I can't answer that question, but just be aware that the engine uses a number of "Torque to yield" bolts. Meaning, you should be using new bolts to install and not reuse the old ones. You'll probably want a tool that can measure angle as well, so if the specs call for 10 ft-lb + 30 degrees, you're not guessing on how far 30 degrees is.
