For the first time since ever, my Cruze overheated. '13 LT w/115k miles. The temp gauge was pegged to 'H'. The radiator fan was on high speed but was blowing cool air from the radiator. The upper radiator hose had no pressure. The coolant tank was pretty low. Like just about empty kind of low. I had some water with me so I put it in the tank but it didn't seem to go anywhere. Just filled the tank. If I squeezed the upper hose, it would move a little coolant and that coolant was pretty **** hot. Would the lack of pressure indicate a failing water pump? It's the original unit.
I let it cool off for a while then tried to drive home. I let it idle for maybe 10 minutes and the temp gauge seemed to behave. I started driving and within a quarter mile it climbed back onto 'H'. I swung a U-turn and doing that made the temp needle move around a bit then back to 'H'.
I don't want to just throw parts at it to fix it but based on past history, a water pump might be a good idea. Not sure if the temp sensors or thermostat is bad.
Any ideas?
Any ideas?
