.
Unfortunately I have gotten a whiff or two of burnt oil which I noticed right before the PCV went the first time.
Maybe I'm being overly cautious but I'm minimizing driving till i get a chance to install the check valve kit. Hopefully that resolves it.
Let us know when your findings are conclusive.
1 - 4 of 4 Posts
About this Discussion
3 Participants
Blasirl
Chevrolet Cruze Forums
Full Forum Listing
