I have a 2012 Cruze 1.8l, it keeps showing low oil pressure while idling but goes away when moving, the oil was just changed and has been well maintained since I've had the car, I had an overheating issue which I changed the thermostat, housing, heater hose, throttle cooling line, solved the heating problem. Had an issue after that of car running rough, loss of power, had it checked by a mechanic and ended up replacing the coil pack and plugs and replaced the valve cover gasket, it then started flashing low oil pressure, changed the oil pressure sensor and then had to fix the little plastic arm on the intake manifold positioning sensor, it still says oil pressure low, I am broke and have spent what little I had to try and repair this junking Chevy, when car broke down I lost my job because I couldn't drive it, I need this car moving and I have reached my end with this car, I don't know what to do at this point, I don't have the money to take it to the dealer and I know a little about working on cars but this is beyond me, I need help figuring this out, please any help would be greatly appreciated
