Hi
Dear All
I have 2010 Chevrolet Cruze 1.8 with 82 thousand kilometers driven. Recently check engine light on and when taken to the mechanic to check they clear the code and check engine light went off. After a week while driving the check engine light turn on again with the same code, this time the mechanic opens the sensor to clean it properly and fix back again with clear codes and check engine off. After a week the same issue happened again check engine light on and the code is exhaust cam position also, this time mechanic changes the sensor and same scenario check engine light off then after a while on again. We changed the sensor assuming maybe the new sensor is defective so we change to another new sensor and the same issue repeat. Now we are completely lost and we don't know how to solve the problem especially that car run very smooth no weird sounds not rough and engine start very smooth no issues at all while driving no problems with gearbox, everything runs smooth and quiet but check engine light on and when scan using the scanner it says exhaust cam position.
as I read that it might be due to the following reasons:
- Dirty engine oil
- Exhaust camshaft
- Pulley
- ECU (But for ECU usually there are signs like difficult to start engine, rough engine, check light on with many of codes, electric and electronic problems but all those signs I don't have)
Did anyone come across this problem before?
Can anyone advise what to do?
Code is
P0365
Thanks a lot,
