Welcome Aboard!
Potential causes for this code,
P0236, to set are:
Vacuum supply
Pinched, collapsed or broken vacuum lines
Faulty control solenoid
Faulty PCM
Read more at:
P0236 Turbocharger Boost Sensor A Range Performance
Causes for this
P0532 code may include:
Defective or damaged A/C refrigerant pressure sensor
A/C refrigerant pressure sensor leaking
Low or incorrect refrigerant pressures/refrigerant level
Damaged wire(s) (open,short to +, short to -, etc.)
Damaged connector ECC (Electronic Climate Control) or
BCM (Body Control Module) issue
Poor connections
Read more at:
P0532 A/C Refrigerant Pressure Sensor A Circuit Low
