2013 Cruze LT RS package
1.4L turbo 111k miles
Codes: P0016 & P0017 & P0171
Just picked this Cruze up 2 days ago, have been reading a lot and just want to make sure I'm on the right track.
I don't know the history of this vehicle, the oil was changed right before I got it, but the old sticker was left on and it was about 6k miles over due for a change when it was done.
The car seems to run well, cranks with no issue, idle is stable around 850RPM doesn't seem to hesitate when accelerating.
The AC compressor does not engage (I've checked all related fuses) and the Radiator fan doesn't not come on ever, I have checked the fuses and relays and it's not that. (It's not overheating) I am also getting P0016 and P0017 codes. The engine really doesn't sound bad, no loud noises, maybe some timing chain rattle. I plan on taking the valve cover off later when it cools down some.
I am also getting an engine oil pressure low warning stop engine warning
I want to check the camshaft position actuators and see if they could be gunked up first, then take the valve cover off and check the timing chain.
Just wanted to run this by and see if I'm missing anything before I start tearing into this thing
