1 - 7 of 7 Posts
2012 Cruze 1.4L AT 75,000 miles
I just noticed drippings on my driveway on the drivers side engine compartment. When I look under the hood I can't see where it's coming from but it's pooling on the transmission right under the water outlet. I just did the valve cover gasket but all the way around still seems to be try.
TIA,
Jim
Check where the turbo oil line leave the block. I think the o rings had a tendency to leak there in the past.
Pull the air tube off and see how much oil you have in it. Would also make sure it was tight to begin with since you just did the valve cover. Some oil in the intake tube is normal.
Discussion Starter #6
Upon further review... I am an idiot. I checked while the car is running and it's coolant. I see bubbles coming from the top hose (expansion tank return hose?) on the water outlet manifold. I replaced the water outlet last year, didn't replace the hose. I am "guessing" it's the o-ring on the hose? Anyone know the official names / part numbers for these parts?
1 - 7 of 7 Posts
