P0102 code persists, running out of ideas..
6141 Views 5 Replies 4 Participants Last post by  Willis330
Info:
  • 2013 Chevrolet Cruze LTZ RS: 1.4 Turbo
  • 120,000 miles
  • Dorman Valve Cover installed
  • PCV Fix Kit V3 installed
Problem:
Check engine light is on, rough idle, and the only code showing is P0102, I have replaced and done many things on the engine and the code still showing and MAF reading is 0.1g/s.
This is the list of things I've tried:
  • Dorman Valve Cover and PCV Fix Kit V3 installed at the same time.
  • MAF sensor replaced.
  • MAF sensor Wiring harness visually inspected.
  • No vacuum leaks on intercooler and tubes/hoses
  • Crankcase resealed.
  • Crankshaft front seal replaced.
  • Oil gauge and cap O-rings replaced.
UPDATE:
Compression test results:
Cyl1: 120psi
Cyl2: 120psi
Cyl3: 120psi
Cyl4: 150psi
Any ideas?
Could it be the turbo itself? or hoping not to be the ECU?
Thank you!
It's not the turbo for this code. This code refers to Mass Air Flow (MAF) Sensor Circuit Low Frequency.
Information
MAF Sensor
Circuit
Short to Ground
Open/High Resistance
Short to Voltage
Signal Performance
Ignition Voltage​
P0102​
P0102, P01101​
P0690​
P0101​
Sensor
P0102, P1101​
P0102, P1101​
P0102*​
P0101, P1101​
Ground
P0102​
*Internal ECM or sensor damage may occur if the circuit is shorted to B+.
Trace wires of maf for any of these above.
B75C Multifunction Intake Air Sensor (LUJ)
Pin
Wire
Circuit
Function
1​
0.5 BN/GY​
4008​
Humidity Sensor Signal
2​
0.5 WH/RD​
3201​
Throttle Inlet Absolute Pressure Sensor 5V Reference
3​
0.5 GN/WH​
492​
Mass Air Flow Sensor Signal
4​
0.5 BK​
150​
Ground
5​
0.75 VT/BU​
5294​
Powertrain Main Relay Fused Supply (5)
6​
0.5 YE/WH​
3200​
Throttle Inlet Absolute Pressure Sensor Signal
7​
0.5 BK/VT​
2760​
Intake Air Temperature Sensor Low Reference
8​
0.5 BN/VT​
472​
Intake Air Temperature Sensor Signal
Since you have replaced the MAF, it shouldn't be dirty or failed, but I would clean it anyway with MAF cleaner. I would also take apart the connection and blow out both sides with air and reconnect. If those things don't change anything, I would use the info Miguelcon74 gave you to trace out the wiring.
Potential causes for this trouble code, P0102, may include:
Dirty or contaminated mass air flow sensor
Failed MAF sensor
Intake air leaks MAF sensor electrical harness or wiring problem (open, shorted, frayed, poor connection, etc.)
Note that other codes may be present if you have a P0102. You may have misfire codes or O2 sensor codes, so it's important to take a "big picture" look at how the systems work together and effect each other when doing a diagnosis.
Read more at: P0102 Mass Airflow (MAF) Circuit High
Information
MAF Sensor
Circuit
Short to Ground
Short to Voltage
Signal Performance
Ignition Voltage​
P0102​
P0102, P01101​
P0690​
P0101​
Sensor
P0102, P1101​
P0102, P1101​
P0102*​
P0101, P1101​
Ground
P0102​
Pin
Wire
Circuit
Function
1​
0.5 BN/GY​
4008​
2​
0.5 WH/RD​
3201​
3​
0.5 GN/WH​
492​
4​
0.5 BK​
150​
Ground
5​
0.75 VT/BU​
5294​
6​
0.5 YE/WH​
3200​
7​
0.5 BK/VT​
2760​
8​
0.5 BN/VT​
472​
I started tracing the harness, I'll keep it posted any result.
In the meantime I tested compression on each cylinder just for information purposes..
