As requested, hope this is the right questionare:
- What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations)
A:Getting 29 to 34MPG highway, calculating manually and using the computer, which have pretty much the same results give or take a MPG.
- What fuel economy are you expecting and why?
A: Expecting between 38 and 42MPH, why because for the first several months I've owned the car thats what it got.
- What are the approximate outside air temps?
A: between 70 to 85 degrees, morning commute around 60
- How long are your trips?
A:25 miles per way, 4 times per day, All highway, 100 miles total per day Highway
How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night?
A:New car battery in new car, voltage between 12.6 and 14
Have you had your alignment checked? Any pulling or abnormal tire wear?
A: no alignment issues or tire wear.
- How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving?
A: 95% Highway, speeds between 65 and 72
- What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.)
A: Pretty even, only slight hills
- What are your tire pressures?
A: 38PSI all around
- Is your oil overfilled? (i.e. above the full mark on the dipstick)
A: Nope
- Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.)
A: 2007 chevrolet Aveo LS Automatic, Always got 34 to 36MPG for same trips
- What region/state are you in? (if you haven't set your location)
A: Central PA
- Are you using the factory tires and wheels? If not, please indicate tire make, model and size?
A: Factory Everything
- If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute?
A: Nope
