I'd check the manifold check valve for the PCV. When that goes, the engine starts leaking oil at it's seams. You may be treating the symptoms and not the disease.I have a 2011 cruze LT with a leaking oil housing that also requires removing and replacing the oil pan and costs associated.
I have noticeable stains on my driveway. Im not noticing a change in oil pressure/level however.
