2014 Cruse, 1.8, auto, 70K
It all started with a gurgle sound that would happen all the time when accelerating around 1200-1500rpm coming somewhere from the front engine area, checked the plugs all clean, replaced the plugs, a week later I find small amount of oil around one plugs, wiped the oil off. Couple of weeks later the rpm scale started acting up accompanying with small engine tremors / stutters in idle and also when driving. Checked the plugs and found small amount of oil again, cleaned the oil off and stuttering went away for a few days but then it returned again but this time jerking / stuttering didn't stop after cleaning the oil off and also all three lights came on stabilitrak, traction, and flashing check engine for the first time, barely made it home because of engine stutters and barely being able to accelerate. Few days later tried starting the car but only started momentarily before it shut off. I then found my coolant tank almost fully empty, puddle on the ground, puddle right below the thermostat housing. No oil around spark plug, it seems to leak only during when car is operational. There is black oil residue around the oil pan, black stain trail possibly going all the way up to the valve cover, small oil residue mark at left bottom corner of the valve gasket cover, can't tell for sure if that's where the main leak is coming from. Now the car won't start. I did try to test PCV valve a weekwith the car running and the valve outlet above the coil pack wasn't sucking air when I put my finger on the hole but when I would pull the oil dip stick out a hissing noise would come on from it and disappear when I put the dipstick back in. I am hoping it's all valve cover, PCV valve, and failed thermostat related but then I don't know if a failed PCV valve would cause the engine to die and not start. I drained some of the engine oil to inspect it and it looks normal, no metal shedding, nothing unusual. The first time I replaced the plugs the coil pack cylinders were clean but 2nd time later one of them had brown residue stains all over it as well inside two cylinder well walls. Another possible symptom was I noticed water dripping out of rear muffler pipe almost constantly which I haven't noticed in the past, haven't seen any white or black smoke. I did notice burnt oil odor sometimes when I turn the heat on inside the cabin for last couple of weeks and then it would disappear after a few minutes. I took a video of spark plug wells, under oil cap look inside the engine, moments when the car started and died on me and the noises it made, and a couple of videos of the oil leak around oil pan, serpentine belt, alternator area. I'm trying to share as many details as I can hoping someone had this type of issue and maybe knows what I'm dealing with here. Any thoughts will be appreciated
[Last time when started and died, the sound of crank and engine running just didn't sound right]
[Next day sound of crank no start]
[Three videos of all the tight spots where I spotted oil residue (oil pan, serpentine belt, alternator)]
[Spark plug cylinder wells]
Spark plugs
[Under oil cap inside the engine light sludge residue]
Under oil cap
Spark plugs
Under oil cap
