The electrical sensor that is part of the maf has high resistance.....nothing to do with airflow.
That is why you are getting a low voltage code most likely.
The ecm sends a specific voltage to the maf and looks at return voltage, expecting a certain return voltage based on rpm/throttle position/engine load.
It does not like the return voltage....it is getting implausable information.
Inspecting any airplaths between the maf to the throttle body was the correct start of the diagnosis......as long as you are satisfied there are no vacuum leaks from hoses feeding the intake manifold there isn't much beyond part replacement.
